W
WWD
I have windows 7 ultimate 64 bit installed with ie 9. Everything up to date with windows update. Sometimes when I open links in MSN only part of the link will open . This is frequently in the Wonderwall links found on MSN. The link opens completely in the 64 bit version of ie9 but not with the 32 bit. I have placed site in the safe sites, cleared cache, reset the explorer and disabled add ins. No effect. I uninstalled adobe flash. No change so is not flash player. Most of graphics that do not display are jpeg. There is no change in behavior if all firewalls are cleared and antivirus disabled.
Here is one link that displays this:http://wonderwall.msn.com/movies/trash-talk-ex-scientologist-director-alleges-garbage-snooping-1661709.story
Any advice on what to do next?
Thanks
Thanks
