"Some updates could not be installed"??? Please help!
Guest olly_k
Hi folks, I have jsut changed motherboards on my PC and had to 'repair' XP -
I did this by trying to re-install then windows gave me the extra option to
repair current edition - I didn't have a recovery disk so couldn't do this
the official way but windows seemed to go through the install process and
everything rebooted fine and windows started working again...
I then had to activate XP over the internet which seemed to go fine.
Trouble is, when ever I get critical updates I click the shield and I get a
box like this...
"Some updates could not be installed" - screenshot below...
http://i170.photobucket.com/albums/u270/olly-k/Image1.jpg
The list seems to be getting more critical so can anyone please help?!
Olly.
Guest olly_k
ok now I am back to the original box
does this mean the other stuff has installed correctly?
Olly.
"olly_k" wrote:
> box like this...
> Olly.</span>
Guest MowGreen [MVP]
Olly,
At this point in time, all updates previously installed are no longer
present. Suggest you show hidden files, folders, and system files -
http://www.bleepingcomputer.com/tutorials/...al62.html#winxp
Then do this - Start > Run > type in
net stop wuauserv
Click OK or press Enter
Back to Start > Run > type in
%windir%\softwaredistribution
Delete ALL of the subfolders of SoftwareDistribution
Close the window
Download and SAVE the latest version of the Windows Update Agent
http://go.microsoft.com/fwlink/?LinkID=91237
and KB927891
http://www.microsoft.com/downloads/details...89-404327772E5A
SAVE them, do NOT run them from their present location
When the downloads complete, close the browser and any other open programs
Install WindowsUpdateAgent30-x86.exe first
If a message appears that the Update Agent is already installed, browse
to the location of WindowsUpdateAgent30-x86.exe from Start > Run >
Browse, Open and add this command after " in the Open line
/wuforce
If the file is located in the root drive and said drive is C:\ the
command will look like this :
"C:\WindowsUpdateAgent30-x86.exe" /wuforce
Press Enter and it will install
Then install WindowsXP-KB927891-v3-x86-ENU.exe and restart the system
When the system is up go back to Start > Run > type in
wuauclt /detectnow
That should get the updating process started again
IF Windows Installer still fails to install, go back to Start > Run >
type in
%windir%\KB893803v2.log
Click OK
Post the above log, please.
MowGreen [MVP 2003-2007]
-343- FDNY
Never Forgotten
Guest olly_k
Hi Mowgreen, thankyou for your response - I just sorted tonight and hadn't
got round to updating this post but I have rated your post as helpful because
it was the same solution!
Thanks again!
Olly.
> Olly,
> net stop wuauserv
> %windir%softwaredistribution
> Close the window
> and KB927891
> /wuforce
> If the file is located in the root drive and said drive is C: the
> "C:WindowsUpdateAgent30-x86.exe" /wuforce
> wuauclt /detectnow
> type in
> %windir%KB893803v2.log
> Click OK
> -343- FDNY
> Never Forgotten
> olly_k wrote:
> <span style="color:green">
> > </span>
You're mowst welcome. So I take the issue is resolved, right ?
-343- FDNY
Never Forgotten
> Thanks again! </span>
Guest olly_k
Yep sorted thanks!
Olly.
> -343- FDNY
> Never Forgotten
  • 3 months later...
Sorry to hijack this post, I am having the same problem and I went through
all the steps you outlined: I ran the last thing you said to do and it told
me the file did not exist. Any suggestions for me? Here are the updates not
being installed:
Cumulative Security Update for Outlook Express for Windows XP (KB929123)
Security Update for Windows XP (KB938829)
Security Update for Windows XP (KB921503)
Update for Windows XP (KB936357)
Security Update for Windows Media Player 9 (KB936782)
Update for Windows XP (KB938828)
Security Update for Windows XP (KB936021)
> Olly,
> net stop wuauserv
> Close the window
> and KB927891
> /wuforce
> wuauclt /detectnow
> type in
> Click OK
> -343- FDNY
> Never Forgotten
> > </span>
  • 4 months later...
Guest Craiig
> Olly,
> net stop wuauserv
> Close the window
> and KB927891
> /wuforce
> wuauclt /detectnow
> type in
> Click OK
> -343- FDNY
> Never Forgotten
> > </span>
> YOUR A GENIUS!!!!! THANK YOU!!!!!!</span>
Guest Craiig
[KB893803v2.log]
0.078:
0.078: 2008/04/21 13:27:54.171 (local)
0.078: c:\1e8cc01594d9d299688a67190c6301\UPDATE\update.exe (version 6.1.22.4)
0.078: Hotfix started with following command line: /quiet /norestart
1.719: In Function TestVolatileFlag, line 11660, RegOpenKeyEx failed with
error 0x2
1.719: In Function TestVolatileFlag, line 11692, RegOpenKeyEx failed with
error 0x2
1.719: DoInstallation: CleanPFR failed: 0x2
1.719: SetProductTypes: InfProductBuildType=BuildType.IC
1.719: SetAltOsLoaderPath: No section uses DirId 65701; done.
1.750: DoInstallation: FetchSourceURL for
c:\1e8cc01594d9d299688a67190c6301\update\update_wxp.inf failed
1.750: CreateUninstall = 1,Directory = C:\WINDOWS\$MSI31Uninstall_KB893803v2$
1.750: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed:
0xe0000102
1.750: BuildCabinetManifest: update.url absent
1.750: Starting AnalyzeComponents
1.750: AnalyzePhaseZero used 0 ticks
1.750: No c:\windows\INF\updtblk.inf file.
1.750: SetupFindFirstLine in LoadExclusionList Failed with error: 0xe0000102
2.781:
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem22.CAT
trusts inf c:\windows\inf\oem22.inf of device
DOT4PRT\VID_03F0&PID_2811&MI_02&DOT4&PRINT_HPZ\9&740E3FB&0&1
3.219:
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem1.CAT
trusts inf c:\windows\inf\oem1.inf of device
PCI\VEN_10DE&DEV_0368&SUBSYS_CB841043&REV_A3\3&2411E6FE&0&51
5.860: Failed to query DriverPath of ROOT\LEGACY_AFD\0000 0x2
5.860: Failed to query DriverPath of ROOT\LEGACY_ARP1394\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_ASIO\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_AVG7CORE\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_AVG7RSW\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_AVG7RSXP\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_AVGCLEAN\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_AVGTDI\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_BEEP\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_CTAC32K\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_CTPRXY2K\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_CTSFM2K\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_DMBOOT\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_DMLOAD\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_EMUPIA\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_FIPS\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_GPC\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_HA20X2K\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_HTTP\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_IPNAT\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_IPSEC\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_KSECDD\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_MNMDD\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_MOUNTMGR\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_NDIS\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_NDISTAPI\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_NDISUIO\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_NDPROXY\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_NETBT\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_NULL\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_OSSRV\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_PARTMGR\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_PARVDM\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_RASACD\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_RDPCDD\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_TCPIP\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_VGASAVE\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_VOLSNAP\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_WANARP\0000 0x2
5.875: Failed to query DriverPath of ROOT\LEGACY_WS2IFSL\0000 0x2
6.688: Failed to query DriverPath of USB\VID_0471&PID_0815\PH00UMH3 0x2
6.703: SetupVerifyInfFile failed with error 0x490 for cyusb.inf of device
USB\VID_04B4&PID_E006\5&19448E6D&0&4
c:\windows\inf\cyusb.inf of device USB\VID_04B4&PID_E006\5&19448E6D&0&4
8.500: OEM file scan used 6750 ticks
8.828: AnalyzePhaseOne: used 7078 ticks
8.828: AnalyzeComponents: Hotpatch analysis disabled; skipping.
8.828: AnalyzeComponents: Hotpatching is disabled.
8.844: AnalyzePhaseTwo used 16 ticks
8.844: AnalyzePhaseThree used 0 ticks
8.844: AnalyzePhaseFive used 0 ticks
8.844: AnalyzePhaseSix used 0 ticks
8.844: AnalyzeComponents used 7094 ticks
8.844: Downloading 0 files
8.844: bPatchMode = FALSE
8.844: Inventory complete: ReturnStatus=0, 7094 ticks
8.844: Num Ticks for invent : 7094
8.844: Conditional load of section MSI.Reg.Install.Condition succeeded
8.844: Allocation size of drive C: is 4096 bytes, free space = 83093934080
bytes
8.844: AnalyzeDiskUsage: Skipping EstimateDiskUsageForUninstall.
8.844: Drive C: free 79244MB req: 5MB w/uninstall: NOT CALCULATED.
8.844: CabinetBuild complete
8.844: Num Ticks for Cabinet build : 0
8.844: DynamicStrings section not defined or empty.
8.969: FileInUse:: need to restart already, turn off
8.969: FileInUse:: Add to list - Service Name: msiserver
9.969: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed:
0xe0000102
9.985: Num Ticks for Backup : 1141
10.188: Num Ticks for creating uninst inf : 203
10.188: Registering Uninstall Program for -> KB893803v2, KB893803v2 , 0x0
10.188: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed:
0xe0000102
11.563: System Restore Point set.
11.594: PFE2: Not avoiding Per File Exceptions.
11.594: GetCatVersion: Failed to retrieve version information from
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.KB893803v2_wxp.cat with error 0x57
11.594: GetCatVersion: C:\WINDOWS\Tmp.0.KB893803v2_wxp.cat has version of
0, this may indicate error converting version string.
11.875: Copied file: C:\WINDOWS\system32\msi.dll
11.906: Copied file: C:\WINDOWS\system32\msiexec.exe
12.094: Copied file: C:\WINDOWS\system32\msihnd.dll
12.125: Copied file: C:\WINDOWS\system32\msimsg.dll
12.125: Copied file: C:\WINDOWS\system32\msisip.dll
12.219: Copied file: C:\WINDOWS\system32\DllCache\msi.dll
12.235: Copied file: C:\WINDOWS\system32\DllCache\msiexec.exe
12.250: Copied file: C:\WINDOWS\system32\DllCache\msihnd.dll
12.266: Copied file: C:\WINDOWS\system32\DllCache\msimsg.dll
12.281: Copied file: C:\WINDOWS\system32\DllCache\msisip.dll
12.281: DoInstallation: Installing assemblies with source root path:
12.281: Num Ticks for Copying files : 2093
12.297: Num Ticks for Reg update and deleting 0 size files : 16
12.313: GetCatVersion: C:\WINDOWS\KB893803v2_wxp.cat has version of 0, this
13.531: ---- Old Information In The Registry ------
13.531: Source:C:\WINDOWS\system32\_000228_.tmp.dll (3.0.3790.2180)
13.531: Destination:
13.531: ---- New Information In The Registry ------
15.641: UpdateSpUpdSvcInf: Source [ProcessesToRunAfterReboot] section is
empty; nothing to do.
15.641: IsRebootRequiredForFileQueue: c:\windows\system32\msisip.dll was
no-delay replaced; reboot is required.
c:\windows\system32\dllcache\msisip.dll was no-delay replaced; reboot is
required.
15.641: IsRebootRequiredForFileQueue: c:\windows\system32\msimsg.dll was
c:\windows\system32\dllcache\msimsg.dll was no-delay replaced; reboot is
required.
15.641: IsRebootRequiredForFileQueue: c:\windows\system32\msihnd.dll was
c:\windows\system32\dllcache\msihnd.dll was no-delay replaced; reboot is
required.
15.641: IsRebootRequiredForFileQueue: c:\windows\system32\msiexec.exe was
c:\windows\system32\dllcache\msiexec.exe was no-delay replaced; reboot is
required.
15.641: IsRebootRequiredForFileQueue: c:\windows\system32\msi.dll was
15.641: IsRebootRequiredForFileQueue: c:\windows\system32\dllcache\msi.dll
was no-delay replaced; reboot is required.
15.641: DoInstallation: A reboot is required to complete the installation of
one or more files.
15.641: In Function SetVolatileFlag, line 11576, RegOpenKeyEx failed with
error 0x2
15.641: In Function SetVolatileFlag, line 11593, RegOpenKeyEx failed with
error 0x2
[ProcessesToRunAfterReboot.RebootNotRequired] section is empty; nothing to do.
15.688: RebootNecessary = 1,WizardInput = 1 , DontReboot = 1, ForceRestart = 0
> Olly,
> net stop wuauserv
> Close the window
> and KB927891
> /wuforce
> wuauclt /detectnow
> type in
> Click OK
> -343- FDNY
> Never Forgotten
> > </span>
What happened when the system was restarted ?
Is Windows Installer 3.1 (KB893803 listed in Add/Remove Programs in the
Control Panel ?
Was Windows Installer 3.1 (V2) manually downloaded from the MS Download
Center or via Automatic|Windows|Microsoft Update ?
Two things stand out in the installation log:
1) SetupVerifyInfFile failed with error 0x490 for cyusb.inf of device
2) GetCatVersion: Failed to retrieve version information from
with error 0x57
The first refers to " Element not found. "
The second may indicate the 'Cause' shown in this MSKB:
You cannot install some updates or programs
http://support.microsoft.com/kb/822798
MowGreen [MVP 2003-2008]
-343- FDNY
Never Forgotten
> [KB893803v2.log]
> 0.078:
> 0.078: c:1e8cc01594d9d299688a67190c6301UPDATEupdate.exe (version 6.1.22.4)
> error 0x2
> error 0x2
> c:1e8cc01594d9d299688a67190c6301updateupdate_wxp.inf failed
> 1.750: CreateUninstall = 1,Directory = C:WINDOWS$MSI31Uninstall_KB893803v2$
> 0xe0000102
> 1.750: No c:windowsINFupdtblk.inf file.
> 2.781:
> C:WINDOWSsystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}oem22.CAT
> trusts inf c:windowsinfoem22.inf of device
> DOT4PRTVID_03F0&PID_2811&MI_02&DOT4&PRINT_HPZ9&740E3FB&0&1
> 3.219:
> C:WINDOWSsystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}oem1.CAT
> trusts inf c:windowsinfoem1.inf of device
> PCIVEN_10DE&DEV_0368&SUBSYS_CB841043&REV_A33&2411E6FE&0&51
> 5.860: Failed to query DriverPath of ROOTLEGACY_AFD�000 0x2
> 5.860: Failed to query DriverPath of ROOTLEGACY_ARP1394�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_ASIO�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_AVG7CORE�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_AVG7RSW�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_AVG7RSXP�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_AVGCLEAN�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_AVGTDI�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_BEEP�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_CTAC32K�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_CTPRXY2K�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_CTSFM2K�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_DMBOOT�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_DMLOAD�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_EMUPIA�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_FIPS�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_GPC�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_HA20X2K�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_HTTP�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_IPNAT�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_IPSEC�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_KSECDD�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_MNMDD�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_MOUNTMGR�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_NDIS�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_NDISTAPI�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_NDISUIO�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_NDPROXY�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_NETBT�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_NULL�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_OSSRV�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_PARTMGR�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_PARVDM�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_RASACD�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_RDPCDD�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_TCPIP�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_VGASAVE�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_VOLSNAP�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_WANARP�000 0x2
> 5.875: Failed to query DriverPath of ROOTLEGACY_WS2IFSL�000 0x2
> 6.688: Failed to query DriverPath of USBVID_0471&PID_0815PH00UMH3 0x2
> USBVID_04B4&PID_E0065&19448E6D&0&4
> c:windowsinfcyusb.inf of device USBVID_04B4&PID_E0065&19448E6D&0&4
> bytes
> 0xe0000102
> 0xe0000102
> C:WINDOWSsystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}Tmp.0.KB893803v2_wxp.cat with error 0x57
> 11.594: GetCatVersion: C:WINDOWSTmp.0.KB893803v2_wxp.cat has version of
> 11.875: Copied file: C:WINDOWSsystem32msi.dll
> 11.906: Copied file: C:WINDOWSsystem32msiexec.exe
> 12.094: Copied file: C:WINDOWSsystem32msihnd.dll
> 12.125: Copied file: C:WINDOWSsystem32msimsg.dll
> 12.125: Copied file: C:WINDOWSsystem32msisip.dll
> 12.219: Copied file: C:WINDOWSsystem32DllCachemsi.dll
> 12.235: Copied file: C:WINDOWSsystem32DllCachemsiexec.exe
> 12.250: Copied file: C:WINDOWSsystem32DllCachemsihnd.dll
> 12.266: Copied file: C:WINDOWSsystem32DllCachemsimsg.dll
> 12.281: Copied file: C:WINDOWSsystem32DllCachemsisip.dll
> 12.313: GetCatVersion: C:WINDOWSKB893803v2_wxp.cat has version of 0, this
> 13.531: Source:C:WINDOWSsystem32_000228_.tmp.dll (3.0.3790.2180)
> 15.641: IsRebootRequiredForFileQueue: c:windowssystem32msisip.dll was
> c:windowssystem32dllcachemsisip.dll was no-delay replaced; reboot is
> required.
> 15.641: IsRebootRequiredForFileQueue: c:windowssystem32msimsg.dll was
> c:windowssystem32dllcachemsimsg.dll was no-delay replaced; reboot is
> required.
> 15.641: IsRebootRequiredForFileQueue: c:windowssystem32msihnd.dll was
> c:windowssystem32dllcachemsihnd.dll was no-delay replaced; reboot is
> required.
> 15.641: IsRebootRequiredForFileQueue: c:windowssystem32msiexec.exe was
> c:windowssystem32dllcachemsiexec.exe was no-delay replaced; reboot is
> required.
> 15.641: IsRebootRequiredForFileQueue: c:windowssystem32msi.dll was
> 15.641: IsRebootRequiredForFileQueue: c:windowssystem32dllcachemsi.dll
> one or more files.
> error 0x2
> error 0x2
>>Olly,
>>net stop wuauserv
>>Close the window
>>and KB927891
>>/wuforce
>>wuauclt /detectnow
>>type in
>>Click OK
>> -343- FDNY
>>Never Forgotten
>>olly_k wrote:
>><span style="color:darkred">
>>></span>
>></span></span>
Guest Frank Saunders MS-MVP IE,OE/WM
"Craiig" <Craiig@discussions.microsoft.com> wrote in message
news:36742664-8265-439C-9DCC-AD4C46D7D6CC@microsoft.com...<span style="color:blue">
> [KB893803v2.log]
> 0.078:
> 6.1.22.4)
> error 0x2
> error 0x2
> 0xe0000102
> 0xe0000102
> 0xe0000102
> 2.781:
> 3.219:
> bytes
> 0xe0000102
> failed:
> 0xe0000102
> with error 0x57
> this
> required.
> required.
> required.
> required.
> of
> one or more files.
> error 0x2
> error 0x2
> do.
> = 0
>> Olly,
>> net stop wuauserv
>> Close the window
>> and KB927891
>> programs
>> /wuforce
>> wuauclt /detectnow
>> type in
>> Click OK
>> -343- FDNY
>> Never Forgotten
>> ></span>
>></span></span>
If it still isn't installed:
Turn on Windows Firewall and turn off any third-party firewall.
Turn off any anti-virus and anti-spyware.
Try again.
www.fjsmjs.com
Do not reply with email
Guest Paul Adare
> Try again.</span>
One would assume that an OE MVP would know better than to quote hundreds of
lines of useless text for a 4 line response. Apparently not.
Paul Adare
http://www.identit.ca
A bad random number generator: 1, 1, 1, 1, 1, 4.33e+67, 1, 1, 1
Can i use this tips and tricks for XP SP3 ? I installed SP3 and windows
update was not unable to update..with the same message "These
components were not installed" style_emoticons/
kva
kva's Profile: http://forums.techarena.in/member.php?userid=47320
View this thread: http://forums.techarena.in/showthread.php?t=793589
Guest PA Bear [MS MVP]
WinXP SP3 RTM has not been made available to users yet. See
http://forums.microsoft.com/TechNet/ShowPo...14173&SiteID=17
The only available support for WinXP SP3 Beta is in this forum:
http://forums.microsoft.com/TechNet/ShowFo...=2010&SiteID=17
NB: You will have to uninstall WinXP SP3 Beta before you'll be able to
install the final release.
~Robear Dyer (PA Bear)
MS MVP-IE, Mail, Security, Windows Desktop Experience - since 2002
AumHa VSOP & Admin http://aumha.net
DTS-L http://dts-l.net/
kva wrote:<span style="color:blue">
> components were not installed" style_emoticons/ </span>
  • 2 weeks later...
Guest AFDave
Instuctions didnt work for me... here is a copy of the log
[KB893803v2.log]
0.031:
0.031: 2008/05/08 21:50:44.595 (local)
0.031:
C:\WINDOWS\SoftwareDistribution\Download\ad9c4c2a779933f83b51a49a2c88838d\update\update.exe (version 6.1.22.4)
0.031: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.031: Hotfix started with following command line: /norestart /quiet -er
/ParentInfo:0e3b82de3115074aaf0668d2e9914204
0.328: In Function TestVolatileFlag, line 11660, RegOpenKeyEx failed with
error 0x2
0.328: In Function TestVolatileFlag, line 11692, RegQueryValueEx failed with
error 0x2
0.328: ---- Old Information In The Registry ------
0.328: Source:C:\WINDOWS\System32\_000045_.tmp (6.2.2600.1106)
0.328: Destination:
0.328: Source:C:\WINDOWS\System32\SETF1.tmp (5.1.2600.1557)
0.328: Destination:C:\WINDOWS\System32\winhttp.dll (5.1.2600.1106)
0.328: ---- New Information In The Registry ------
0.328: Destination:
0.328: SetProductTypes: InfProductBuildType=BuildType.Sel
0.328: SetAltOsLoaderPath: No section uses DirId 65701; done.
0.343: DoInstallation: FetchSourceURL for
c:\windows\softwaredistribution\download\ad9c4c2a779933f83b51a49a2c88838d\update\update_wxp.inf failed
0.343: CreateUninstall = 1,Directory = C:\WINDOWS\$MSI31Uninstall_KB893803v2$
0.343: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed:
0xe0000102
0.343: BuildCabinetManifest: update.url absent
0.343: Starting AnalyzeComponents
0.343: AnalyzePhaseZero used 0 ticks
0.343: No c:\windows\INF\updtblk.inf file.
0.343: SetupFindFirstLine in LoadExclusionList Failed with error: 0xe0000102
2.578: OEM file scan used 2235 ticks
2.859: AnalyzePhaseOne: used 2516 ticks
2.859: AnalyzeComponents: Hotpatch analysis disabled; skipping.
2.859: AnalyzeComponents: Hotpatching is disabled.
2.859: AnalyzePhaseTwo used 0 ticks
2.859: AnalyzePhaseThree used 0 ticks
2.859: AnalyzePhaseFive used 0 ticks
2.859: AnalyzePhaseSix used 0 ticks
2.859: AnalyzeComponents used 2516 ticks
2.859: Downloading 0 files
2.859: bPatchMode = FALSE
2.859: Inventory complete: ReturnStatus=0, 2516 ticks
2.859: Num Ticks for invent : 2516
2.859: Conditional load of section MSI.Reg.Install.Condition succeeded
2.859: Allocation size of drive C: is 4096 bytes, free space = 196600782848
bytes
2.859: AnalyzeDiskUsage: Skipping EstimateDiskUsageForUninstall.
2.859: Drive C: free 187493MB req: 10MB w/uninstall: NOT CALCULATED.
2.859: CabinetBuild complete
2.859: Num Ticks for Cabinet build : 0
2.859: DynamicStrings section not defined or empty.
2.859: FileInUse:: need to restart already, turn off
2.859: FileInUse:: Add to list - Service Name: msiserver
3.859: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed:
0xe0000102
3.921: Num Ticks for Backup : 1062
4.171: Num Ticks for creating uninst inf : 250
4.171: Registering Uninstall Program for -> KB893803v2, KB893803v2 , 0x0
4.171: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed:
0xe0000102
4.500: System Restore Point set.
4.515: Copied file: C:\WINDOWS\System32\spmsg.dll
4.546: PFE2: Not avoiding Per File Exceptions.
4.562: GetCatVersion: Failed to retrieve version information from
C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\KB893803v2_wxp.cat with error 0x57
4.656: Copied file: C:\WINDOWS\System32\msi.dll
4.671: Copied file: C:\WINDOWS\System32\msiexec.exe
4.703: Copied file: C:\WINDOWS\System32\msihnd.dll
4.781: Copied file: C:\WINDOWS\System32\msimsg.dll
4.796: Copied file: C:\WINDOWS\System32\msisip.dll
4.828: Copied file: C:\WINDOWS\System32\DllCache\msi.dll
4.828: Copied file: C:\WINDOWS\System32\DllCache\msiexec.exe
4.843: Copied file: C:\WINDOWS\System32\DllCache\msihnd.dll
4.843: Copied file: C:\WINDOWS\System32\DllCache\msimsg.dll
4.859: Copied file: C:\WINDOWS\System32\DllCache\msisip.dll
4.859: DoInstallation: Installing assemblies with source root path:
4.859: Num Ticks for Copying files : 688
4.875: Num Ticks for Reg update and deleting 0 size files : 16
4.875: ---- Old Information In The Registry ------
4.875: Source:C:\WINDOWS\System32\_000045_.tmp (6.2.2600.1106)
4.875: Destination:
4.875: Source:C:\WINDOWS\System32\SETF1.tmp (5.1.2600.1557)
4.875: Destination:C:\WINDOWS\System32\winhttp.dll (5.1.2600.1106)
4.875: Source:C:\WINDOWS\System32\_000103_.tmp.dll (2.0.2600.1106)
4.875: Destination:
4.875: ---- New Information In The Registry ------
4.875: Destination:
4.875: Destination:
5.859: UpdateSpUpdSvcInf: Source [ProcessesToRunAfterReboot] section is
5.859: IsRebootRequiredForFileQueue: c:\windows\system32\msisip.dll was
5.859: IsRebootRequiredForFileQueue: c:\windows\system32\dllcache\msisip.dll
5.859: IsRebootRequiredForFileQueue: c:\windows\system32\msimsg.dll was
5.859: IsRebootRequiredForFileQueue: c:\windows\system32\dllcache\msimsg.dll
5.859: IsRebootRequiredForFileQueue: c:\windows\system32\msihnd.dll was
5.859: IsRebootRequiredForFileQueue: c:\windows\system32\dllcache\msihnd.dll
5.859: IsRebootRequiredForFileQueue: c:\windows\system32\msiexec.exe was
required.
5.859: IsRebootRequiredForFileQueue: c:\windows\system32\msi.dll was
5.859: IsRebootRequiredForFileQueue: c:\windows\system32\dllcache\msi.dll
5.859: DoInstallation: A reboot is required to complete the installation of
one or more files.
5.859: In Function SetVolatileFlag, line 11576, RegOpenKeyEx failed with
error 0x2
5.859: In Function SetVolatileFlag, line 11593, RegQueryValueEx failed with
error 0x2
5.859: RebootNecessary = 1,WizardInput = 1 , DontReboot = 1, ForceRestart = 0
0.047:
0.063: 2008/05/10 14:16:41.691 (local)
0.063:
0.079: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.079: Hotfix started with following command line: /norestart /quiet -er
/ParentInfo:94275152cc171b43ac6d1321fbf36269
0.594: In Function TestVolatileFlag, line 11660, RegOpenKeyEx failed with
error 0x2
0.594: In Function TestVolatileFlag, line 11692, RegOpenKeyEx failed with
error 0x2
0.594: ---- Old Information In The Registry ------
0.594: Source:C:\WINDOWS\system32\wuauclt.exe.wusetup.124421.bak
(5.4.3790.2180)
0.594: Destination:
0.594: Source:C:\WINDOWS\system32\wuaucpl.cpl.wusetup.124562.bak
(5.4.3790.2180)
0.594: Destination:
0.594: Source:C:\WINDOWS\system32\wuaueng.dll.wusetup.124718.bak
(5.4.3790.2180)
0.594: Destination:
0.594: Source:C:\Program Files\Logitech\Desktop Messenger\8876480\rename.tmp
0.594: Destination:C:\Program Files\Logitech\Desktop
Messenger\8876480\rename.ini
0.594: ---- New Information In The Registry ------
(5.4.3790.2180)
0.594: Destination:
(5.4.3790.2180)
0.594: Destination:
0.610: Source:C:\WINDOWS\system32\wuaueng.dll.wusetup.124718.bak
(5.4.3790.2180)
0.610: Destination:
0.610: Source:C:\Program Files\Logitech\Desktop Messenger\8876480\rename.tmp
0.610: Destination:C:\Program Files\Logitech\Desktop
0.610: SetProductTypes: InfProductBuildType=BuildType.IP
0.610: SetAltOsLoaderPath: No section uses DirId 65701; done.
0.625: DoInstallation: FetchSourceURL for
0.625: CreateUninstall = 1,Directory = C:\WINDOWS\$MSI31Uninstall_KB893803v2$
0.625: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed:
0xe0000102
0.625: BuildCabinetManifest: update.url absent
0.625: Starting AnalyzeComponents
0.625: AnalyzePhaseZero used 0 ticks
0.625: No c:\windows\INF\updtblk.inf file.
0.625: SetupFindFirstLine in LoadExclusionList Failed with error: 0xe0000102
4.735:
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem35.CAT
trusts inf c:\windows\inf\oem35.inf of device
HID\VID_046D&PID_C517&MI_00\7&3D07BFF&0&0000
6.032:
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem10.CAT
trusts inf c:\windows\inf\oem10.inf of device
PCI\VEN_8086&DEV_2811&SUBSYS_00000000&REV_02\3&61AAA01&0&F8
6.250:
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem11.CAT
trusts inf c:\windows\inf\oem11.inf of device
PCI\VEN_8086&DEV_2828&SUBSYS_01F81028&REV_02\3&61AAA01&0&FA
6.407:
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem13.CAT
trusts inf c:\windows\inf\oem13.inf of device
PCI\VEN_8086&DEV_2830&SUBSYS_01F81028&REV_02\3&61AAA01&0&E8
6.610:
PCI\VEN_8086&DEV_2831&SUBSYS_01F81028&REV_02\3&61AAA01&0&E9
6.735:
PCI\VEN_8086&DEV_2832&SUBSYS_01F81028&REV_02\3&61AAA01&0&EA
7.563:
PCI\VEN_8086&DEV_2834&SUBSYS_01F81028&REV_02\3&61AAA01&0&D0
7.829:
PCI\VEN_8086&DEV_2835&SUBSYS_01F81028&REV_02\3&61AAA01&0&D1
8.157:
PCI\VEN_8086&DEV_2836&SUBSYS_01F81028&REV_02\3&61AAA01&0&EF
8.344:
PCI\VEN_8086&DEV_283A&SUBSYS_01F81028&REV_02\3&61AAA01&0&D7
8.485:
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem12.CAT
trusts inf c:\windows\inf\oem12.inf of device
PCI\VEN_8086&DEV_283E&SUBSYS_01F81028&REV_02\3&61AAA01&0&FB
8.579:
PCI\VEN_8086&DEV_283F&SUBSYS_00000000&REV_02\3&61AAA01&0&E0
8.672:
PCI\VEN_8086&DEV_2841&SUBSYS_00000000&REV_02\3&61AAA01&0&E1
8.766:
PCI\VEN_8086&DEV_2845&SUBSYS_00000000&REV_02\3&61AAA01&0&E3
8.860:
PCI\VEN_8086&DEV_2849&SUBSYS_00000000&REV_02\3&61AAA01&0&E5
8.907: SetupVerifyInfFile failed with error 0x490 for hdaudbus.inf of device
PCI\VEN_8086&DEV_284B&SUBSYS_01F81028&REV_02\3&61AAA01&0&D8
9.157:
PCI\VEN_8086&DEV_2850&SUBSYS_01F81028&REV_02\3&61AAA01&0&F9
9.266:
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem9.CAT
trusts inf c:\windows\inf\oem9.inf of device
PCI\VEN_8086&DEV_2A00&SUBSYS_00000000&REV_0C\3&61AAA01&0&00
9.391:
PCI\VEN_8086&DEV_2A01&SUBSYS_00000000&REV_0C\3&61AAA01&0&08
11.547: OEM file scan used 10922 ticks
11.938: AnalyzePhaseOne: used 11313 ticks
11.938: AnalyzeComponents: Hotpatch analysis disabled; skipping.
11.938: AnalyzeComponents: Hotpatching is disabled.
11.938: AnalyzePhaseTwo used 0 ticks
11.938: AnalyzePhaseThree used 0 ticks
11.938: AnalyzePhaseFive used 0 ticks
11.938: AnalyzePhaseSix used 0 ticks
11.938: AnalyzeComponents used 11313 ticks
11.938: Downloading 0 files
11.938: bPatchMode = FALSE
11.938: Inventory complete: ReturnStatus=0, 11313 ticks
11.938: Num Ticks for invent : 11313
11.938: Conditional load of section MSI.Reg.Install.Condition succeeded
11.938: Allocation size of drive C: is 4096 bytes, free space = 186732740608
bytes
11.938: AnalyzeDiskUsage: Skipping EstimateDiskUsageForUninstall.
11.938: Drive C: free 178082MB req: 5MB w/uninstall: NOT CALCULATED.
11.938: CabinetBuild complete
11.938: Num Ticks for Cabinet build : 0
11.938: DynamicStrings section not defined or empty.
12.797: FileInUse:: need to restart already, turn off
12.797: FileInUse:: Add to list - Service Name: msiserver
12.797: In order to successfully complete this installation, the following
services will automatically be stopped and restarted.
12.797: Windows Installer.
14.797: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed:
0xe0000102
14.922: Num Ticks for Backup : 2984
22.860: Num Ticks for creating uninst inf : 7938
22.875: Registering Uninstall Program for -> KB893803v2, KB893803v2 , 0x0
22.875: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed:
0xe0000102
22.891: System Restore Point set.
23.250: PFE2: Not avoiding Per File Exceptions.
23.297: GetCatVersion: Failed to retrieve version information from
23.500: Copied file: C:\WINDOWS\system32\msi.dll
23.688: Copied file: C:\WINDOWS\system32\msiexec.exe
23.750: Copied file: C:\WINDOWS\system32\msihnd.dll
23.907: Copied file: C:\WINDOWS\system32\msimsg.dll
23.938: Copied file: C:\WINDOWS\system32\msisip.dll
24.063: Copied file: C:\WINDOWS\system32\DllCache\msi.dll
24.079: Copied file: C:\WINDOWS\system32\DllCache\msiexec.exe
24.235: Copied file: C:\WINDOWS\system32\DllCache\msihnd.dll
24.266: Copied file: C:\WINDOWS\system32\DllCache\msimsg.dll
24.313: Copied file: C:\WINDOWS\system32\DllCache\msisip.dll
24.313: DoInstallation: Installing assemblies with source root path:
24.313: Num Ticks for Copying files : 1453
24.375: Num Ticks for Reg update and deleting 0 size files : 62
24.547: ---- Old Information In The Registry ------
24.547: Source:C:\WINDOWS\system32\wuauclt.exe.wusetup.124421.bak
(5.4.3790.2180)
24.547: Destination:
24.547: Source:C:\WINDOWS\system32\wuaucpl.cpl.wusetup.124562.bak
(5.4.3790.2180)
24.547: Source:C:\WINDOWS\system32\wuaueng.dll.wusetup.124718.bak
(5.4.3790.2180)
24.547: Source:C:\Program Files\Logitech\Desktop Messenger\8876480\rename.tmp
24.547: Destination:C:\Program Files\Logitech\Desktop
24.547: Source:C:\WINDOWS\system32\_000220_.tmp.dll (3.0.3790.2180)
24.547: Source:C:\WINDOWS\system32\_000221_.tmp.dll (3.0.3790.2180)
24.547: ---- New Information In The Registry ------
(5.4.3790.2180)
(5.4.3790.2180)
(5.4.3790.2180)
25.454: UpdateSpUpdSvcInf: Source [ProcessesToRunAfterReboot] section is
25.454: IsRebootRequiredForFileQueue: c:\windows\system32\msisip.dll was
required.
25.454: IsRebootRequiredForFileQueue: c:\windows\system32\msimsg.dll was
required.
25.454: IsRebootRequiredForFileQueue: c:\windows\system32\msihnd.dll was
required.
25.454: IsRebootRequiredForFileQueue: c:\windows\system32\msiexec.exe was
required.
25.454: IsRebootRequiredForFileQueue: c:\windows\system32\msi.dll was
25.454: IsRebootRequiredForFileQueue: c:\windows\system32\dllcache\msi.dll
25.454: DoInstallation: A reboot is required to complete the installation of
one or more files.
25.454: In Function SetVolatileFlag, line 11576, RegOpenKeyEx failed with
error 0x2
25.454: In Function SetVolatileFlag, line 11593, RegOpenKeyEx failed with
error 0x2
25.469: UpdateSpUpdSvcInf: Source
25.532: RebootNecessary = 1,WizardInput = 1 , DontReboot = 1, ForceRestart = 0
> Olly,
> net stop wuauserv
> Close the window
> and KB927891
> /wuforce
> wuauclt /detectnow
> type in
> Click OK
> -343- FDNY
> Never Forgotten
> > </span>
Guest AFDave
I found a fix to my problem on another blog...this is what I found...
SYMPTOMS
When you try to install updates from the Windows Update Web site, from the
Microsoft Update Web site, or by using the Automatic Updates feature, you
receive a message that states that the update or the updates were not
installed successfully. However, the updates are not displayed in the Update
History part of the Web site.
You experience this problem if the following conditions are both true:
• You try to update a computer that is running Windows XP.
• You have repaired the Windows XP installation by using the Windows XP CD.
CAUSE
This problem occurs because of how the Windows XP repair operation replaces
Windows system files. When you repair a Windows installation by using a
Windows XP CD, the repair operation performs both of the following
operations:
• It replaces all the Windows system files with the corresponding files from
the CD.
Note: This includes the Windows Update files.
• It restores the Windows registry.
The latest version of Windows Update includes a file that was not available
in the release version of Windows XP. This file is named Wups2.dll.
Therefore, after the repair operation is complete, the following situation
exists:
• The Wups2.dll file remains on the computer.
• The registry entries that correspond to this file are missing.
Because the registry files that correspond to the Wups2.dll file are
missing, update installations are unsuccessful.
RESOLUTION
Method 1: Register the Wups2.dll file in Windows
To register the Wups2.dll file in Windows, follow these steps:
1. Stop the Automatic Updates service. To do this, follow these steps:
a. Click Start, click Run, type cmd, and then click OK.
b. At the command prompt, type the following command, and then press ENTER:
net stop wuauserv
2. Register the Wups2.dll file. To do this, follow these steps:
a. At the command prompt, type the following command, and then press ENTER:
regsvr32 %windir%\system32\wups2.dll
Note For a computer that is running Windows XP Professional x64 Edition,
regsvr32 %windir%\syswow64\wups2.dll
b. Click OK on each verification message that you receive.
3. Start the Automatic Updates service. To do this, type the following
command at the command prompt, and then press ENTER:
net start wuauserv
4. Exit the command prompt. To do this type exit and then press ENTER.
> [KB893803v2.log]
> 0.031:
> 0.031:
> C:WINDOWSSoftwareDistributionDownloadad9c4c2a779933f83b51a49a2c88838dupdateupdate.exe (version 6.1.22.4)
> error 0x2
> error 0x2
> 0.328: Source:C:WINDOWSSystem32_000045_.tmp (6.2.2600.1106)
> 0.328: Destination:
> 0.328: Source:C:WINDOWSSystem32SETF1.tmp (5.1.2600.1557)
> 0.328: Destination:C:WINDOWSSystem32winhttp.dll (5.1.2600.1106)
> 0.328: Destination:
> c:windowssoftwaredistributiondownloadad9c4c2a779933f83b51a49a2c88838dupdateupdate_wxp.inf failed
> 0.343: CreateUninstall = 1,Directory = C:WINDOWS$MSI31Uninstall_KB893803v2$
> 0xe0000102
> 0.343: No c:windowsINFupdtblk.inf file.
> bytes
> 0xe0000102
> 0xe0000102
> 4.515: Copied file: C:WINDOWSSystem32spmsg.dll
> C:WINDOWSSystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}KB893803v2_wxp.cat with error 0x57
> 4.656: Copied file: C:WINDOWSSystem32msi.dll
> 4.671: Copied file: C:WINDOWSSystem32msiexec.exe
> 4.703: Copied file: C:WINDOWSSystem32msihnd.dll
> 4.781: Copied file: C:WINDOWSSystem32msimsg.dll
> 4.796: Copied file: C:WINDOWSSystem32msisip.dll
> 4.828: Copied file: C:WINDOWSSystem32DllCachemsi.dll
> 4.828: Copied file: C:WINDOWSSystem32DllCachemsiexec.exe
> 4.843: Copied file: C:WINDOWSSystem32DllCachemsihnd.dll
> 4.843: Copied file: C:WINDOWSSystem32DllCachemsimsg.dll
> 4.859: Copied file: C:WINDOWSSystem32DllCachemsisip.dll
> 4.875: Source:C:WINDOWSSystem32_000045_.tmp (6.2.2600.1106)
> 4.875: Destination:
> 4.875: Source:C:WINDOWSSystem32SETF1.tmp (5.1.2600.1557)
> 4.875: Destination:C:WINDOWSSystem32winhttp.dll (5.1.2600.1106)
> 4.875: Source:C:WINDOWSSystem32_000103_.tmp.dll (2.0.2600.1106)
> 4.875: Destination:
> 4.875: Destination:
> 4.875: Destination:
> 5.859: IsRebootRequiredForFileQueue: c:windowssystem32msisip.dll was
> 5.859: IsRebootRequiredForFileQueue: c:windowssystem32dllcachemsisip.dll
> 5.859: IsRebootRequiredForFileQueue: c:windowssystem32msimsg.dll was
> 5.859: IsRebootRequiredForFileQueue: c:windowssystem32dllcachemsimsg.dll
> 5.859: IsRebootRequiredForFileQueue: c:windowssystem32msihnd.dll was
> 5.859: IsRebootRequiredForFileQueue: c:windowssystem32dllcachemsihnd.dll
> 5.859: IsRebootRequiredForFileQueue: c:windowssystem32msiexec.exe was
> required.
> 5.859: IsRebootRequiredForFileQueue: c:windowssystem32msi.dll was
> 5.859: IsRebootRequiredForFileQueue: c:windowssystem32dllcachemsi.dll
> one or more files.
> error 0x2
> error 0x2
> 0.047:
> 0.063:
> error 0x2
> error 0x2
> 0.594: Source:C:WINDOWSsystem32wuauclt.exe.wusetup.124421.bak
> (5.4.3790.2180)
> 0.594: Destination:
> 0.594: Source:C:WINDOWSsystem32wuaucpl.cpl.wusetup.124562.bak
> (5.4.3790.2180)
> 0.594: Destination:
> 0.594: Source:C:WINDOWSsystem32wuaueng.dll.wusetup.124718.bak
> (5.4.3790.2180)
> 0.594: Destination:
> 0.594: Source:C:Program FilesLogitechDesktop Messenger8876480rename.tmp
> 0.594: Destination:C:Program FilesLogitechDesktop
> Messenger8876480rename.ini
> (5.4.3790.2180)
> 0.594: Destination:
> (5.4.3790.2180)
> 0.594: Destination:
> 0.610: Source:C:WINDOWSsystem32wuaueng.dll.wusetup.124718.bak
> (5.4.3790.2180)
> 0.610: Destination:
> 0.610: Source:C:Program FilesLogitechDesktop Messenger8876480rename.tmp
> 0.610: Destination:C:Program FilesLogitechDesktop
> 0.625: CreateUninstall = 1,Directory = C:WINDOWS$MSI31Uninstall_KB893803v2$
> 0xe0000102
> 0.625: No c:windowsINFupdtblk.inf file.
> 4.735:
> C:WINDOWSsystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}oem35.CAT
> trusts inf c:windowsinfoem35.inf of device
> HIDVID_046D&PID_C517&MI_007&3D07BFF&0&0000
> 6.032:
> C:WINDOWSsystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}oem10.CAT
> trusts inf c:windowsinfoem10.inf of device
> PCIVEN_8086&DEV_2811&SUBSYS_00000000&REV_023&61AAA01&0&F8
> 6.250:
> C:WINDOWSsystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}oem11.CAT
> trusts inf c:windowsinfoem11.inf of device
> PCIVEN_8086&DEV_2828&SUBSYS_01F81028&REV_023&61AAA01&0&FA
> 6.407:
> C:WINDOWSsystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}oem13.CAT
> trusts inf c:windowsinfoem13.inf of device
> PCIVEN_8086&DEV_2830&SUBSYS_01F81028&REV_023&61AAA01&0&E8
> 6.610:
> PCIVEN_8086&DEV_2831&SUBSYS_01F81028&REV_023&61AAA01&0&E9
> 6.735:
> PCIVEN_8086&DEV_2832&SUBSYS_01F81028&REV_023&61AAA01&0&EA
> 7.563:
> PCIVEN_8086&DEV_2834&SUBSYS_01F81028&REV_023&61AAA01&0&D0
> 7.829:
> PCIVEN_8086&DEV_2835&SUBSYS_01F81028&REV_023&61AAA01&0&D1
> 8.157:
> PCIVEN_8086&DEV_2836&SUBSYS_01F81028&REV_023&61AAA01&0&EF
> 8.344:
> PCIVEN_8086&DEV_283A&SUBSYS_01F81028&REV_023&61AAA01&0&D7
> 8.485:
> C:WINDOWSsystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}oem12.CAT
> trusts inf c:windowsinfoem12.inf of device
> PCIVEN_8086&DEV_283E&SUBSYS_01F81028&REV_023&61AAA01&0&FB
> 8.579:
> PCIVEN_8086&DEV_283F&SUBSYS_00000000&REV_023&61AAA01&0&E0
> 8.672:
> PCIVEN_8086&DEV_2841&SUBSYS_00000000&REV_023&61AAA01&0&E1
> 8.766:
> PCIVEN_8086&DEV_2845&SUBSYS_00000000&REV_023&61AAA01&0&E3
> 8.860:
> PCIVEN_8086&DEV_2849&SUBSYS_00000000&REV_023&61AAA01&0&E5
> PCIVEN_8086&DEV_284B&SUBSYS_01F81028&REV_023&61AAA01&0&D8
> 9.157:
> PCIVEN_8086&DEV_2850&SUBSYS_01F81028&REV_023&61AAA01&0&F9
> 9.266:
> C:WINDOWSsystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}oem9.CAT
> trusts inf c:windowsinfoem9.inf of device
> PCIVEN_8086&DEV_2A00&SUBSYS_00000000&REV_0C3&61AAA01&0&00
> 9.391:
> PCIVEN_8086&DEV_2A01&SUBSYS_00000000&REV_0C3&61AAA01&0&08
> bytes
> 0xe0000102
> 0xe0000102
> 23.500: Copied file: C:WINDOWSsystem32msi.dll
> 23.688: Copied file: C:WINDOWSsystem32msiexec.exe
> 23.750: Copied file: C:WINDOWSsystem32msihnd.dll
> 23.907: Copied file: C:WINDOWSsystem32msimsg.dll
> 23.938: Copied file: C:WINDOWSsystem32msisip.dll</span>
Always begin a new thread about /your/ problem, please.
Updates are not installed successfully from Windows Update, from Microsoft
Update, or by using Automatic Updates after you repair a Windows XP
installation:
http://support.microsoft.com/kb/943144
NB: Also applies to clean installs, upgrade installs, and Recovery installs.
Windows Update-specific newsgroup:
news://msnews.microsoft.com/microsoft.public.windowsupdate
AFDave wrote:<span style="color:blue">
> Instuctions didnt work for me... here is a copy of the log</span>
<snip>
  • 6 months later...
Guest brendo76
Hello Mow,
Nor will I ever forget...
I have been following your discussion with olly_k. I followed your
directions to the letter.
When I ran C:\windowsupdateagent30-x86.exe /wuforce, it appeared to be
installing as I would have expected. However, at the final screen, I go the
following message:
Install failed with the following error number:
0x8024d007
Since you requested of Olly that the log be provided, here it is:
[KB893803v2.log]
3.359:
3.359: 2005/05/18 17:14:51.467 (local)
3.359:
C:\WINDOWS\SoftwareDistribution\Download\85edc023096735764b42f7ffe25be521\update\update.exe (version 6.1.22.4)
3.422: Failed To Enable SE_SHUTDOWN_PRIVILEGE
3.469: Hotfix started with following command line: /norestart /quiet -er
/ParentInfo:03ac1bda50c7da4594fdf384cd9494d8
15.406: In Function TestVolatileFlag, line 11660, RegOpenKeyEx failed with
error 0x2
15.406: In Function TestVolatileFlag, line 11692, RegOpenKeyEx failed with
error 0x2
15.406: DoInstallation: CleanPFR failed: 0x2
16.484: SetProductTypes: InfProductBuildType=BuildType.IP
16.484: SetAltOsLoaderPath: No section uses DirId 65701; done.
18.078: DoInstallation: FetchSourceURL for
c:\windows\softwaredistribution\download\85edc023096735764b42f7ffe25be521\update\update_wxp.inf failed
18.078: CreateUninstall = 1,Directory =
18.078: LoadFileQueues: UpdSpGetSourceFileLocation for halaacpi.dll failed:
0xe0000102
18.094: BuildCabinetManifest: update.url absent
18.140: Starting AnalyzeComponents
18.140: AnalyzePhaseZero used 0 ticks
18.140: No c:\windows\INF\updtblk.inf file.
18.140: SetupFindFirstLine in LoadExclusionList Failed with error: 0xe0000102
54.187: Third Party Provider = Zenographics Inc for
DOT4PRT\VID_03F0&PID_0D17&REV_0100\7&13EDCC4E&0&1
57.531: SetupVerifyInfFile failed with error 0x490 for
c:\windows\inf\hp3200c.inf of device
LPTENUM\VID_04E6PID_80002000\5&1FDBBC00&0&LPT1.0
83.687: Failed to query DriverPath of ROOT\LEGACY_AFD\0000 0x2
83.687: Failed to query DriverPath of ROOT\LEGACY_BEEP\0000 0x2
83.687: Failed to query DriverPath of ROOT\LEGACY_DMBOOT\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_DMLOAD\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_FIPS\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_GPC\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_I2OMGMT\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_IPNAT\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_IPSEC\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_KSECDD\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_MMC_2K\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_MNMDD\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_MOUNTMGR\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_MRTRATE\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NAVAP\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NAVENG\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NAVEX15\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NDIS\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NDISTAPI\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NDISUIO\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NDPROXY\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NETBT\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NULL\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NWLNKFLT\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NWLNKFWD\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NWLNKIPX\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NWLNKNB\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_NWLNKSPX\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_PARTMGR\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_PARVDM\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_PFMODNT\0000 0x2
83.703: Failed to query DriverPath of ROOT\LEGACY_RASACD\0000 0x2
83.719: Failed to query DriverPath of ROOT\LEGACY_RDPCDD\0000 0x2
83.734: Failed to query DriverPath of ROOT\LEGACY_SYMEVENT\0000 0x2
83.734: Failed to query DriverPath of ROOT\LEGACY_SYMREDRV\0000 0x2
83.734: Failed to query DriverPath of ROOT\LEGACY_SYMTDI\0000 0x2
83.734: Failed to query DriverPath of ROOT\LEGACY_TCPIP\0000 0x2
83.734: Failed to query DriverPath of ROOT\LEGACY_VGASAVE\0000 0x2
83.734: Failed to query DriverPath of ROOT\LEGACY_VOLSNAP\0000 0x2
83.734: Failed to query DriverPath of ROOT\LEGACY_WANARP\0000 0x2
91.547: Third Party Provider = Hewlett-Packard for
USB\VID_03F0&PID_0D17\00CNFB268818
95.453: OEM file scan used 77313 ticks
95.844: AnalyzePhaseOne: used 77704 ticks
95.844: AnalyzeComponents: Hotpatch analysis disabled; skipping.
95.844: AnalyzeComponents: Hotpatching is disabled.
95.922: AnalyzePhaseTwo used 78 ticks
95.922: AnalyzePhaseThree used 0 ticks
95.922: AnalyzePhaseFive used 0 ticks
96.828: AnalyzePhaseSix used 906 ticks
96.844: AnalyzeComponents used 78704 ticks
96.844: Downloading 0 files
96.844: bPatchMode = FALSE
96.844: Inventory complete: ReturnStatus=0, 78766 ticks
96.844: Num Ticks for invent : 78766
96.844: Conditional load of section MSI.Reg.Install.Condition succeeded
96.844: Allocation size of drive C: is 4096 bytes, free space = 52124495872
bytes
96.984: AnalyzeDiskUsage: Skipping EstimateDiskUsageForUninstall.
96.984: Drive C: free 49709MB req: 5MB w/uninstall: NOT CALCULATED.
96.984: CabinetBuild complete
96.984: Num Ticks for Cabinet build : 140
96.984: DynamicStrings section not defined or empty.
97.078: FileInUse:: need to restart already, turn off
97.078: FileInUse:: Add to list - Service Name: msiserver
98.125: LoadFileQueues: UpdSpGetSourceFileLocation for halaacpi.dll failed:
0xe0000102
104.844: Num Ticks for Backup : 7860
152.312: Num Ticks for creating uninst inf : 47468
152.359: Registering Uninstall Program for -> KB893803v2, KB893803v2 , 0x0
152.359: LoadFileQueues: UpdSpGetSourceFileLocation for halaacpi.dll failed:
0xe0000102
152.734: Copied file: C:\WINDOWS\system32\spmsg.dll
152.812: PFE2: Not avoiding Per File Exceptions.
158.562: GetCatVersion: Failed to retrieve version information from
C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\KB893803v2_wxp.cat with error 0x57
196.500: Copied file: C:\WINDOWS\system32\msi.dll
196.547: DoInstallation: Installing assemblies with source root path:
196.547: Num Ticks for Copying files : 44235
196.719: Num Ticks for Reg update and deleting 0 size files : 172
196.797: ---- Old Information In The Registry ------
196.875: Source:C:\WINDOWS\system32\_000117_.tmp.dll (3.1.4000.1823)
196.875: Destination:
196.875: ---- New Information In The Registry ------
224.359: UpdateSpUpdSvcInf: Source [ProcessesToRunAfterReboot] section is
224.359: IsRebootRequiredForFileQueue: c:\windows\system32\msi.dll was
224.359: DoInstallation: A reboot is required to complete the installation
of one or more files.
224.359: In Function SetVolatileFlag, line 11576, RegOpenKeyEx failed with
error 0x2
224.359: In Function SetVolatileFlag, line 11593, RegOpenKeyEx failed with
error 0x2
224.422: UpdateSpUpdSvcInf: Source
229.750: RebootNecessary = 1,WizardInput = 1 , DontReboot = 1, ForceRestart
= 0
I'll continue to search for what that error means, but it seems as though
you know way more than I do. So, I would greatly appreciate your guidance.
Thanks for all you do!
Brendan.........
> Olly,
> net stop wuauserv
> Close the window
> and KB927891
> /wuforce
> wuauclt /detectnow
> type in
> Click OK
> -343- FDNY
> Never Forgotten
> > </span>
