Help With M2V
shadowfax1007
New member
hey guyz
on linkin-inside you can download videos but most are now in a format called .m2v
does any1 know wat i need to play these files or if there is a plugin for media player or sumthing
plz help
nkramar78
New member
hey guyz
plz help
m2v is nothing more than an MPEG-2 file with a different extension. If you can play MPEG 2 files on your computer, you should be able to do so with m2v files. There should be several codecs available, especially for WMP.
UnhingedMouse0
New member
m2v is nothing more than an MPEG-2 file with a different extension. If you can play MPEG 2 files on your computer' date=' you should be able to do so with m2v files. There should be several codecs available, especially for WMP.[/quote']
Thats what I thought... cuz dosent 'm2v' stand for 'MPEG 2 Video' or somethin like that.... ;)
nkramar78
New member
I believe you're right.
I think you can even change the extension directly to mpg or mpeg without any harm done to the file...
dany
New member
hey guyz
plz help
u really need smth like bs player or real one player
dany-romania
