P
PogMaThoin
Hi I tried to play this game I used to play called maplestory it worked B4 on my computer and I installed it. When I went to play it gave me an (unspecified error) and I was told to run Dxdiag. I don't know how to fix this so here is the log...Please Help Me
System Information
Time of this report: 3/17/2012, 14:47:18
Machine name: ACER-6E40E97492
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.111025-1629)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: AOA150
BIOS: InsydeH2O Version v0.3305
Processor: Intel(R) Atom(TM) CPU N270 @ 1.60GHz (2 CPUs)
Memory: 1012MB RAM
Page File: 361MB used, 2066MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: Several files (kstvtune.ax, ksxbar.ax, kswdmcap.ax, etc.) are incorrectly installed in the Windows folder and should be deleted.
Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 945 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) GMA 950
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_27AE&SUBSYS_015B1025&REV_03
Display Memory: n/a
Current Mode: 1024 x 600 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.4926 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 2/15/2008 08:12:06, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 2/15/2008 08:12:06, 5854752 bytes
Device Identifier: {D7B78E66-64EE-11CF-AB60-5121A2C2CB35}
Vendor ID: 0x8086
Device ID: 0x27AE
SubSys ID: 0x015B1025
Revision ID: 0x0003
Revision ID: 0x0003
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0268&SUBSYS_1025015B&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5628 (English)
WHQL Logo'd: Yes
Date and Size: 5/20/2008 02:53:00, 4800000 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27CA
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 00:15:38, 59520 bytes
| Driver: usbd.sys, 4/14/2008 20:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: pnp0303
| Upper Filters: DKbFltr
| Service: i8042prt
| Driver: DKbFltr.SYS, 12/7/2004 23:10:00, 16896 bytes
| Driver: FILTRCOI.DLL, 12/8/2004 21:04:40, 5120 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 05:43:22, 40840 bytes
| Driver: kbdclass.sys, 4/14/2008 20:00:00, 24576 bytes
+ Synaptics PS/2 Port Pointing Device
| Matching Device ID: pnp0f13
| Upper Filters: SynTP
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 20:00:00, 52480 bytes
| Driver: mouclass.sys, 4/14/2008 00:09:48, 23040 bytes
| Driver: SynTP.sys, 4/24/2008 18:17:10, 225024 bytes
| Driver: SynTPAPI.dll, 4/24/2008 18:31:12, 151552 bytes
| Driver: SynCOM.dll, 4/24/2008 18:19:00, 163840 bytes
| Driver: SynCtrl.dll, 4/24/2008 18:19:46, 200704 bytes
| Driver: SynTPRes.dll, 4/24/2008 18:38:46, 5824512 bytes
| Driver: SynTPCpl.dll, 4/24/2008 18:34:42, 946176 bytes
| Driver: SynCntxt.rtf, 4/24/2008 18:39:12, 4659147 bytes
| Driver: SynZMetr.exe, 4/24/2008 18:21:42, 241664 bytes
| Driver: SynMood.exe, 4/24/2008 18:20:52, 233472 bytes
| Driver: SynTPEnh.exe, 4/24/2008 18:32:08, 1044480 bytes
| Driver: SynTPCOM.dll, 4/24/2008 18:31:34, 102400 bytes
| Driver: Tutorial.exe, 4/24/2008 18:39:04, 327680 bytes
| Driver: InstNT.exe, 4/24/2008 19:08:08, 118784 bytes
| Driver: SynISDLL.dll, 4/24/2008 18:39:28, 630784 bytes
| Driver: SynUnst.ini, 5/1/2008 18:40:08, 440935 bytes
| Driver: fx04.wav, 5/8/2007 18:48:26, 16898 bytes
| Driver: SynAcer.exe, 4/24/2008 18:22:12, 139264 bytes
| Driver: SynAcerCpl.cpl, 4/24/2008 18:21:58, 241664 bytes
| Driver: SynTPCo4.dll, 4/24/2008 19:07:56, 110592 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 115.5 GB
Total Space: 147.6 GB
File System: NTFS
Model: WDC WD1600BEVT-22ZCT0
System Devices
Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_015B1025&REV_02\3&B1BFB68&0&FB
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_015B1025&REV_02\3&B1BFB68&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/14/2008 20:00:00, 144384 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D6
Device ID: PCI\VEN_8086&DEV_27D6&SUBSYS_00000000&REV_02\3&B1BFB68&0&E3
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 68224 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D4
Device ID: PCI\VEN_8086&DEV_27D4&SUBSYS_00000000&REV_02\3&B1BFB68&0&E2
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D2
Device ID: PCI\VEN_8086&DEV_27D2&SUBSYS_00000000&REV_02\3&B1BFB68&0&E1
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_00000000&REV_02\3&B1BFB68&0&E0
Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_015B1025&REV_02\3&B1BFB68&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 7168 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_015B1025&REV_02\3&B1BFB68&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 20608 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_015B1025&REV_02\3&B1BFB68&0&EA
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_015B1025&REV_02\3&B1BFB68&0&E9
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_015B1025&REV_02\3&B1BFB68&0&E8
Name: Intel(R) 82801GBM/GHM (ICH7-M Family) Serial ATA Storage Controller - 27C4
Device ID: PCI\VEN_8086&DEV_27C4&SUBSYS_015B1025&REV_02\3&B1BFB68&0&FA
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 4/14/2008 20:00:00, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 96512 bytes
Name: Intel(R) 82801GBM (ICH7-M/U) LPC Interface Controller - 27B9
Device ID: PCI\VEN_8086&DEV_27B9&SUBSYS_00000000&REV_02\3&B1BFB68&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 37248 bytes
Name: Mobile Intel(R) 945 Express Chipset Family
Device ID: PCI\VEN_8086&DEV_27AE&SUBSYS_015B1025&REV_03\3&B1BFB68&0&10
Driver: C:\WINDOWS\system32\DRIVERS\igxpmp32.sys, 6.14.0010.4926 (English), 2/15/2008 08:12:06, 5854752 bytes
Driver: C:\WINDOWS\system32\igxprd32.dll, 6.14.0010.4926 (English), 2/15/2008 08:12:06, 57344 bytes
Driver: C:\WINDOWS\system32\igxpgd32.dll, 6.14.0010.4926 (English), 2/15/2008 08:12:06, 151040 bytes
Driver: C:\WINDOWS\system32\igxpdv32.dll, 6.14.0010.4926 (English), 2/15/2008 08:12:16, 1670144 bytes
Driver: C:\WINDOWS\system32\igxpdx32.dll, 6.14.0010.4926 (English), 2/15/2008 08:12:14, 2643968 bytes
Driver: C:\WINDOWS\system32\igxpxk32.vp, 2/15/2008 07:38:38, 2096 bytes
Driver: C:\WINDOWS\system32\igxpxs32.vp, 2/15/2008 10:09:18, 27024 bytes
Driver: C:\WINDOWS\system32\hccutils.dll, 6.14.0010.4926 (English), 2/15/2008 07:45:44, 102400 bytes
Driver: C:\WINDOWS\system32\igfxsrvc.dll, 6.14.0010.4926 (English), 2/15/2008 07:46:08, 48128 bytes
Driver: C:\WINDOWS\system32\igfxsrvc.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:16, 256536 bytes
Driver: C:\WINDOWS\system32\igfxpph.dll, 6.14.0010.4926 (English), 2/15/2008 07:46:26, 204800 bytes
Driver: C:\WINDOWS\system32\igfxcpl.cpl, 6.14.0010.4926 (English), 2/15/2008 07:46:28, 122880 bytes
Driver: C:\WINDOWS\system32\igfxcfg.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:06, 530968 bytes
Driver: C:\WINDOWS\system32\igfxdev.dll, 6.14.0010.4926 (English), 2/15/2008 07:45:40, 208896 bytes
Driver: C:\WINDOWS\system32\igfxdo.dll, 6.14.0010.4926 (English), 2/15/2008 07:46:16, 135168 bytes
Driver: C:\WINDOWS\system32\igfxtray.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:20, 141848 bytes
Driver: C:\WINDOWS\system32\igfxzoom.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:24, 170520 bytes
Driver: C:\WINDOWS\system32\hkcmd.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:04, 166424 bytes
Driver: C:\WINDOWS\system32\igfxress.dll, 6.14.0010.4926 (English), 2/15/2008 07:45:28, 3293184 bytes
Driver: C:\WINDOWS\system32\igfxpers.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:14, 137752 bytes
Driver: C:\WINDOWS\system32\igfxrara.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:24, 159744 bytes
Driver: C:\WINDOWS\system32\igfxrchs.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:24, 110592 bytes
Driver: C:\WINDOWS\system32\igfxrcht.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:24, 110592 bytes
Driver: C:\WINDOWS\system32\igfxrdan.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:26, 172032 bytes
Driver: C:\WINDOWS\system32\igfxrdeu.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:26, 192512 bytes
Driver: C:\WINDOWS\system32\igfxrenu.lrc, 6.14.0010.4926 (English), 2/15/2008 07:45:40, 172032 bytes
Driver: C:\WINDOWS\system32\igfxresp.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 188416 bytes
Driver: C:\WINDOWS\system32\igfxrfin.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 176128 bytes
Driver: C:\WINDOWS\system32\igfxrfra.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 184320 bytes
Driver: C:\WINDOWS\system32\igfxrheb.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrita.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:30, 188416 bytes
Driver: C:\WINDOWS\system32\igfxrjpn.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:30, 131072 bytes
Driver: C:\WINDOWS\system32\igfxrkor.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 126976 bytes
Driver: C:\WINDOWS\system32\igfxrnld.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 188416 bytes
Driver: C:\WINDOWS\system32\igfxrnor.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 176128 bytes
Driver: C:\WINDOWS\system32\igfxrplk.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 180224 bytes
Driver: C:\WINDOWS\system32\igfxrptb.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 180224 bytes
Driver: C:\WINDOWS\system32\igfxrptg.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 180224 bytes
Driver: C:\WINDOWS\system32\igfxrrus.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 180224 bytes
Driver: C:\WINDOWS\system32\igfxrsky.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 176128 bytes
Driver: C:\WINDOWS\system32\igfxrslv.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 172032 bytes
Driver: C:\WINDOWS\system32\igfxrsve.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 172032 bytes
Driver: C:\WINDOWS\system32\igfxrtha.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 163840 bytes
Driver: C:\WINDOWS\system32\igfxrcsy.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:26, 176128 bytes
Driver: C:\WINDOWS\system32\igfxrell.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 192512 bytes
Driver: C:\WINDOWS\system32\igfxrhun.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:30, 180224 bytes
Driver: C:\WINDOWS\system32\igfxrtrk.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 172032 bytes
Driver: C:\WINDOWS\system32\igfxext.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:10, 170520 bytes
Driver: C:\WINDOWS\system32\igfxexps.dll, 6.14.0010.4926 (English), 2/15/2008 07:46:18, 24576 bytes
Driver: C:\WINDOWS\system32\iglicd32.dll, 6.14.0010.4926 (English), 2/15/2008 08:00:58, 2334720 bytes
Driver: C:\WINDOWS\system32\igldev32.dll, 6.14.0010.4926 (English), 2/15/2008 08:01:04, 294912 bytes
Driver: C:\WINDOWS\system32\igfxCoIn_v4926.dll, 2/15/2008 08:21:56, 147456 bytes
Name: Mobile Intel(R) 945GME Express Processor to DRAM Controller - 27AC
Device ID: PCI\VEN_8086&DEV_27AC&SUBSYS_00000000&REV_03\3&B1BFB68&0&00
Driver: n/a
Device ID: PCI\VEN_8086&DEV_27A6&SUBSYS_015B1025&REV_03\3&B1BFB68&0&11
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_00000000&REV_E2\3&B1BFB68&0&F0
Name: Atheros AR5007EG Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_001C&SUBSYS_E008105B&REV_01\4&2803E7C1&0&00E2
Driver: n/a
Name: Realtek RTL8102E Family PCI-E Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8136&SUBSYS_015B1025&REV_02\4&20975680&0&00E1
Driver: C:\WINDOWS\system32\DRIVERS\Rtenicxp.sys, 5.732.0629.2009 (English), 6/29/2009 12:59:14, 142592 bytes
Driver: C:\WINDOWS\system32\RtNicProp32.dll, 1.02.0000.0003 (English), 6/10/2009 03:34:20, 73728 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 4/14/2008 20:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 4/14/2008 20:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 4/14/2008 20:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 82432 bytes
system.dll: 1.01.4322.2494 English Final Retail 1/18/2012 04:12:43 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 3/13/2012 12:23:37 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 3/13/2012 12:23:31 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 3/13/2012 12:23:32 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 3/13/2012 12:23:32 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 3/13/2012 12:23:33 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 3/13/2012 12:23:33 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 3/13/2012 12:23:34 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 3/13/2012 12:23:34 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 3/13/2012 12:23:35 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 3/13/2012 12:23:36 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 3/13/2012 12:23:38 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:38 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:38 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:39 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:39 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:37 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:37 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:36 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6151 English Beta Retail 9/17/2010 23:53:25 954368 bytes
mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 06:33:55 978944 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 20:00:00 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 20:00:00 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 20480 bytes
qasf.dll: 11.00.5721.5262 English Final Retail 1/30/2009 21:34:02 211456 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 279040 bytes
qdvd.dll: 6.05.2600.6169 English Final Retail 11/3/2011 08:28:36 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 733696 bytes
quartz.dll: 6.05.2600.6169 English Final Retail 11/3/2011 08:28:36 1292288 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 01:00:21 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 20:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 20:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 20:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 20:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 20:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 20:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 20:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 20:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 02:01:48 204800 bytes
ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:44 129536 bytes
ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:58 4096 bytes
stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:52 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 00:09:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:54 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:54 4352 bytes
mstee.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:52 5504 bytes
ipsink.ax: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:44 16384 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 118272 bytes
ndisip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 10880 bytes
streamip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 15232 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 1428992 bytes
slip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 11136 bytes
nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:26 85248 bytes
ccdecode.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 17024 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 30208 bytes
msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 10:11:44 17920 bytes
wstcodec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:26 19200 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.5512
CC Decoder,0x00200000,2,1,,5.03.2600.5512
WST Codec,0x00200000,1,1,,5.03.2600.5512
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
InterVideo Video Decoder,0x00700000,2,4,IVIVIDEO.ax,5.00.0011.1255
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6169
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8117.0416
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
InterVideo Audio Processor,0x00200000,1,1,IviAudioProcess.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6169
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5262
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5262
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6169
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6169
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
Intervideo CDSF Filter,0x00200000,0,1,ivicdsf.ax,9.00.0000.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.6076
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6169
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6169
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5262
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.6169
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5262
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6169
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5262
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6169
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6169
File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5262
InterVideo Audio Decoder,0x00700000,1,1,iviaudio.ax,5.00.0011.1255
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6169
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5262
InterVideo Navigator,0x00190000,0,3,Ivinav.ax,5.00.0011.1255
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5262
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.6076
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6169
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6169
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6169
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5262
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6169
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6169
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6169
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6169
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.5512
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6169
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.05.2600.5512
VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6169
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6169
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.6169
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6169
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6169
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6169
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.6169
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6169
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6169
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6169
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6169
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6169
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.6169
WDM Streaming Capture Devices:
Realtek HD Audio Input,0x00200000,1,1,,5.03.2600.5512
Acer Crystal Eye webcam,0x00200000,0,1,,5.03.2600.5512
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,,5.03.2600.5512
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.5512
Video Capture Sources:
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.6161
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.6161
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.6161
WDM Streaming Communication Transforms:
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.6169
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6169
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6169
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.6169
WDM Streaming System Devices:
Realtek HD Audio Input,0x00200000,2,1,,5.03.2600.5512
Realtek HD Audio output,0x00200000,4,1,,5.03.2600.5512
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
System Information
Memory: 1012MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
DAC type: Internal
Display Memory: n/a
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x8086
Device ID: 0x27AE
Revision ID: 0x0003
Revision ID: 0x0003
Video Accel:
Registry: OK
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: i8042prt
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
File System: NTFS
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
