ghott
Well-Known Member
- Joined
- Apr 12, 2012
- Location
- Shen. Valley, VA
Up for sale are a few 04/05 Honda TRX450R parts.
First and foremost - the prices do NOT include shipping and do NOT include PP fees. Buyer will cover the PP fees or can gift the payment to save the hassle.
Shipping prices:
- Anything that will fit in a USPS Priority Mail small flat rate: - add $6
- Anything that will fit in a USPS Priority Mail medium flat rate: - add $13
- Anything that will fit in a USPS Priority Mail large flat rate: - add $18
- Anything larger than the above will be $25+ depending on box size, weight, and destination
Prices are pretty firm, but will cut you a break if you buy MULTIPLE items.
Here are the part's descriptions and pictures:
Complete Stock 04/05 A-Arm setup w/ Aftermarket (?) Tie Rods - $65
-- Comes with everything pictured
-- WILL NOT SEPARATE
-- PLEASE NOTE: threads on the a-arm ball joints will need to be cleaned up
-- Worked well, just removed - ball joints are tight, boots are in good shape
-- Tie rods look like they are aftermarket - pretty thick and strong
-- Also comes with the brackets for the brake line mounts
-- Do NOT come with frame mounting bolts, spindles, or hubs
-- Lots of scratches on these, but they are straight
Stock 04/05 TRX450R Parking/E-Brake Complete Setup w/ Cable - $5
-- Great shape, little dirty, has silver spray paint over-spray on it
Stock 04/05 TRX450R Head Light - $50
-- Comes with mounting brackets and bulbs
-- Worked great on high and low beam
Stock 04/05 TRX450R Oil Cooler (w/ lines, o-rings, shroud, and mounting bolts) - $20
-- Very nice complete set
-- Dirty but works great
Stock 04/05 TRX450R 94mm Piston w/ Pin and Rings - $5
-- No clue if this is in spec or not?
Handlebars - $15 (PENDING)
-- No clue what brand they are - possibly the brand pictured on the foam cover
-- Stock thickness
-- Comes with grips
Stock 04/05 TRX450R Ignition/CDI - $10 (PENDING)
-- Works great, just dirty
Shipping prices:
-- Stock thickness
-- Comes with grips
