Hey all,
I'm curious to see what you have as a set up for a walk in door for security purposes... Sometime last night or this morning, my garage door was busted wide open. Look like it was kicked and the door is sorta ****ed up now. The hinges are out of place and the lock didn't do ****.
Well, you cant argue with the law of physics. Pretty much any structure with weakest parts will break with enough force or pressure is applied.
I did what i could do for now with a temporary fix. New LONGER screws in the hinges and reinforced the door lock with a temporary fix. I did that by putting some small boards between the door frame and the jack studs. All this just so that i can open and close the door till i do something. However, now it's easy to slide a credit card through and push the locked door open. I'm still searching around to see if anything is stolen. Far as i can see, it looked like both of my wheelers were moved! Good thing they couldn't take both because i had a bunch of **** in front of them. On top of that both of the sliding garage doors are pad locked to the garage's structure. I have to do some more searching around. I havnt because i'm still pissed and cant think straight at this point. I am sleep deprived from insomnia problems and dealing with summer flu.
IF you have a good set up to prevent from a break in again... POST! i'd love to read it and brain storm a few ideas what i can do about my situation. The police wont do ****.... I know i will have to buy a new door, hinges, metal lock reinforcer, and dead bolts.
PS: Ed's right i have the worst luck nowadays :/ something is out to get me or something.
