Guest Orlando J. Rodriguez Posted January 23, 2012 Share Posted January 23, 2012 Hi There! I installed a SCCM 2007 R3 in a test Windows Server 2008 R2 Domain, I configured without problems all the setting of SCCM 2007, including Software Update Point, State Migration Point and so on. I tried to test the process of refreshing a Windows XP Machine to Windows 7, using the Operating System Deployment functionallity of SCCM 2007 R3, WAIK 2.0 is installed in the SCCM 2007 R3 Machine, I can generate a Package of USMT 4.0 without problems. I Generate a Capture Media using the Create Task Sequence Media Option in SCCM 2007, burn it to a CD an use it to capture a Windows 7 image from a reference Computer with a fresh install of Windows 7, this computer is in a Workgroup and have blank local administrator password, then y copy the .wim image to a folder in my SCCM 2007 R3 Server and load as an Operating System Image to the SCCM Server. I created a Task Sequence to Intall an existing Image Package, can Add the Advanced SCCM Client Package and the USMT 4.0 package, after I advertised this task sequence to a Test Computer Collection, the Windows XP computer receive the advertised Task Sequence in seconds when I refresh the Machine Policy Interval. I CLick the advertisement in the Windows XP Machine, and start to Run Without Problems nad capture state of the machine and download some files without problems (I correct the prblem of the NULL Certificate Subject Names applying the correct update on Server an Fixing the certificate on the Windows XP Machine) but in a few seconds the porcess stop and rolled back, because an error. I monitor the advertisement Status, and see that all the first steeps start OK, but when try to excetute the Scanstate the followin error show: The task sequence execution engine failed executing the action (Capture User Files and Settings) in the group (Capture User Files and Settings) with the error code 2147942426 Action output: ssful Building user defined params successful Building USMT command successful Successfully connected to "\\SCCM.UCDOM.LAN\SMPSTOREf_7B3EA745$\7832E390CA301C2A19FDF8BA88E34D1014999431BC23ED77C5796C7CE598FE6B" Executing command line: "C:\_SMSTaskSequence\Packages\S0100006\x86\scanstate.exe" "\\SCCM.UCDOM.LAN\SMPSTOREf_7B3EA745$\7832E390CA301C2A19FDF8BA88E34D1014999431BC23ED77C5796C7CE598FE6B" /o /localonly /encrypt /key: /c /efs:copyraw /all /l:"C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstate.log"progress:"C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstateprogress.log" /i:"C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml" /i:"C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml" Log messages are being sent to 'C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstate.log' Starting the migration process Abnormal Termination. ScanState return code: 26 USMT returned exit code (0x0000001a). Look USMT log file scanstate.log for detail error message. POSDMigrateUserState finished: 0x8007001a. The operating system reported error 2147942426: The specified disk or diskette cannot be accessed. I open the Log Files in the Windows XP Machine I am trying to refreshing to Windows 7, the scanstateprogress.log is empty but the scanstate.log is the following 2012-01-19 09:49:54, Info [0x000000] USMT Started at 2012/01/19:09:49:54.264 2012-01-19 09:49:54, Info [0x000000] Command line: C:\_SMSTaskSequence\Packages\S0100006\x86\scanstate.exe \\SCCM.UCDOM.LAN\SMPSTOREf_7B3EA745$\7832E390CA301C2A19FDF8BA88E34D1014999431BC23ED77C5796C7CE598FE6B /o /localonly /encrypt /key: /c /efs:copyraw /all /l:C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstate.log /progress:C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstateprogress.log /i:C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml /i:C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml 2012-01-19 09:49:54, Info [0x000000] Script file specified: C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml[gle=0x00000002] 2012-01-19 09:49:54, Info [0x000000] Script file specified: C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml[gle=0x00000002] 2012-01-19 09:49:54, Info [0x000000] Starting the migration process[gle=0x00000006] 2012-01-19 09:49:54, Warning [0x08040c] Failed to create SMI engine 2012-01-19 09:49:54, Warning [0x08066d] GAC data store: mscoree.dll is not found. (hr = 0x0000007E) 2012-01-19 09:49:56, Warning [0x080462] CListSysFileFilter::BuildTree: could not create FileList object for C:\_SMSTaskSequence\Packages\S0100006\x86\SFLISTXP.DAT: Win32Exception: \\?\C:\_SMSTaskSequence\Packages\S0100006\x86\SFLISTXP.DAT: El sistema no puede hallar el archivo especificado. [0x00000002] __thiscall UnBCL::FileStream::FileStream(const class UnBCL::String ,enum UnBCL::FileMode,enum UnBCL::FileAccess,enum UnBCL::FileShare,unsigned long) 2012-01-19 09:49:57, Error [0x000000] Unhandled exception: OutOfMemoryException: (no exception message provided) class UnBCL::String __stdcall Mig::pGetDateAndTime(void)[gle=0x00000091] 2012-01-19 09:49:57, Error [0x000000] Unhandled exception, abnormal termination[gle=0x00000091] 2012-01-19 09:49:57, Info [0x000000] USMT Completed at 2012/01/19:09:49:57.608[gle=0x00000006] 2012-01-19 10:34:30, Info [0x000000] USMT Started at 2012/01/19:10:34:30.335 2012-01-19 10:34:30, Info [0x000000] Command line: C:\_SMSTaskSequence\Packages\S0100006\x86\scanstate.exe \\SCCM.UCDOM.LAN\SMPSTOREf_7B3EA745$\7832E390CA301C2A19FDF8BA88E34D1014999431BC23ED77C5796C7CE598FE6B /o /localonly /encrypt /key: /c /efs:copyraw /all /l:C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstate.log /progress:C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstateprogress.log /i:C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml /i:C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml 2012-01-19 10:34:30, Info [0x000000] Script file specified: C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml[gle=0x00000002] 2012-01-19 10:34:30, Info [0x000000] Script file specified: C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml[gle=0x00000002] 2012-01-19 10:34:30, Info [0x000000] Starting the migration process[gle=0x00000006] 2012-01-19 10:34:30, Warning [0x08040c] Failed to create SMI engine 2012-01-19 10:34:30, Warning [0x08066d] GAC data store: mscoree.dll is not found. (hr = 0x0000007E) 2012-01-19 10:34:32, Warning [0x080462] CListSysFileFilter::BuildTree: could not create FileList object for C:\_SMSTaskSequence\Packages\S0100006\x86\SFLISTXP.DAT: Win32Exception: \\?\C:\_SMSTaskSequence\Packages\S0100006\x86\SFLISTXP.DAT: El sistema no puede hallar el archivo especificado. [0x00000002] __thiscall UnBCL::FileStream::FileStream(const class UnBCL::String ,enum UnBCL::FileMode,enum UnBCL::FileAccess,enum UnBCL::FileShare,unsigned long) 2012-01-19 10:34:33, Error [0x000000] Unhandled exception: OutOfMemoryException: (no exception message provided) class UnBCL::String __stdcall Mig::pGetDateAndTime(void)[gle=0x00000091] 2012-01-19 10:34:33, Error [0x000000] Unhandled exception, abnormal termination[gle=0x00000091] 2012-01-19 10:34:33, Info [0x000000] USMT Completed at 2012/01/19:10:34:33.070[gle=0x00000006] I can´t continue with my test, because I´m Stucked here! I don´t Know what´s happening !!! The SCCM is installed in Windows Server 2008 R2 - X64 & have SAL Server 2008 R2 Full updated, the Boot Image (x86 and x64) are both the default language of SCCM (English) The Windows XP Machine I tried to Refresh is in Spanish LAnguage, the Windows 7 references Machine is in Spanish too ! Can you Help me with a possible solution ? Thanks a Lot Orlando Orlando Rodriguez Continue reading... Quote Link to comment Share on other sites More sharing options...
