Tokyomods Less Tension Throttle Spring
grunt58
  • Replies 21
Posted Images
I just cut the stock spring. You can also try a trx 90 lever as well they are slightly longer.
Just make sure you use the 04/05 450r throttle. I think it works on the 400ex throttle also.
http://www.offtopic.forum/data/MetaMirrorCache/fd3b0f2c0d7ce24057c01e9a7e667bc6.jpg
HUNG RACING, MSR RACING, RATH RACING, HOUSER RACING, JT SPROCKETS, HIPER TECHNOLOGY, HINSON RACING, STIFF BRAND CLOTHING,and CYCRA RACING.
Link to comment
Share on other sites
I had a ligth spring put on my by Sredrum when he did my carb, not sure the brand, but ilove it
http://www.offtopic.forum/data/MetaMirrorCache/06f1a7ba567102d307e3f721efc437ad.jpg
Zorros racing..
#123A - Baja 500, 2014 FINISHER !!!
Subscribe to us on FB http://www.facebook.com/zorros.rt
http://www.offtopic.forum/data/MetaMirrorCache/91c75944b97d47249f183869c9875a9e.gif
http://www.offtopic.forum/data/MetaMirrorCache/5639c3ecf3b34b1f1e26b660950f9785.gif
Join the http://www.Marines.com travel to exotic lands, meet exciting unusual people and kill them..
Link to comment
  • 2 weeks later...
Went ahead and bought it, figure for $30 it was worth a try. Not saying a spring is worth $30, price is ridiculously high for what it is.
Any tutorials on installing it? I found this for relocating the spring mount pretty much the same process I'd assume minus the drilling.
http://www.trx450r.org/forum/118-engine-tech-faq/155461-fcr-throttle-spring-mod.html
Link to comment
  • 3 weeks later...
So got the spring, pulled the carb, installed the spring went to tighten up the "Flat CR" cap and the casting broke. I think the cap was cocked and when I snugged it up it snapped. I blame myself wasn't being careful just wanted to get it done. This $30 job just got expensive. I don't think I have any other choice but to get a used carb. Unless someone has a great solution....?
With that said anyone selling a 08 450er carb or know a good place to get a used one? Found a few on ebay but they are a little high.
[ATTACH]621.vB[/ATTACH]
Link to comment
  • 4 weeks later...
Got the cap fixed and have it put backed together. But to start it and have it stay idling I have to push on the thumb throttle just a bit. I think one of the sensors is being triggered or not being triggered. I just need to push it till it clicks up at the thumb throttle and it starts and idle as normal. If I let off the throttle it basically cuts out as opposed to stalling. Any thoughts on what to adjust?
08 450er
Thanks
Link to comment
Do you have proper free play in the throttle cable? Should be able to feel a little slack in the cable. That however would be kinda backwards from your problem but you never know.
That or the hotstart cable got messed up and it's pulling when it shouldn't be?
How about the pilot screw? Can you tune it out with that?
Also the simple - no cracks in the boots or exhaust leaks?
2004 Honda Trx450Riot Kicker
Dasa
K&N
Motul
Kenda
Pro Taper
Motion Pro
Streamline
Blingstar
Link to comment
Turned the idle knob up till it was reving high when running let off the throttle and it cut out. Tried to start and it would not fire up till I pushed the throttle in a bit. Then reved high as expected turned it down same thing. I think it is the sensors not sure how to check though. I'll recheck the cable slack. Right not its about 5mm of free play at the throttle, see if I can get more out of it.
Link to comment
the throttle cable is too tight and is holding the slide open every so slightly. there is a little micro-switch under the plastic cover to the carb. has nothing to do with idle adjustment. just adjust the throttle cable at the carb for a lil more slack and she'll fire right up :gr_cool:
Stock Bore, Stock Stroke, Pump Gas, and Kicking Ass
TEAM JUNK RACING #224
Link to comment
