U
undisclosed
my pc has been crashing non stop with 0x0000001e errors and it has no
string attached just plain 0x000. i updated the bios tonight but im
trying to make heads and tails of this mini dump to see if that will
resolve the issue. any help will be appreciated.
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\070910-26847-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: Invalid
Symbol loading may be unreliable without a symbol search path.
Use .symfix to have the debugger choose a symbol path.
After setting your symbol path, use .reload to refresh symbol
locations.
Executable search path is:
Symbols can not be loaded because symbol path is not initialized.
The Symbol Path can be set by:
using the _NT_SYMBOL_PATH environment variable.
using the -y <symbol_path> argument when starting the debugger.
using .sympath and .sympath+
Unable to load image ntoskrnl.exe, Win32 error 0n2
ERROR: Module load completed but symbols could not be loaded for
ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0xfffff800`02c10000 PsLoadedModuleList =
0xfffff800`02e4de50
Debug session time: Fri Jul 9 03:07:03.466 2010 (UTC - 4:00)
System Uptime: 0 days 0:12:31.544
ntoskrnl.exe
Loading Kernel Symbols
..............................................Unable to load image
Unknown_Module_00000000`00000000, Win32 error 0n2
WARNING: Unable to verify timestamp for
Unable to add module at 00000000`00000000
Loading User Symbols
Bugcheck Analysis
Use !analyze -v to get detailed debugging information.
BugCheck 1E, {0, 0, 0, 0}
Kernel symbols are WRONG. Please fix symbols to do analysis.
Your debugger is not using the correct symbols
In order for this command to work properly, your symbol path
must point to .pdb files that have full type information.
Certain .pdb files (such as the public OS symbols) do not
contain the required information. Contact the group that
provided you with these symbols if you need this command to
work.
Type referenced: nt!_KPRCB
work.
work.
Probably caused by : ntoskrnl.exe ( nt+705d0 )
Followup: MachineOwner
Darkankh
locations.
ntoskrnl.exe
Machine Name:
0xfffff800`02e4de50
ntoskrnl.exe
Bugcheck Analysis
work.
work.
work.
Darkankh
