L
LAban24
Hi
I'm looking into creating a two-level certificate hierarchy and I'm just
wondering, are there any advantages by running this as opposed to a
single-level CA certificate?
A three-level hierarchy (which is what Microsoft docs seem to advocate) is
an overkill for my intended use of a CA.
I want to set up a CA solution that's as secure as possible without using HW
based crypto units or a three-level CA hierarchy. That's why I am wondering
if a two-level CA hierarchy will do the job. All my issuing CA's will be
issuing the same type of certificates.
If the certificate of the issuing certificate CA is compromised, do I need
to rebuild the entire hierarchy?
Any best-practices out there for a two-level CA solution?
Other things I should be aware of?
Thanks,
L.
Thanks,
L.
