E
eric
Hi haqin, after i copy the following commands and then paste into the Notepad
window,then i close the Notepad window it just prompted do you want to save
change to untitled?save,don't save or cancel.I also try click start,Run,type:
C:\fix.reg and enter the windows cannot find ,make sure you typed the name
correctly.what should i do?
"Haqiu" wrote:
> 1. Click Start, Click Run, type in "notepad C:\fix.reg" (without quotation
> marks) and press Enter. Choose Yes when you are prompted.
> 2. Copy the following commands and then paste them into the opened Notepad
> window.
> Windows Registry Editor Version 5.00
> [HKEY_CLASSES_ROOT\CLSID\{0000031A-0000-0000-C000-000000000046}]
> @="ClassMoniker"
> [HKEY_CLASSES_ROOT\CLSID\{0000031A-0000-0000-C000-000000000046}\InprocServer32]
> @="ole32.dll"
> [HKEY_CLASSES_ROOT\CLSID\{0000031A-0000-0000-C000-000000000046}\ProgID]
> @="clsid"
> [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\CLSID]
> @="{0000031A-0000-0000-C000-000000000046}"
> 3. After you paste the above commands, please close the Notepad window.
> Choose Yes when you are prompted to save the file.
> 4. Click Start and Click Run, type in "C:\fix.reg" (without quotation marks)
> and press Enter to run the commands we have pasted.
> 5. A dialog box will pop-up saying "Are you sure you want to add the
> information in C:\fix.reg to the registry?". Click Yes on this dialog box
> 6. Reboot the machine.
> 7. After the machine reboots use Windows Update and see if the problem has
> gone away.
> "Aldaran" wrote:
> > Hello
> > If youy want to resolve 0x8DDD0004 error code try to install Microsoft
> > Internet Explorer 7 Beta 2 Preview ...
> > It works for me!
> > Good luck
> > Aldaran
> window.
> @="ClassMoniker"
> @="ole32.dll"
> @="clsid"
> gone away.
> "Aldaran" wrote:
> > Hello
> > It works for me!
> > Good luck
> > Aldaran
