Blue screen - DRIVER POWER STATE FAILURE
N
NewsBot
<span>Could use some help.</span>
<span>Since I moved my system partition to an SSD, I get BSOD 'driver power state failure' errors. Randomly.</span>
<span>Shutting down certain hardware (e.g. USB 3.0) doesn’t help.</span>
<span>Could you read my <a href="https://skydrive.live.com/redir?resid=B8D5A44BDC113C1D!124" target="_blank">
minidump</a> to find the driver causing the issue?</span>
<span>Much obliged,</span>
<span>Simon</span>
On Fri 18-5-2012 14:41:10 GMT your computer crashed
crash dump file: M:WindowsMinidump�51812-10920-01.dmp
This was probably caused by the following module: <a href="http://www.google.com/search?q=ntoskrnl.exe" target="_blank">
ntoskrnl.exe</a> (nt+0x7F1C0)
Bugcheck code: 0x9F (0x3, 0xFFFFFA800EE84060, 0xFFFFF80000B9C518, 0xFFFFFA800D051010)
Error: <a href="http://www.google.com/search?q=MSDN+bugcheck+DRIVER_POWER_STATE_FAILURE" target="_blank">
DRIVER_POWER_STATE_FAILURE</a>
file path: M:Windowssystem32ntoskrnl.exe
product: <a href="http://www.google.com/search?q=Microsoft® Windows® Operating System" target="_blank">
Microsoft® Windows® Operating System</a>
company: <a href="http://www.google.com/search?q=Microsoft Corporation" target="_blank">
Microsoft Corporation</a>
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
View the thread
