DaMan
Active Member
- Joined
- Nov 17, 2003
- Location
- South of Nowhere
<center><a href="http://www.bgr.com/2011/11/08/apples-iphone-4s-antenna-resolves-death-grip-issues-consumer-reports-finds"><img class="size-full wp-image-111703 aligncenter" title="antennagate" src="http://www-bgr-com.vimg.net/wp-content/uploads/2011/11/antennagate.jpg" alt="" width="652" height="482" /></a></center>
Apple was undoubtedly losing sleep over the fact that Consumer Reports refused to “recommend” its iPhone 4 due to the attenuation issues affectionately referred to as <em>Antennagate</em> — Consumer Reports continuously praised the iPhone 4 despite saying <a href="http://www.bgr.com/2010/07/12/consumer-reports-iphone-4/">it couldn’t recommend the phone</a> — but now the Cupertino-based company can finally sleep easy. Consumer Reports on Tuesday proclaimed that the redesigned antenna system on Apple’s iPhone 4S is no longer affected by the dreaded <em>death grip</em>. “In special reception tests of the iPhone 4S that duplicated those we did on the iPhone 4, the newer phone did not display the same reception flaw, which involves a loss of signal strength when you touch a spot on the phone’s lower left side while you’re in an area with a weak signal,” the independent consumer shopping guide stated on its blog. While the new antenna allowed the iPhone 4S to score higher than its predecessor in Consumer Reports’ ratings, the improvements still weren’t enough to top Samsung’s Galaxy S II, the LG Thrill or the Motorola DROID BIONIC.<span id="more-111700"></span>
<a href="http://news.consumerreports.org/electronics/2011/11/consumer-reports-recommends-the-iphone-4s.html">Read</a>
<img src="http://feeds.feedburner.com/~r/TheBoyGeniusReport/~4/G2uWgGPTmPE" height="1" width="1"/>
Via BRG - Boy Genius Report
