E
Elliott Barrere
Hi all,
I've been trying to create an ISO image of Windows 7 for deployment using the Media Content portion of the Deployment Workbench. I have configured an OS, added software and tasklists and everything is fine there. When I try to run Update Media Content however, it fails, claiming it needs more disk space:
Starting MDT Media Update
Opened the media deployment share.
Folders to be copied to the media deployment share: 6
Copied: DS001:\Applications
Copied: DS001:\Operating Systems
Copied: DS001:\Out-of-Box Drivers
Copied: DS001:\Packages
Copied: DS001:\Task Sequences
Copied: DS001:\Selection Profiles
Copied: DS001:\Applications with Replace option
Copied: DS001:\Operating Systems with Replace option
Copied: DS001:\Out-of-Box Drivers with Replace option
Copied: DS001:\Packages with Replace option
Copied: DS001:\Task Sequences with Replace option
Copied: DS001:\Selection Profiles with Replace option
Copied standard folders.
Boot images updated.
Setting up x64 boot image.
Boot configuration editing completed.
Reset read-only attributes.
Starting: "C:\Program Files\Windows AIK\Tools\AMD64\OSCDIMG.EXE" -u2 -m -o -h -b"C:\Program Files\Windows AIK\Tools\PETools\amd64\boot\ETFSBOOT.COM" "E:\Windows 7 Deployment\Content" "E:\Windows 7 Deployment\Windows 7 Deployment.iso" > "C:\Users\ELLIOT~1.BAR\AppData\Local\Temp\Update-MDTMedia.3400\Update-MDTMedia-91126.log" 2>&1
Exit code = 1
OSCDIMG 2.55 CD-ROM and DVD-ROM Premastering Utility Copyright (C) Microsoft, 1993-2007. All rights reserved. Licensed only for producing Microsoft authorized content. Scanning source tree Scanning source tree complete (3013 files in 531 directories) Computing directory information
Computing directory information complete Image file is 6225395712 bytes (before optimization) Insufficient disk space for E:\Windows 7 Deployment\Windows 7 Deployment.iso (need 6225395712 bytes)
Scanning source tree (500 files in 57 directories)
Scanning source tree (1000 files in 214 directories)
Scanning source tree (1500 files in 257 directories)
Scanning source tree (2000 files in 439 directories)
Scanning source tree (2500 files in 464 directories)
Scanning source tree (2899 files in 500 directories)
Scanning source tree (3000 files in 519 directories)
All content was copied to the media directory, but the ISO generation was not successful. This might be due to insufficient disk space at the target path External Drive.
The thing is, the external drive has tons of space! (see the screenshot here , even the Local C: drive has enough space to house the image)
Anybody seen this before? Any idea what to do to fix it??
Thanks in advance!
Cheers,
-elliott-
Exit code = 1
Thanks in advance!
Cheers,
-elliott-
