Intelligent Design: Required by Biological Life?
Guest Patriot Games
February 19, 2008
K.D. Kalinsky
I. Introduction:
This article is meant to stimulate thought and discussion. As that
discussion unfolds, I
expect that this article will be revised over time in the same way that a
paper submitted to
a journal is often revised during the process of review. The purpose of this
article is to
attempt to bring some clarity to the discussion of intelligent design and
the origin and
diversity of biological life. Essentially, we have two options. Either
biological life
required intelligent design or it did not. As with most problems in science,
it is difficult to
prove one option or another with absolute certainty. Instead, options can be
evaluated
against each other in an attempt to estimate which option is more likely.
Even then, the
fact that one option may be more likely than another does not 'prove' that
it is actually the
case. Instead, I will propose a way in which both options can be evaluated
against each
other. The results indicate that it seems highly likely that intelligent
design was required
for biological life.
II. Defining some terms and concepts
There is considerable confusion over what intelligent design is. Indeed, the
concept is
often used in different ways. It is sometimes used to describe a cause and
other times
used to describe an effect. For example, someone can ask if a laptop
computer requires
intelligent design or they can ask if it is an example of intelligent
design. In the first use,
'intelligent design' is being used in the causal sense; it is a necessary
cause for a laptop
computer. In the second use, it is being used as a result or effect;
intelligent design is the
result of a prior cause, presumably a mind. For the purpose of this article,
I will treat
intelligent design as an effect. In other words, the question, 'does this
laptop computer
require intelligent design?, can be replaced by the question, 'is this
laptop computer an
example of intelligent design?' Of course, if one is inclined to be more
exhaustive in their
definitions then, as is often the case in lexicons, two or more definitions
or senses of the
term can be offered.
If we take intelligent design to be an effect, then we can define it as an
effect that
requires a mind. If we take intelligent design to be causal, then we can
define it as the
process of producing an effect that requires a mind. Since the common
denominator in
both uses is an effect that requires a mind, I will define intelligent
design as follows:
Intelligent Design: an effect that requires a mind.
It follows from this that a necessary requirement for intelligent design is
a mind. Of
course, natural processes could also be necessary as well but, in this case,
insufficient to
produce the effect. Thus, at the very least, intelligent design requires a
mind but may also
require natural processes as well. In other words, natural processes may be
necessary for
intelligent design, but they are not sufficient; a mind is also necessary.
The other option is
the hypothesis that intelligent design is not required for a given effect.
This second option
must assume that natural processes are not only necessary to produce the
effect, but they
are also sufficient. A mind is not necessary. Thus, to be perfectly clear,
this second option
entails that mindless natural processes are necessary and sufficient to
produce the given
effect.
To illustrate the two options, let us imagine that the SETI Institute
obtains a signal from
outside the solar system that contains the first 50 prime numbers. If they
were to conclude
that it was more likely that a mind would be necessary to produce the signal
than that
mindless natural processes were sufficient to produce the phenomenon, then
the signal
would be a possible example of intelligent design. It would only be a
possible example,
due to the nature of scientific investigation; we could not be certain. No
matter how
improbable, it is still logically possible that the signal could have been
generated by
mindless natural processes. The best we could do is to weigh the probability
that a mind
could produce such a signal against the probability that mindless natural
processes could
do it and draw a conclusion as to which option was more likely. We know that
a mind
can generate the first 50 prime numbers, so the probability that a mind
could produce that
information is 1. If the probability that natural processes could generate
the first 50 prime
numbers is less than 1, then one can compare the two probabilities to decide
how much
more likely intelligent design is than mindless natural processes. If it
turns out that
intelligent design is ten times more likely, or a thousand more times more
likely, then it
becomes increasingly irrational to invoke mindless natural processes, and
increasingly
rational to invoke intelligent design.
Causal Hypothesis: For any effect, either mindless natural processes are
sufficient to
cause the effect, or a mind is required.
The problem arises in estimating which of the two options is more likely. We
need
something that we can use to distinguish between examples of intelligent
design and
mindless natural processes. One possibility is the following hypothesis:
Intelligence Hypothesis: an attribute that distinguishes a mind from
mindless natural
processes is the ability of a mind to produce effects requiring significant
levels of
functional information.
The above Intelligence Hypothesis allows that mindless natural processes can
accidentally produce functional information within, say, the background
noise of a
physical system, but the information will not achieve a significant level.
It also allows for
the fact that a mind can mimic mindless natural processes by producing
effects that do
not require a significant level of functional information. We are left with
the following
questions:
1. How is functional information measured?
2. What constitutes a significant level of functional information?
Before we look at these questions, we will take a brief look at the role of
intelligent
design in science.
III. The role of intelligent design in science
Intelligent design plays an important role in at least three areas of
science, including
intelligent design detection, reverse engineering, and applied design (e.g.,
human
intelligence applied to experimental design). In this section, I shall limit
the discussion to
the role of intelligent design detection in science. Intelligent design
detection can be
defined as follows:
Intelligent design detection: the discipline of examining an effect and
determining if
it is an example of intelligent design.
An area of science where intelligent design detection is front and center is
in the SETI
Institute's ongoing search for extra-terrestrial intelligence. Radio and
optical signals from
deep space are monitored and analyzed to determine if the signal may have
come from an
extra terrestrial intelligence or not. Intelligent design detection is also
important for
archeology, where a distinction must be made between artifacts and effects
due to natural
processes. For example, ground penetrating radar can be used to search for
ancient
building sites and artifacts. The results must be continually analyzed to
determine if what
is being seen by radar is the result of mindless natural processes, or the
product of
intelligent design. Intelligent design detection is also central to forensic
science, which
concerns itself with whether the crime was carried out by an intelligent
agent, in this
case, human, or was due to natural causes. With advances in genetics and
cell biology,
and the discovery of molecular machines, molecular computers and functional
sequence
complexity encoded in the genomes of life, intelligent design detection has
now become
necessary in biology. Furthermore, the J.Craig Venter Institute's creation
of a synthetic
M. genitalium genome presents us with a genome that is known to have been
built by
intelligent design, and that contains five 'watermarks'.1 Strictly speaking,
it is the
'watermarks' that are known to be a result of intelligent design. Some have
asserted that
intelligent design has no place in science, but of course intelligent design
detection is
firmly entrenched and essential to SETI, archeology, and forensic science.
Those who
insisted that ID has no place in biology will have to admit that now that
synthetic
genomes are being constructed, with 'watermarks', intelligent design
detection is now an
issue in biology as well. The job of science is to come up with a general,
scientific
approach to intelligent design detection. One possible approach that has the
potential of
being general enough to be applied to SETI, archeology, forensic science,
and biology is
suggested by the Intelligence Hypothesis: examine the functional information
required to
produce the effect and then to decide if it is more likely than not that
intelligence was
required to produce that degree of functional information.
1 http://blog.wired.com/wiredscience/2008/01/venter-institut.html
IV. Functional Information
The Intelligence Hypothesis suggests that intelligence can produce effects
that require a
significant amount of functional information. To proceed, we need a method
to measure
functional information and, second, we need to decide what constitutes a
significant level
Measuring functional information
A method to measure functional information has recently been published by
Hazen et al.
whereby functional information is defined as
I(Ex) = - log2[M(Ex)/N] (1)
where Ex is the degree of function x, M(Ex) is the number of different
configurations that
achieves or exceeds the specified degree of function x, ? Ex, and N is the
total number of
possible configurations.2 To illustrate, suppose we inherit grandfather's
safe that has a
combination lock that requires three numbers, each within the range of 0 to
99. Since
each number has 100 possibilities, and there are three numbers, N = 1003 =
1,000,000
possible combinations. Let us suppose that the mechanism has a little slop
to it such that
one need only get within 1 digit of each of the three numbers. In other
words, for each of
the three numbers in the combination, there are actually three functional
options.
Therefore, the total number of functional combinations that will open the
safe is M(Ex) =
33 = 27 functional combinations. The amount of functional information
required to open
grandfather's safe is therefore
I(Ex) = - log2[27/1,000,000] = 15 bits of functional information.
As Hazen et al. point out, 'functional information quantifies the
probability that, for a
particular system, a configuration with a specified degree of function will
emerge', where
the probability is denoted by M(Ex)/N. Strictly speaking, the probability
that Hazen et al.
speak of is the probability Pf of achieving the function in a single
sampling, or
Pf = M(Ex)/N. (2)
As more trials are attempted, the probability of achieving the function
improves.
Estimating Isig
This raises the second question; what constitutes a significant level of
functional
information (Isig)? The Intelligence Hypothesis suggests that the attribute
that
distinguishes intelligence from mindless natural processes, is the ability
to produce
significant levels of functional information. Mindless natural processes can
accidentally
produce effects requiring a low level of functional information. For
example, if we were
2 Hazen, R.M., Griffen, P.L., Carothers, J.M. & Szostak, J.W. (2007)
'Functional
information and the emergence of biocomplexity', PNAS 104, 8574-8581.
to move grandfather's safe down to the riverbank, and attach a water driven
turbine to the
dial, and install the turbine in a turbulent portion of the current, where
the turbine could
be turned either direction by the current, it is possible that, after a long
enough time, the
variable current may actually open grandfather's safe. Of course, the number
of trials may
vastly exceed 1,000,000 if the same combinations are mindlessly tried more
than once.
Recall, as Hazen et al. point out, that probability is at the core of the
equation to measure
functional information. We must establish a relationship between the number
of trials
mindless natural processes have for the particular problem, and Pf.
A search by mindless natural processes is essentially a random walk, where
the search
proceeds in no set direction and, for any point in the search, it can be
returned to any
number of times. This is not to be confused with an evolutionary search that
is directed
by a fitness function or a fitness landscape, which will be discussed later.
We must first
establish Isig for a mindless natural search. In such a search, the
probability that a given
sampling will not be successful is 1 - Pf. For a search involving R trials,
the probability
that it will not be successful is (1 - Pf )R. Therefore, the probability
that the search will be
successful is simply 1 - (1 - Pf )R. Let us assume that a search will be
successful if the
search performs enough trials to raise the probability of success to 0.5, or
0.5 = 1 - (1 - Pf )R.
Simplifying, we get
Pf = 1-(1-0.5)1/R (2)
Eqn. (2) gives us an estimate for the most improbable functional event that
a blind search
could reasonably expect to find, given R trials. That being the case, the
highest level of
functional information that natural processes could reasonably be expected
to produce for
a given function would be the case where only one functional configuration
would
reasonably be found in R trials, or
Inat = - log2[1-(1-0.5)1/R]. (3)
The requirement for Isig is that it must be greater than Inat. For example,
if the turbine
method of trying to open grandfather's safe was capable of 500,000 trials
before the
system wore out, then the turbine-safe system could reasonably be expected
to produce as
much as 13 bits of functional information (Isig = 13 bits). Since a
requires 15 bits of functional information, one could not reasonably expect
the turbine
system to open the safe without any intelligent design so far as finding the
right
combination is concerned. Therefore, if such a system were built and the
safe
successfully opened, we could on reasonable grounds accuse the engineer of
having
biased the system to find the right combination, for the physical system was
unlikely to
have done it without any intelligently designed bias built in. Due to the
nature of
probability, however, it is possible that the river current could open
grandfather's safe on
the very first try, or it might never open the safe. It is also possible
that the engineer did
not build in an intelligently designed bias to find the right combination,
we were just
fortunate. We could never be absolutely sure, therefore, whether there was a
built in
intelligently designed bias or not. Since at the core of functional
information is
probability, we can never arrive at a definitive conclusion, only a likely,
probable, or
plausible conclusion. This leads to the following considerations.
Probability considerations
1. Inat is not a cutoff for the amount of functional information natural
processes can
produce. Rather, the probability that natural processes can produce x amount
of
functional information decreases exponentially as the amount of functional
information increases beyond Inat. For example, if Inat = 32 bits of
functional
information, using Eqn. (1), this corresponds to a probability of
approximately 10-10
whereas 64 bits of functional information corresponds to a probability of
approximately 10-19. In other words, 64 bits of functional information is
only twice as
much information as 32 bits, but one billion times more difficult to find in
a search.
2. Our observations indicate that there does not seem to be any known limit
to the
amount of functional information that intelligence can produce. It seems to
be capable
of producing anywhere from 0 bits and up.
3. In view of the previous two points, we can only speak of the likelihood
that an effect
required intelligent design, where the greater the difference between the
functional
information required for the effect and Inat, the more likely it is that
intelligent design
was required. This would hold true for SETI, archeology, forensic science,
and
biological life.
Method to gauge the likelihood of intelligent design
Given that there is no known upper limit for the amount of functional
information a mind
can produce, for any effect requiring or producing functional information,
intelligent
design is the more likely explanation if
I(Ex) > Inat. (4)
The greater the difference between I(Ex) and Inat, the more likely it is
that intelligent
design was required. It will be assumed, for simplicity, that the
natural processes can achieve Inat is 1 and decreases probabilistically for
I(Ex) > Inat. The
probability that intelligent design can achieve I(Ex) will be assumed to be
1 for any finite
amount of functional information. This is a reasonable assumption, given our
observations of what intelligence can do and the apparent absence of any
upper limit.
This method can, in principle, be applied within the fields of forensic
science,
archeology, SETI, and biology, as well as in areas outside of science, such
as lottery
gaming investigations, plagiarism investigations, and the justice system, to
name a few.
V. Application to Biological Life
Now that we have a method to identify examples of intelligent design, we are
now
equipped to apply it to biological life to see what the likelihood is that
it was designed.
We shall first discuss the relationship between natural selection and
functional
information. We will then derive a generous estimate of Inat for an
evolutionary search.
We shall then estimate I(Ex) for several test cases and, applying the method
suggested in
the previous section, see if it is likely that biological life is an example
of intelligent
design.
Natural selection, fitness functions, and functional information
It is usually assumed that the origin and diversification of life is not a
blind search.
Actual mutations, insertions, deletions, and genetic drift may be chance
events, but
natural selection essentially guides the search and, hence, the search is
not blind. On the
one hand, it is assumed that natural selection explains how life could
appear and diversify
without requiring any intelligence, but on the other hand, terms that that
are usually
applied to intelligence, such as 'design' and 'selecting' are commonly
applied to natural
selection. It is very common to read articles where the author marvels at
what natural
selection is capable of. Of course, this raises the question, does natural
selection, itself,
require intelligent design? The fatal mistake made by many who appeal to
natural
selection is the assumption that natural selection, itself, does not require
intelligent
design. It is bad science that does not test its assumptions, so we must
apply intelligent
design detection to natural selection itself.
Although natural selection is credited with somehow discovering the right
combination of
nucleotides to code for, say, proteins like SecY or RecA, there is a great
deal of
vagueness about how it actually is supposed to do this, and not just for two
proteins, but
for thousands. Not only must it somehow locate the proper sequences that are
determined
a priori by physics that will produce a stable 3-D structure, but it must
also be able to
assemble the information that will produce more impressive things like
molecular
machines, molecular computers and, ultimately, the cell and the organism
itself.
Fortunately, the field of genetic algorithms or evolutionary algorithms can
be used to
introduce rigor to the concept of natural selection.
Every evolutionary search process, whether we are discussing natural
selection, or a
computational evolutionary algorithm, requires a fitness function. Without a
fitness
function, the search degenerates into a blind search, at best. The fitness
function can be
defined as follows:
Fitness function (evaluation function): represents "the requirements to
adapt to. It
forms the basis for selection, and thereby it facilitates improvements. More
accurately, it defines what improvement means. From the problem-solving
perspective, it represents the task to solve in the evolutionary context."3
Since the fitness function, whether it is found in nature, or in a genetic
algorithm, must
contain the requirements to adapt to, or that defines the desired outcome,
it must contain
at least as much functional information as the desired outcome. If the
functional
information contained in the fitness function is less than the functional
information
required for the desired outcome, then the deficit must be made up for in a
blind search,
which falls prey to the probability problems that emerge.
Natural selection requires a fitness function. If a given protein is a
product of natural
selection operating within a fitness landscape, then sufficient functional
information
required to find that protein in an evolutionary search must be encoded
within the fitness
function. If a few hundred, or several thousand proteins are required, then
a great deal
more functional information must be encoded within a much more complex
fitness
function. If molecular machines are also desired, then additional functional
information
must be included within the fitness function.
No one actually knows where this amazing fitness function is in nature such
that we can
measure the amount of functional information that it contains. However, if
we assume
that natural selection is responsible for, say, the origin of gene coding
proteins, then we
can estimate the amount of functional information the fitness function of
nature contains
by measuring how much functional information a given protein requires. We
are then in a
position to see if intelligent design is required for natural selection to
produce the given
protein by comparing the degree of functional information that must be
encoded within
the fitness function of nature and comparing it with Inat. Intelligent
design detection
methods must be applied to natural selection to see if intelligent design is
required to
encode the appropriate amount of functional information into the fitness
function of
natural selection. There is no escape; the functional information within a
fitness function
must be measured and evaluated, and a test performed to see if it requires
intelligent
design.
For example, if an evolutionary algorithm is attempting to produce even more
complex
software commands, then the fitness landscape includes the operating system
within
which those commands will survive or fail and the functional information
required to
produce that operating system must be measured. If the fitness function is
outside the
actual algorithm, say within a database, then the functional information
contained in the
database must also be included. To summarize; if natural selection or a
fitness function
are credited with producing a given amount of functional information, then
if that
functional information exceeds Inat, by the method proposed in this article,
ID is required
to properly configure the fitness function.
Estimating Inat:
3 Eiben, A.E. & Smith, J.E. (2003) Introduction to Evolutionary Computing,
Springer-
Verlag Berlin Heidelberg, 19.
It is estimated that there may be somewhere between 500 and 900 different
protein
folds,4,5 that form roughly 4,000 to 7,000 different protein families.6 The
stable folds are
determined by physics, not biology. This requires that any evolutionary
process must
perform a search of sequence space to locate those areas where physics
produces a stable,
3-D structure. Origin of life theorists are not decided as to what processes
could lead to
the minimal genome. Regardless of whether one prefers a genetic approach or
a
metabolic approach, we do know that at some point, proteins must be
produced, or at
least the information coding for stable, folded proteins must be achieved.
We can,
therefore, take all origin of life scenarios and put them into a 'black box'
which performs
an evolutionary search and outputs the stable folded proteins that are
permitted by
physics. It is not necessary to know what the processes within this black
box do, all we
need to know is the output. The output can be evaluated two ways, one way is
to assume
that the black box is performing a blind search which, of course, requires
no intelligent
design, and the other way is to assume that some sort of fitness function is
operating
within the black box which may or may not require intelligent design,
depending upon
how much functional information is required for the output. To estimate Inat
for a prebiotic,
origin of life search, we must estimate the number of trials available for a
blind
search. We will then be in a position to estimate Inat and compare it with
the functional
information required to produced a minimal genome to see if a fitness
function would be
necessary that would require intelligent design. Since we do not know what
processes
could perform the search, let us be extremely generous.
Taylor et al. have estimated that the mass of the earth would equal about
1047 proteins, of
100 amino acids each.7 If we suppose that the entire set of 1047 proteins
reorganized once
per year over a 500 million year interval (about the estimated time period
for pre-biotic
evolution), then that search permits about 1055 options to be tried. Using
Eqn. (3), Inat ?
185 bits of functional information. Of course, this scenario is much more
generous than
any scenario under consideration, but at least we will not be
underestimating Inat. If I(Ex)
requires more than Inat, then we can assume that either a fitness function
requiring
intelligent design must be included in the black box, or intelligent design
is operating in
some other fashion to properly encode the functional information.
We are now ready to examine four test cases.
Case One: the Venter Institute's synthetic genome for M. genitalium:
4 Taylor, W. (2002) 'A periodic table for protein structures', Nature, 416,
657-660.
5 Zhang, C. & DeLisi, C. (1998) 'Estimating the number of protein folds',
JMB, 284,
1301-1305.
6 Wolf, Y., Grishin, N. & Koonin, E. (2000) 'Estimating the number of
protein folds and
families from complete genome data', JMB 299, 897-905.
7 Taylor, S., Walter, K., Kast, P. & Hilvert, D. (2001) 'Searching sequence
space for
protein catalysts' PNAS 98, 10596-10601.
The five 'watermarks' in the synthetic Venter genome are formed by choosing
base pairs
that, when translated into amino acids and using the amino acid single
letter symbols,
spell out the following five words:
VENTERINSTITVTE
CRAIGVENTER
HAMSMITH
CINDIANDCLYDE
GLASSANDCLYDE.
Hazen et al. point out that the number of functional options can vary
according to the
degree of efficiency required by the system. This is true for both human
languages and
biopolymer sequences. In this case, however, we will assume that the Venter
Institute
wants their watermarks correctly spelled according to the above sequences.
Given that
there are 20 options for each site in each word, using Eqn. (1), I(Ex) = 259
bits of
functional information. Since Inat has been estimated at 185 bits of
functional
information, I(Ex) > Inat. These results indicate that it is about 1022
times more probable
that the watermarks required ID than that they could be produced by mindless
natural
processes. Therefore, by the method proposed here, we can conclude that the
'watermarks' are likely produced by ID, in this case, the Venter Institute.
Case Two: a folded, functional protein domain:
Axe has estimated that the frequency of occurrence of stable, folded
functional protein
domains, a structurally independent component of a protein, is somewhere
between 10-64
to 10-77.8 These values correspond to M(Ex)/N in Eqn. (1). The functional
information
required, therefore, to code for a stable, folded protein domain is 213 to
256 bits. Since
we have estimated Inat at a generous 185 bits, which is much too low to
achieve the
amount of functional information required to produce a folded, functional
protein
domain, I(Ex) > Inat and it is at least 1019 times more probable that ID can
produce a
folded functional domain than mindless natural processes. The method of ID
detection
proposed in this article, therefore, reveals that ID is highly likely to be
required to
produce folded, functional protein domains. If the sequences coding for a
stable fold are
the product of a pre-biotic black box that contains a fitness function, then
the fitness
function will require intelligent design.
Case Three: an average 300 amino acid protein:
The functional information required to produce an average, 300-amino acid
protein, can
be estimated by analyzing the set of aligned sequences for SecY and RecA.
These two
proteins are particularly interesting because they are also universal
proteins, found
throughout organic life. It is inferred, therefore, that they would be
required in a minimal
genome. Analyzing a set of 1,553 aligned sequences for RecA and 469 aligned
sequences
8 Axe, D. (2004), 'Estimating the prevalence of protein sequences adopting
functional
enzyme folds', JMB, 1295-1315.
for SecY reveals that 832 bits of functional information are required for
RecA and 688
bits for SecY.9 It is reasonable, therefore, to estimate the functional
for the average 300 amino acid protein to be around 700 bits of information.
I(Ex) > Inat
and ID is 10155 times more probable than mindless natural processes to
produce the
average protein. Again, if natural selection is invoked to explain the
origin of proteins, a
fitness function will be necessary that requires intelligent design.
Case Four: the simplest life form:
It is estimated that the simplest life form would require at least 382
protein-coding
genes.10 Using our estimate in Case Four of 700 bits of functional
for the average protein, we obtain an estimate of about 267,000 bits for the
simplest life
form. Again, this is well above Inat and it is about 1080,000 times more
likely that ID could
produce the minimal genome than mindless natural processes. Again, if one
wishes to
explain the origin of the simplest life form by natural selection, a fitness
function will be
required that is capable of generating 267,000 bits of functional
information, well into the
area that requires intelligent design.
VI. Conclusion:
In this article, I have proposed a method for the detection of intelligent
design. Applying
that method to the Venter 'watermarks' in their synthetic genome, the method
successfully
identifies the watermarks as highly likely to require ID. The same method
applied to
protein domains, average proteins, and the minimal genome, also indicates
that ID is
required for even the simplest life form. If life is the product of natural
selection and an
extremely complex fitness landscape, then we can conclude that it is
extremely likely that
intelligent design was required to configure the fitness function. Whether
there actually is
such an impressive fitness function encoded in nature is outside the scope
of this
discussion. I have not proved that intelligent design was required for
biological life.
Instead, I have shown that given intelligent design is easily capable of
generating
functional information on the level of what is required for biological life,
and given that
the functional information required for biological life is far beyond what
we could
reasonably expect nature to generate, intelligent design is the most
probable explanation,
by many orders of magnitude, for biological life. Intelligent design would
also be the
most probable explanation for any fitness function operative in natural
selection that
could successfully locate the folding proteins required for life.
9 Durston, K., Chiu, D., Abel, D. & Trevors, J. (2007) 'Measuring the
functional sequence
complexity of proteins', Theoretical Biology and Medical Modeling, 4:47.
10 Glass, J., Assad-Garcia, N., Alperovich, N., Yooseph, S., Lewis, M.,
Maruf, M.,
Hutchison III, C., Smith, H., & Venter, J. (2006) 'Essential genes of a
minimal bacterium'
PNAS, 103, 425-430.
There is nothing intelligent in nature. Animals eat other animals to
survive. Is that intelligent? Why are there thousands of diseases and
serious body malfunctions, is that also intelligent? Why is earth the
ONLY planet supporting life out of billions of other planets? An
intelligent designer would have done a better job.
Guest jimp@specsol.spam.sux.com
Just the other day you were claiming animals made ideal communists.
So are you now saying you have to be unintelligent to be a communist?
Jim Pennino
Remove .spam.sux to reply.
Guest L. Raymond
uri wrote:
> Why is earth the
How do you know there is no life in all the universe except on Earth?
What's your evidence for this?
L. Raymond
There are only two realistic options to consider. 1) Life was created
exclusively on this planet by God. 2) Life has formed on many planets
spontaneously. If the second option is true then there must be other
life somewhere in the universe.
http://www.thekeyboard.org.uk/Extraterrestrial%20life.htm
Guest Rev. Karl E. Taylor
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Very good, you figured it out. Number 2 is factual based on the
enormous size of the universe and the probability of life evolving with
in that vastness.
So much for the concept of gods.
There are none more ignorant and useless,
than they that seek answers on their knees,
with their eyes closed.
____________________________________________________________________
Rev. Karl E. Taylor http://www.jesusneverexisted.com/
~ http://azhotops.blogspot.com/
A.A #1143 http://scienceblogs.com/aardvarchaeology/
Apostle of Dr. Lao EAC: Virgin Conversion Unit Director
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFICj8vf+wl0F6+jvgRAl7eAKCLoW3uTL1AhN/hpxCDJQRKBmDVbACfWtYz
n7y7X5+BBwKpclpnto5fN/0=
=WenC
-----END PGP SIGNATURE-----
Guest Free Lunch
On Sat, 19 Apr 2008 11:41:31 -0700 (PDT), in alt.atheism
uri <danny99@bezeqint.net> wrote in
<c077a300-b4c0-47fe-a61c-4908f0e16179@2g2000hsn.googlegroups.com>:
Must? Why?
It seems very likely that there is life on many planets, but you have
created a false dichotomy.
Guest L. Raymond
You should have randomly capitalized and/or misspelled some words, but
other than that you do a good job of satirizing the scientifically
illiterate creationists.
L. Raymond
3) The conditions required for life to form are rare and life hasn't
formed anywhere else.
4) The conditions required for life to form are uncommon and life has
formed in a few places.
5) The conditions required for life to form are common and life has
formed in many places.
If you want to posit an all powerfull God:
6) God saw the results of creating life on Earth, i.e. Uri, and gave
up on creating life as a bad idea.
7) God saw the results of creating life on Earth, i.e. Uri, and tried
something different elsewhere.
Jim Pennino
Guest I never proof-read my posts.
Intelligence arises from components that lack intelligence. The brain
is made up of atoms. Each atom lacks intelligence. Since
intelligence can arise from the unintelligent, any data that indicates
intelligent design could also be the result of a very complicate
system of unintelligent components producing that data.
Guest BradGuth
Intelligent design is not without its mistakes or unfortunate
mutations, like the one which created "uri".
.. - Brad Guth
Guest BradGuth
On Apr 19, 12:13 pm, Jerry Kraus <jkraus_1...@yahoo.com> wrote:
> > February 19, 2008
> Psychotic morons aren't in the best position to claim "intelligent
> design", Patriot. Bear it in mind.
And your supposed better standard for intelligent design is????
.. - Brad Guth
Guest BradGuth
On Apr 19, 12:49 pm, lorad...@cs.com wrote:
> > February 19, 2008
> > K.D. Kalinsky
> > I. Introduction:
> > paper submitted to
> > article is to
> > the origin and
> > biological life
> No... that's wrong from the get go.
> Biological life requires organization ... repeatable bio-chemical
> interactive outcomes from the molecular level on up.
> Where that organization came from should be the matter under dispute
> dispute.
> PS: Human origins: The extremely large percentage (compared to other
> species) of 'junk DNA' in homo-sapiens should prove to be extremely
> interesting for any adherent of intelligent design..
That's very good logic. Too bad this mostly anti-think-tank Usenet of
such a Semitic faith-based ideology that's clearly intent upon global
domination, as such isn't the least bit interested, much less in
allowing whatever truths that could materialize.
.. - Brad Guth
Guest BradGuth
On Apr 20, 1:45 am, "I never proof-read my posts."
How do we know that atoms don't have a form of intelligence?
How about photons, gravitons and of all the other weird black stuff of
our vast and supposedly forever expanding universe; is it all w/o
intelligence?
.. - Brad Guth
Guest Patriot Games
"Jerry Kraus" <jkraus_1999@yahoo.com> wrote in message
news:acf40223-a821-41ef-b61f-b2343afc78a0@e39g2000hsf.googlegroups.com...
> February 19, 2008
news:c0aacdc9-a080-47ad-a158-ac78f0ad71bb@d62g2000hsf.googlegroups.com...
On Mar 14, 4:18 pm, "Patriot Games" <Patr...@America.com> wrote:
>> "Jerry Kraus" <jkraus_1...@yahoo.com> wrote in message
>> news:129b3ae1-8022-44fc-8b9b-92ff680097b4@t54g2000hsg.googlegroups.com...
>> On Mar 13, 2:11 pm, "Patriot Games" <Patr...@America.com> wrote:
>> >> "Joe" <dropdead_nos...@hotmail.com> wrote in message
>> >> YOU are now exposed as a LIAR and a FRAUD.
>> >Did you say something, baby-killer?
>> Thanks for outting yourself.
>I don't believe I've ever made any secret of the fact that I consider
>current members of the U.S. military to be mercenary scum, Patriot.
>And, that I consider Vietnam veterans to have been baby killers. So
>do quite a few of them, by the way. You were in a useless war,
>killing people for no reason, which, apparently you've never recovered
>from. My sympathies. Doesn't change the facts, though.
Guest Patriot Games
> February 19, 2008
news:ce9df93b-3f07-4b39-9b1b-532f10ce3e36@v3g2000hsc.googlegroups.com...
>> Let's summarize:
>> 1) You were completely WRONG about everything.
>> 2) I was completely correct about everything.
>> 3) You KNEW you were completely WRONG about everything and did not even
>> attempt to substantiate any of it.
>> 4) I KNEW I was completely correct about everything AND PROVED IT.
>Simple to explain, Patriot.
Yes, I explained it above.
YOU ARE A LIAR.
YOU ARE A FRAUD.
I have EXPOSED YOU as a LIAR and a FRAUD.
And the good news is Google and Yahoo Groups will SAVE THIS FOREVER.)
>Rapes, assaults, property crimes -- why, who
>cares? That's the attitude of American police.
Again, NOT ONE CITE FROM YOU. ONLY BULLSHIT.
YOU ARE A LIAR.
YOU ARE A FRAUD.
You claim that criminals WANT TO GO STRAIGHT and all they need is
HELP.
You FAILED TO PROVE that criminals WANT TO GO STRAIGHT.
I PROVED that most criminals DO NOT WANT to go straight.
And I EXPOSED YOU as a LIAR and a FRAUD.
Only 17% of eligible inmates participate in Federal Prison Industries, only
35% participate in Education programs and only 7% take advantage of
Vocational/Occupational Training programs.
http://www.bop.gov/news/PDFs/sob05.pdf
Quite obviously, 83% DO NOT WANT TO GO STRAIGHT and 93% DO NOT WANT TO LEARN
ANOTHER CAREER.
You claim that "most industrialized countries" take care of their citizens
and so have fewer criminals and crimes.
You FAILED TO PROVE that "most industrialized countries" take care of their
citizens and so have fewer criminals and crimes.
I PROVED that "most industrialized countries" DO NOT take care of their
citizens and so DO NOT have fewer criminals and crimes.
You FAILED TO EXPLAIN equally high Assaults:
Assaults (per capita) (most recent) by country
http://www.nationmaster.com/graph/cri_ass_percap-crime-assaults-per-capita
#6 United States: 7.56923 per 1,000 people
#8 United Kingdom: 7.45959 per 1,000 people
#9 Canada: 7.11834 per 1,000 people
#10 Australia: 7.02459 per 1,000 people
You FAILED TO EXPLAIN why OTHER COUNTRIES have HIGHER VICTIMIZATION Rates:
#2 United Kingdom: 2.8%
#3 Australia: 2.4%
#4 New Zealand: 2.4%
#5 Canada: 2.3%
#6 Finland: 2.1%
#7 Denmark: 1.4%
#8 France: 1.4%
#9 Sweden: 1.2%
#10 Belgium: 1.2%
#11 United States: 1.2%
You FAILED TO EXPLAIN why OTHER COUNTRIES have HIGHER RAPE Rates:
Rapes (per capita) (most recent) by country
http://www.nationmaster.com/graph/cri_rap_percap-crime-rapes-per-capita
#3 Australia: 0.777999 per 1,000 people
#5 Canada: 0.733089 per 1,000 people
#9 United States: 0.301318 per 1,000 people
Rape victims (most recent) by country
http://www.nationmaster.com/graph/cri_rap_vic-crime-rape-victims
#1 New Zealand: 1.3%
#2 Austria: 1.2%
#3 Sweden: 1.1%
#4 Finland: 1.1%
#5 Australia: 1%
#6 United Kingdom: 0.9%
#7 Canada: 0.8%
#8 Slovenia: 0.8%
#9 Netherlands: 0.8%
#10 France: 0.7%
#11 Switzerland: 0.6%
#12 Italy: 0.6%
#13 Denmark: 0.4%
#14 United States: 0.4%
You FAILED TO EXPLAIN why OTHER COUNTRIES have HIGHER CRIME Rates:
Burglaries (per capita) (most recent) by country
http://www.nationmaster.com/graph/cri_bur_percap-crime-burglaries-per-capita
#1 Australia: 21.7454 per 1,000 people
#3 Denmark: 18.3299 per 1,000 people
#5 Finland: 16.7697 per 1,000 people
#6 New Zealand: 16.2763 per 1,000 people
#7 United Kingdom: 13.8321 per 1,000 people
#8 Poland: 9.46071 per 1,000 people
#9 Canada: 8.94425 per 1,000 people
#10 South Africa: 8.89764 per 1,000 people
#12 Iceland: 8.11156 per 1,000 people
#13 Switzerland: 8.06303 per 1,000 people
#17 United States: 7.09996 per 1,000 people
Property crime victims (most recent) by country
http://www.nationmaster.com/graph/cri_pro_cri_vic-crime-property-victims
#1 New Zealand: 14.8%
#2 Australia: 13.9%
#3 Italy: 12.7%
#4 United Kingdom: 12.2%
#6 Canada: 10.4%
#7 United States: 10%
Guest Patriot Games
<lorad474@cs.com> wrote in message
news:d62ccc95-a277-4573-bf1a-465277a9bb6f@x41g2000hsb.googlegroups.com...
>> February 19, 2008
>> K.D. Kalinsky
>> I. Introduction:
>> paper submitted to
>> this
>> article is to
>> the origin and
>> biological life
>dispute.
Same thing...
Yep.
Guest Patriot Games
"I never proof-read my posts." <goofindoo@gmail.com> wrote in message
news:9916f6f5-dd12-4df1-a25f-89af36f02ca7@p39g2000prm.googlegroups.com...
An unsophisticated observation.
> Since intelligence can arise from the unintelligent,
Unproven, to date.
"Data" is not the result of anything other than scientific observation and
testing.
Guest Patriot Games
"urine" <danny99@bezeqint.net> wrote in message
news:c077a300-b4c0-47fe-a61c-4908f0e16179@2g2000hsn.googlegroups.com...
Your small mind failed to consider:
2-a) Life was created on many planets by God.
3-a) Life has formed on JUST THIS ONE planet spontaneously because of
extremely unique circumstances.
Perhaps you should confine yourself to your Smurf-based political opinions
and leave the hard work to those more capable?
Guest Uncle Al
[snip rest of crap]
Only an idiot or a virgin believes in Intelligent Design.
Uncle Al
http://www.mazepath.com/uncleal/
(Toxic URL! Unsafe for children and most mammals)
http://www.mazepath.com/uncleal/lajos.htm#a2
Guest Sri Bodhi Prana
> February 19, 2008
> K.D. Kalinsky
Here is a more readable version.
What a load of nonsense this paper is. It sounds like something meant
to fool amateurs into thinking it has scientific content.
Sri Bodhi Prana.
