M
mm
On Thu, 10 Jun 2010 14:23:01 -0700, Mark Adams
<MarkAdams@discussions.microsoft.com> wrote:
>"mm" wrote:
>> On Tue, 8 Jun 2010 23:52:07 -0300, "news.microsoft.com"
>> <pjp_is_located_@_hotmail_dot_com> wrote:
>> >You mentioned it's an Averatec laptop. I have a 6100 works fine.
>> >Their site seems to have all the extra drivers you likely need. It's not
>> >enough to just install XP but you also must install the manufacturer's
>> >motherboard, audio, USB etc. drivers. As you don't have the original install
>> >cd's that's the way to go (and basically is for all pc's nowadays when don't
>> >have original Restore disks).
>> Great idea. It has two options, a list of drivers, but the only one
>> that relates to a problem I know of is the audio driver. It doesn't
>> show anything for USB. I should look for a generic USB driveer, I
>> think, but how will I install it when Device Manager doesn't work?
>> It also had a link to a DriverAgent page, which said Welcome Averatec
>> customers, and offered a driver scan. Since it was recommended by
>> Averatec I did it, and it froze the computer at 40% of the scan. Did
>> the same thing 3 times.
>> On my own computer, I dl'd the same program, same version number from
>> the same site, and it ran to completion and said it had newer drivers
>> for 12 out of 36 drivers. (Although none of those things are giving me
>> problems)
>NEVER use one of these driver detecting programs. They charge you money to
>download drivers that are available for free from the manufacturer's website,
>and they frequently offer obsolete or completely wrong drivers- a sure way to
>hose your system.
Well this is what finally happened tonight (Sunday). Don't start
your reply until reading the whole thing.
I had already left the laptop with my young friend with instructions
to backup any data to CD's, when I came home and read Mark's post that
I'm replying to.
Turns out the CD writer wasn't working either (No CD in drive) so then
I was going to have him gat some google storage space and upload it
there.
Then I read Mark's post
>Go to the Averatec website and download all the drivers for your model
>machine and burn them to CD.
I made the CD and went there tonight. Sunday
> Install the drivers from the CD. If a "chipset"
>driver is listed, install it first and reboot the computer.
There was, also called 4in1, four in one, and I ran that driver .exe
first and rebooted, and I think it didn't help. Then I ran it again,
and it detected the USB flashdrive. Hooray. And thanks.
>That will
>probably get the USB ports working by providing support for the "Enhanced USB
>Controller".
Yes indeedy.
>Install the video and audio drivers next. Reboot and go to
Installed audio, from the self-extracting file, and got a long string
of "Creation of folder Failed". In fact it didn't extract anything.
Did it again, same result.
Skipped video for now because video seemed good.
Did CPU Power, but it wanted to uninstall things. I guess because
everything was installed. Hmmmm. Maybe we should have uninstalled
and installed, but I just put that one aside for later, and then
skipped it.
Ran MousePad, or SomethingPad, Touchpad, because his cursor had been
moving when no one was touching it, usually falling down the screen.
Not enough time for me to decide if this fixed it, and my
young friend wasn't sure if it was better or not.
WLAN and LAN have been working fine so I put them aside for later and
skipped them.
I don't know what CARD is. And he probably won't ever need Modem,
plus we have no way to test it.
>Device Manager and look for yellow exclamation points next to devices.
>Continue to install the drivers for those devices.
Device Manager still didn't work. Googled error message for Blank
Device Manager and first hit said that the Plug and Play Service has
to be enabled. It wasn't. How did that change??
Also the error message when I tried to use Windows Help said the Help
& Support service was not working.
Ran services.msc and both services are disabled. Put both on
Automatic.
Sound now works, icon in systray for removing USB device appears, File
Manager works (and there are no yellow exclamation marks!.
The remaining questions are: What could mess up the USB so that the
chipset driver had to be reinstalled? How do such things happen?
And, any chance these services disabled themselves, or must my young
friend have done so?
Under grilling he admitted that he might have done something when he
was trying to stop something he didn't like. That could account for
the services but what about the USB driver?
He's 23, impatient, antsy, might even have DPDT or DBA or one of those
antsy syndromes. Probably not but I like the line.
So everything is fixed except maybe the CD burning. (Reading works.)
He or we should be able to fix that.
And it was all in all the chipset driver, two services. and maybe the
Touchpad driver.
Thanks a lot Mark, Daave, news, mike S, windrider, Ken, and Jim.
He had no money for another computer and had been trying to fix up a
win98 box. This is much better.
>> problems)
>hose your system.
I'm replying to.
there.
>That will
>Controller".
Yes indeedy.
skipped it.
skipped them.
Automatic.
Touchpad driver.
