A
Anita
We have some Windows 2000 SP4 OpenVPN clients "on the road" that are unable
to connect with the VPN server. The logs on the server indicate that
everything is happening correctly.
The issue seems to be the failure of the virtual interface to be correctly
configured with DHCP:
D:\> ipconfig /all
Ethernet adapter Local Area Connection 4:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : TAP-Win32 Adapter OAS
Physical Address. . . . . . . . . : 00-FF-BC-1B-3E-7E
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IP Address. . . : 0.0.0.0
Subnet Mask . . . . . . . . . . . : 0.0.0.0
Default Gateway . . . . . . . . . :
DNS Servers . . . . . . . . . . . :
The server shows the client properly connected with DHCP-assigned address
10.8.0.5/16 with a gateway of 10.8.0.1 and correct DNS servers, yet the
client interface remains unconfigured, and the OpenVPN client states
"Unconnected", even though there is a "connection active" icon in the task
tray.
We've checked the "Services" to verify that the DHCP and DNS client are
started automatically, and have disabled APIPA in the registry, and .
Everything seems like it should be working ... yet it's not. The OpenVPN
online support people can find nothing wrong, yet something on the Windows
2000 client side is preventing correct DHCP configuration, both with and
without any firewall.
Can anyone help, please?
D:\> ipconfig /all
tray.
