DVD Burning Help
shadowfax1007
New member
Hey guys
I was just wondering if anyone knew how I could burn a video file to play on a dvd, but also have an album, caus I want to burn The Making Of The Rising Tied and The Rising Tied on a dvd to play on my DVD player.
I hope that makes sense...
Can anyone help?
DJ BloodFrost
New member
Let me see if I understand this correctly.
You want to make a custom DVD of The Making of The Rising Tied PLUS The Rising Tied.
This is close to impossible unless you have a LOT of money. Ripping the TRT DVD is the easy part, but then you would have to edit the menus to accomodate for a DVD-Audio section, which would have to be made from scratch anyway. DVD-Audio burning software is INSANELY expensive, and not too commonly provided illegally either. And editing the TRT DVD menus would be a ***** as well.
It's a really sweet idea, but I just don't see it happening.
shadowfax1007
New member
I have both the album and the dvd, i also have the dvd ripped in avi, i just wanted to combine the two......an example of what i mean is the Frat Party dvd, how you can watch the videos, and listen to 1stp klsr and high voltage etc
DJ BloodFrost
New member
I have both the album and the dvd' date=' i also have the dvd ripped in avi, i just wanted to combine the two......an example of what i mean is the Frat Party dvd, how you can watch the videos, and listen to 1stp klsr and high voltage etc[/quote']
I believe that on the Frat Party DVD, 1STP KLOSR and High Voltage appear to be DVD-Audio, but are actually DVD-Video with a static image. That is a possibility as well, but still very difficult.
P.S. Using AVI as a source for a DVD is a bad idea, especially when you have the DVD itself.
Stenners
New member
Doesnt Nero allow custom menus for DVD's? Just put in the rising tied feature presentation and the audio and work from there :)
DJ BloodFrost
New member
We're not talking about MAKING a menu. We're talking about EDITING a menu, a professionally made one at that. Good luck, because this it what you would have to do:
A. Make it in DVD-Audio format and add the TRT DVD into it as "custom DVD-Video content"
OR
B. Make a video file for each of the tracks with a static image as the video and then add them to the TRT DVD image. You'll have to rip all the TRT tracks in WAVE format to preserve the track length (so gaps aren't added) and make MPEG files for maximum picture and audio quality.
And, either way, you'll have to edit the menu, which, last I checked, is still a *****.
