CJMs 2013 Build
CJM
As you all pretty well know Ive been planning a rebuild for awhile. Just got all the parts I need for the motor today and will be sending the head off to P&P as well as new valves and springs.
Currently were sitting with:
-2004 450R, stock motor, CT exhaust with open tip (spark arrestors ok but meh open tip has more power) and thats basically it besides an outerwears box I custom made, and an 06+ swinger setup. FWIW once I can get it started it runs rather well. my only worry is the clutch arm seal leaks a bit b/c I welded the case on the bike for the case saver. Im hoping my welder just fried the seal-but if not I think a new seal and some RTV may work well.
The build has evolved overtime into the following:
-12:1 CP piston sb/ss
-Stage 2 hotcam
-Used but EXCELLENT shape clutch/basket (ty Ed!)
-Ported head from Matt at Dynamite w/valve job, new valves and springs
-Tokyo Mods clutch springs
Later:
-CFM airbox if I can find one used
-+1 arms (most likely houser or JD)
-GT Thunder MX link
-Revalved stock shocks, probably dirtworks since jet is closing
-GFX
-Custom cut PRM swinger skidplate
-PRM chassis skid
-PRM Edge bumper possibly
-Pro armor grab bar
-JD +1 custom anti-vibe stem
-FCR off a dirtbike
Otherwise should be good to go. Goal is to make an excellent desert/trail riding machine. I dont need the most insane power and I dont need the most hopped up suspension. My days of riding balls to the wall are mostly over, cant afford to get hurt these days anymore.
I REALLY wanted to do an all out build but I think Im going to focus on making it a runner for now. Later on perhaps this winter Id like to PC the frame candy apple or perhaps a metallic flake red, then if funds allow Id REALLY like to get some white plastics PC the wheels gold, get a blue seat and do a retro 250/crf looking build. Think it would look BA!
04R work in progress
Link to comment
Share on other sites
  • Replies 120
good luck and keep us posted... if you want some sick a arms i got a POC in LSR and in http://www.teixeiratech.com/
http://www.offtopic.forum/data/MetaMirrorCache/06f1a7ba567102d307e3f721efc437ad.jpg
Zorros racing..
#123A - Baja 500, 2014 FINISHER !!!
Subscribe to us on FB http://www.facebook.com/zorros.rt
http://www.offtopic.forum/data/MetaMirrorCache/91c75944b97d47249f183869c9875a9e.gif
http://www.offtopic.forum/data/MetaMirrorCache/5639c3ecf3b34b1f1e26b660950f9785.gif
Join the http://www.Marines.com travel to exotic lands, meet exciting unusual people and kill them..
Link to comment
Thanks guys. So far you and dave have been super helpful as well as mamito (can I drop your name at dirtworks lol?) in this build.
I cant wait to have it all done up, I just pray the jugs good and not wallowed out..it is either new stock sized jug or 480 kit.
Link to comment
Jugs aren't very expensive depending on what kinda jugs your paying for. ;)
Link to comment
My only experience is with 2 at a time and they arent cheap if you want to have a good look at them lol :gr_nod:
Link to comment
Looking good, I'm tuned into this one!
Look at a CRF carb, I got mone for like 100 bucks from a CRF 250 and I don't even have to cut the wires on the TPS and I have $200 into the carb(+jets)
CRASHTEST RACING
IMMORTAL ATV
http://www.offtopic.forum/data/MetaMirrorCache/7cbc5acb2a1ab76eac286e7fe5b4520d.jpg
Link to comment
That was the plan Dave. Im probably gonna look for a clean one for awhile and when I get one I'll put it on during the winter months when I go over everything to make sure its tip top for spring.
Link to comment
Don't quote me but I think 2004 is the best year for the TPS plug, I think it can only be bored to 42.5 though, which is fine by me lol.
CRASHTEST RACING
IMMORTAL ATV
Link to comment
Any year 450f carb will need the TPS rewired but they start off at 40mm.. but if it's getting bored anyway, pick up a 250 carb (they are cheaap compared to the 450f carbs)
You're having Matt do the work and he charges the same to have it bored from 37mm or 40mm, the 250 carb just has the wiring already done. Not a big deal, your more than capable but a PITA none the less lol
CRASHTEST RACING
IMMORTAL ATV
Link to comment
Sounds good Dave
Edit: Just was replacing the swingarm pinch bolts b/c mine are a bit stripped from PO. Decided to see just how much play the axle had since I had to go to town with my grinder and a sanding disc on the sprocket and brake hub when I did the carrier. Imho it has too much, can clearly move it ever so slightly up and down and get that little audible thump thump. Looks like I need a new axle/brake hub now, hopefully I can nab a good used setup.Oh well I tried to save it lol.
Link to comment
I asked you to not reply. Please delete your post Ryan. As for riding with you, that will never happen as long as either of us live, ok?
Currently Pm ethanschaeffer on the org, we shall see what happens Ed. I need one thats in good shape, mine was all galled up on the sprocket hub. Axle itself is fine but I aint pressing out the sprocket hub lol.
  • Like 1
Link to comment
He's a good guy to deal with! I got two Unis/Box/Tube for $61 shipped! Text him up, good guy to shoot the breeze with:gr_cheers:
CRASHTEST RACING
IMMORTAL ATV
Link to comment
Dang stew, I just got one thru ethan shafer at the org. Oh well.. I need anything else along the way Ill let you know.
Also scored a near brand new brake hub off ebay for $35 shipped.
See, I tried to save the axle/hub b/c they were all chewed up but I guess taking 1/8" off was to much.
Link to comment
Hub came today, man is it mint for $35 lol. Got me some sprocket bolts (rather replace than reuse), waiting on the axle and some brake hub bolts (just incase the bolts dont come out ez), got some cv4 red hoses off the org, got a desert quadtech seat coming. Now all I need to do is make sure the dang axle/carrier is ok when everything comes and sendoff my head when my builder buddy gets back so we can go over stuff. Im confident in my skills but he is easily 3 notches over me. I mostly want him to check the crank out.
Link to comment
Got the axle yesterday and my nice quadtech desert seat. Going to try and put the axle on in a few mins actually. Hoping I didnt toast the carrier bearings from that one ride where I used the axle I tried to fix (its only loose on the sprocket side where I ground the axle down). Cross your fingers...
In other news Im hoping I have enough funds to do the head porting in the few next week. My buddy who agreed to help me do the motor is on vacation and on top of that my pick up needs a timing belt and I really dont want to spend but its gotta be done.
At least Ill have the 450 about 80% done with what I want after the motor. I think Ill break it down over the winter and I think Ill paint the frame or PC if I can get my buddy to do it cheap again (thinking maybe candy apple red or similar to go with the retro CRF/TRX look from the 80s I want to do). Also want to do +1 arms up front and put the MX link on the rear with reworked stockers.
off to go put an axle in.
Link to comment
Sounds pretty solid. I like the retro CRF look that's been done a few times, I thought about doing a bike like Honda put out in 2013 (all white with blue and red like the old 250rs)
I just had to buy new summer tires for my truck, that's nice on the wallet when I'm 3/4 of the way through a rebuild on the bike haha
CRASHTEST RACING
IMMORTAL ATV
Link to comment
