Guest Gatemix Posted November 14, 2007 Share Posted November 14, 2007 Hi im having problems whit the web cam on this Computer , i have windows vista and when i try to install it , i allmost got it installd , but when i was gona select the web cam , then windows vista strted making problems ,an said tha the program vas a treath to t computer and somthing call DEP shutted dow my msn , by the way it was in Msn i tryd to install it:) so how do i deactivate DEP from a singel Program?? an please explain it in a easy way , im not a computer geek hehe style_emoticons/ but im getting there:) so if anyone can help me i greatfull:) Quote Link to comment Share on other sites More sharing options...
Guest Jesper Posted November 14, 2007 Share Posted November 14, 2007 You can't disable DEP for Live Messenger. It is considered a system binary, and those are designed to run with DEP. If this persists, your best option is going to be to get a different camera that is designed to work with Vista, or to see if there are updated drivers available for the one you have. I'd try the latter option first. --- Your question may already be answered in Windows Vista Security: http://www.amazon.com/gp/product/047010155...rotectyourwi-20 "Gatemix" wrote: <span style="color:blue"> > Hi im having problems whit the web cam on this Computer , i have windows > vista and when i try to install it , i allmost got it installd , but when i > was gona select the web cam , then windows vista strted making problems ,an > said tha the program vas a treath to t computer and somthing call DEP shutted > dow my msn , by the way it was in Msn i tryd to install it:) so how do i > deactivate DEP from a singel Program?? an please explain it in a easy way , > im not a computer geek hehe style_emoticons/ but im getting there:) so if anyone can help > me i greatfull:) </span> Quote Link to comment Share on other sites More sharing options...
Guest Gatemix Posted November 14, 2007 Share Posted November 14, 2007 -- i need help "Jesper" wrote: <span style="color:blue"> > You can't disable DEP for Live Messenger. It is considered a system binary, > and those are designed to run with DEP. > > If this persists, your best option is going to be to get a different camera > that is designed to work with Vista, or to see if there are updated drivers > available for the one you have. I'd try the latter option first. > --- > Your question may already be answered in Windows Vista Security: > http://www.amazon.com/gp/product/047010155...rotectyourwi-20 > > </span> yea but the web cam is a part of the computer ,so i dont understand why windows vista is rejcting it , it vas allredy on the computer when i got it ? <span style="color:blue"> ></span> Quote Link to comment Share on other sites More sharing options...
Guest Jesper Posted November 14, 2007 Share Posted November 14, 2007 Did your computer come with Windows Vista? If so the manufacturer should provide you with proper software that makes the webcam work. You need to call their tech support. If the web cam consistently causes Messenger to hang then they need to provide you with a solution. There is nothing we can really do to help you, unfortunately. --- Your question may already be answered in Windows Vista Security: http://www.amazon.com/gp/product/047010155...rotectyourwi-20 "Gatemix" wrote: <span style="color:blue"> > > -- > i need help > > > "Jesper" wrote: > <span style="color:green"> > > You can't disable DEP for Live Messenger. It is considered a system binary, > > and those are designed to run with DEP. > > > > If this persists, your best option is going to be to get a different camera > > that is designed to work with Vista, or to see if there are updated drivers > > available for the one you have. I'd try the latter option first. > > --- > > Your question may already be answered in Windows Vista Security: > > http://www.amazon.com/gp/product/047010155...rotectyourwi-20 > > > > </span> > yea but the web cam is a part of the computer ,so i dont understand why > windows vista is rejcting it , it vas allredy on the computer when i got it ? <span style="color:green"> > ></span></span> Quote Link to comment Share on other sites More sharing options...
Guest James Matthews Posted November 20, 2007 Share Posted November 20, 2007 You should be able to do it from the propties -- http://www.goldwatches.com/movado--watches.html http://www.jewelerslounge.com/ "Gatemix" <Arnstein_l_@hotmail.com> wrote in message news:F8367D1C-BF45-498C-BCE6-87FC5968A1B5@microsoft.com...<span style="color:blue"> > Hi im having problems whit the web cam on this Computer , i have windows > vista and when i try to install it , i allmost got it installd , but when > i > was gona select the web cam , then windows vista strted making problems > ,an > said tha the program vas a treath to t computer and somthing call DEP > shutted > dow my msn , by the way it was in Msn i tryd to install it:) so how do i > deactivate DEP from a singel Program?? an please explain it in a easy way > , > im not a computer geek hehe style_emoticons/ but im getting there:) so if anyone can > help > me i greatfull:) > </span> Quote Link to comment Share on other sites More sharing options...
Guest Elrik_C Posted March 20, 2008 Share Posted March 20, 2008 I also have problems with DEP that prevents the installation of system board device drivers, and since MachSpeed, the manufacturer of the system board has no intention of providing a DEP compatable set of Vista 64 bit device drivers and only made Vista 64 bit drivers as an after thought. So it would be nice if there were a way to completely disable DEP at least until all the device drivers are installed. Perhaps a registry tweak or removal of a system file? style_emoticons/ -- Elrik_C Posted via http://www.vistaheads.com Quote Link to comment Share on other sites More sharing options...
Guest Brink Posted March 20, 2008 Share Posted March 20, 2008 Elrik_C;653936 Wrote: <span style="color:blue"> > I also have problems with DEP that prevents the installation > of system board device drivers, and since MachSpeed, the > manufacturer of the system board has no intention of > providing a DEP compatable set of Vista 64 bit device drivers > and only made Vista 64 bit drivers as an after thought. > > So it would be nice if there were a way to completely > disable DEP at least until all the device drivers are installed. > > Perhaps a registry tweak or removal of a system file? style_emoticons/ > > > -- > Elrik_C > Posted via 'Microsoft Windows Vista Community Forums - Vistaheads' > (http://www.vistaheads.com)</span> Hi Elrik_C, I do not know if it will help in installing the drivers, but this will show you how to completely disable DEP. http://www.vistax64.com/tutorials/120778-d...le-disable.html Shawn -- Brink There are no dumb questions, just the people that do not ask them. ' VISTA FORUMS ' (http://www.vistax64.com/index.php?referrerid=2980) Please post feedback to help others. Quote Link to comment Share on other sites More sharing options...
