R
R. C. White
Hi, Angela.
Please see me earlier message. It sounds to me like you already have IE8
and are trying to install IE7 over it. :>(
> my guess is that his version I'm trying
> to install contains both 32 and 64-bit,</span>
Good guess! See my earlier post - and posts by Bobby and Don.
> and to install the 32-bit (the one I
> don't have now), I need to uninstall 64-bit,</span>
BAD Guess!
As we said before, BOTH versions are installed automatically. You can
choose to run either one (the 32-bit is the default but you can change it) -
or both side by side.
So, no need to uninstall 64-bit. You really can't, anyhow, without
uninstalling 32-bit along with it.
> and then use this download to
> reinstall both. Does that make sense? Sorry if the answer is obvious.</span>
I'm not sure that "obvious" is the word. But just install IE8 on your
64-bit Vista. Then look in TWO locations and you will find the TWO versions
of iexplore.exe: the 32-bit in Program Files (x86) and the 64-bit in
Program Files (without the "x86"). You may think that these two
identically-named files are identical, but they are not. One clue is that
the 32-bit file is 658 KB; the 64-bit version is bigger at 681 KB. You
want - and need - and will automatically get BOTH files "for the price of
one".
> I'd
> just prefer to not do something stupid. : o )</span>
Not stupid. Just hard to understand the way Microsoft does things
sometimes. :^{
Now...When I tried to send the screenshot of both "Help | About..." windows
earlier, I forgot to Attach it. Then I tried to send it in a second
message - which was rejected because it was too big (about 400 KB). So I
cut it down and tried again - and I don't know what happened. My Sent Items
says it was sent, but it hasn't shown up here yet. But you don't really
need it. Just open each of the two versions of IE - either 7 or 8 - and
click Help | About Internet Explorer and look at the Version line to see if
it mentions 64-bit. If it doesn't you are seeing the 32-bit version - which
is the default. If you want to see the 64-bit version, just browse to:
C:\Program Files\Internet Explorer\iexplore.exe and click on it. (And I
just realized that I left the \Internet Explorer out of the paths in my
first message.)
Good luck! Please post back and let us know how it works out for you.
RC
R. C. White, CPA
San Marcos, TX
rc@grandecom.net
Microsoft Windows MVP
Windows Live Mail 2009 (14.0.8089.0726) in Win7 Ultimate x64
"angela g" <angelag@discussions.microsoft.com> wrote in message
news:CC7D7E12-00F8-4181-94A2-C38A83BFC402@microsoft.com...<span style="color:blue">
> Thanks everyone. I did download IE from the links you gave. When tried to
> install, got msg that a newer version was already on my PC. Well, I
> suspect
> they're the same version but anyhow, my guess is that his version I'm
> trying
> to install contains both 32 and 64-bit, and to install the 32-bit (the one
> I
> don't have now), I need to uninstall 64-bit, and then use this download to
> reinstall both. Does that make sense? Sorry if the answer is obvious. I'd
> "Don Varnau" wrote:
><span style="color:green">
>> Hi,
>> In IE> Help> About, what's the version? If 64-bit or x-64 isn't in the
>> About
>> Internet Explorer info, you're running the 32-bit version. When IE8 is
>> installed to a 64-bit system, both 64-bit and 32-bit versions of IE are
>> installed, but the 32-bit version of IE is the default.
>> Anyhow...
>> Windows Internet Explorer 8 for Windows Vista 64-bit Edition or Windows
>> Server 2008 64-bit Edition
>> http://www.microsoft.com/downloads/details...&displaylang=en
>> Hope this helps,
>> Don
>> [MS MVP- IE]
>> news:6B9B9E22-F3AD-4797-B251-5CBA78D713D4@microsoft.com...<span style="color:darkred">
>> > A webex tech support person suggested I might need to run IE 32-bit to</span>
>> access<span style="color:darkred">
>> > a webinar (I have 64-bit Vista Home Premium). I tried to download and</span>
>> install<span style="color:darkred">
>> > 32-bit IE but when I tried to install it I got an error msg saying it
>> > wouldn't run on my PC, apparently because it's 32-bit IE and I have
>> > 64-bit</span>
>> PC.<span style="color:darkred">
>> > Is there a special 32-bit version of IE for 64-bit PCs like mine, and
>> > if</span>
>> so,<span style="color:darkred">
>> > where is the download?
>> > Thank you in advance.</span>
>> </span></span>
BAD Guess!
one".
> I'd
sometimes. :^{
first message.)
RC
R. C. White, CPA
San Marcos, TX
rc@grandecom.net
> suspect
> trying
> I
>> Hi,
>> About
>> Anyhow...
>> Hope this helps,
>> Don
>> [MS MVP- IE]
>> > 64-bit</span>
>> > if</span>
>> </span></span>
