"No Audio Output Device is installed"
S
SAlly
"Paul H" wrote:
> I did another restart of my Vista to remove constipation, etc. This time I
> have no sound. it says "No Audio Output Device is installed". How do I get
> sound back on my Acer 5610 laptop?
I did the automatic Update that it requests on Vista on my laptop and have
the problem with the speaker and red cross with alert saying "no audio output
is installed"
I do not have external speakers so no unplug/plug in issues there.
I have been through all of the online automatic checks and come to a dead end
1) check driver - did online and said it's the most recent version
2) cannot do 'roll back' driver option to older version so thinking driver
up to date
3) checking device is enabled - searched and showed it was 'disabled' so
clicked to enable - this is all on the recording - sound - of control panel.
The 'playback' tab shows no audio device installed and the buttons at bottom
(configure, set default, properties) are blanked out (i.e. cannot click)
At every stage I have restarted and at a dead end.
If anyone can help; I'd be much applied (sorry that I have clicked reply to
this post; I am IT challenged and in need of assistance!)
U
undisclosed
Sound problems cause by several reasons and every problem may have a
different solution. Once when I had similar sound problem I had found a
suggestion at http://www.noaudiooutput.com website that worked for me. There
are several suggestions given depending on different causes. So I would
like to suggest to check the said website and read all the suggestions
carefully. Maybe they have a suggestion that work for you too... :)
mak777
