A
Ahmed Dopolos
1. Right click the sound icon in the tray at the bottom right hand side of the computer.
2. Select playback devices
3. Select "No audio output devices installed"then right click it
4. Click "Show disabled devices"
5. Click "Properties"
6. Click "enable"
Hope that was helpful.
Paul H wrote:
"No Audio Output Device is installed"
20-Apr-08
I did another restart of my Vista to remove constipation, etc. This time I
have no sound. it says "No Audio Output Device is installed". How do I get
sound back on my Acer 5610 laptop?
On Sunday, April 20, 2008 1:51 PM
On Sunday, April 20, 2008 2:48 PM
Malke wrote:
Re: "No Audio Output Device is installed"
Paul H wrote:
Install the drivers. Get them from Acer's website for your specific model
laptop. Install all drivers, including the chipset, as well as any
laptop-specific software such as for power management.
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
On Sunday, April 20, 2008 3:17 PM
Paul H wrote:
Thanks. I'll try that.
Thanks. I'll try that. It's very frustrating to have to deal with things
like this - my XP Pro on my old laptop stays like I leave it. But my Vista
Home Premium frequently does me little favors like this. Real time wasters.
"Malke" <malke@invalid.invalid> wrote in message
news:ecDrecxoIHA.1420@TK2MSFTNGP03.phx.gbl...
I have no sound. it says "No Audio Output Device is installed". How do I
get sound back on my Acer 5610 laptop?
Malke
MS-MVP
Don't Panic!
On Wednesday, October 14, 2009 3:09 AM
Denis Richard wrote:
no audio output device installed
no audio output device installed.
how to I correct this ?
Mny thanks
20-Apr-08
Malke
MS-MVP
Don't Panic!
Thanks. I will try that. it is very frustrating to have to deal with things
Malke
MS-MVP
Don't Panic!
EggHeadCafe - Software Developer Portal of Choice
Lightweight ASP.NET DataSet to Excel Class
http://www.eggheadcafe.com/tutorial...9d-c9ca1b04fb7e/lightweight-aspnet-datas.aspx
On Wednesday, October 14, 2009 3:12 AM
Mny thanks
20-Apr-08
Malke
MS-MVP
Don't Panic!
Malke
MS-MVP
Don't Panic!
Mny thanks
IIS - Create App Pools, Virtual Directories and Web Sites C# .NET
http://www.eggheadcafe.com/tutorial...476-ff05b085d86e/iis--create-app-pools-v.aspx
On Sunday, October 18, 2009 10:41 AM
vandervecker wrote:
Ignore all suggestions about reinstalling audio drivers!
Ignore all suggestions about reinstalling audio drivers! U suspect that
will get you nowhere. Instead try this:
1. Open your registry editor (regedit from Run prompt). (For your own
safety, either back up the registry, set a restore point or export the
key in the next step.)
2. Drill down to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\
Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
3. Delete any of the following registry entries if they exist under
this key:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
4. Reboot the computer.
Hope this helps.
On Friday, April 09, 2010 2:28 AM
Lemonta wrote:
After following all these steps, sound returns, but after rebooting the
After following all these steps, sound returns, but after rebooting the no
audio output device installed err returns.
"Denis Richard" wrote:
On Wednesday, April 14, 2010 4:25 PM
SAlly wrote:
"Paul H" wrote:I did the automatic Update that it requests on Vista on my
"Paul H" wrote:
I did the automatic Update that it requests on Vista on my laptop and have
the problem with the speaker and red cross with alert saying "no audio output
is installed"
I do not have external speakers so no unplug/plug in issues there.
I have been through all of the online automatic checks and come to a dead end
1) check driver - did online and said it is the most recent version
2) cannot do 'roll back' driver option to older version so thinking driver
up to date
3) checking device is enabled - searched and showed it was 'disabled' so
clicked to enable - this is all on the recording - sound - of control panel.
The 'playback' tab shows no audio device installed and the buttons at bottom
(configure, set default, properties) are blanked out (i.e. cannot click)
At every stage I have restarted and at a dead end.
If anyone can help; I'd be much applied (sorry that I have clicked reply to
this post; I am IT challenged and in need of assistance!)
On Thursday, May 20, 2010 4:37 AM
undisclosed wrote:
Sound problems cause by several reasons and every problem may have adifferent
different solution. Once when I had similar sound problem I had found a
suggestion at www.noaudiooutput.com website that worked for me. There
are several suggestions given depending on different causes. So I would
like to suggest to check the said website and read all the suggestions
carefully. Maybe they have a suggestion that work for you too...
mak777
On Sunday, June 06, 2010 7:49 PM
Sabrina wrote:
When I read this thread, I followed the advice yet to no avail.
When I read this thread, I followed the advice yet to no avail. The reason I
had no success was because even though I had downloaded and re-installed the
driver, the driver was not what was missing. The device was missing - the
speakers themselves were gone. So I had to re-install the speaker hardware,
enable it and then once I did that , the driver had something to run from.
After start after re-start, it worked liked a charm but getting to that
realisation was frustrating. Hope this helps....
Sabrina
"Paul H" wrote:
Overriding Deserialization of Persisted Workflow Instances
http://www.eggheadcafe.com/tutorial...lization-of-persisted-workflow-instances.aspx
6. Click "enable"
20-Apr-08
Malke
MS-MVP
Don't Panic!
Malke
MS-MVP
Don't Panic!
Mny thanks
20-Apr-08
Malke
MS-MVP
Don't Panic!
Malke
MS-MVP
Don't Panic!
Mny thanks
20-Apr-08
Malke
MS-MVP
Don't Panic!
Malke
MS-MVP
Don't Panic!
Mny thanks
this key:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Hope this helps.
is installed"
up to date
mak777
Sabrina
