How to deaktiverer DEP from a program ???Help Please:)
Guest Gatemix
Guest Gatemix
Hi im having problems whit the web cam on this Computer , i have windows
vista and when i try to install it , i allmost got it installd , but when i
was gona select the web cam , then windows vista strted making problems ,an
said tha the program vas a treath to t computer and somthing call DEP shutted
dow my msn , by the way it was in Msn i tryd to install it:) so how do i
deactivate DEP from a singel Program?? an please explain it in a easy way ,
im not a computer geek hehe style_emoticons/ but im getting there:) so if anyone can help
me i greatfull:)
Link to comment
Share on other sites
You can't disable DEP for Live Messenger. It is considered a system binary,
and those are designed to run with DEP.
If this persists, your best option is going to be to get a different camera
that is designed to work with Vista, or to see if there are updated drivers
available for the one you have. I'd try the latter option first.
Your question may already be answered in Windows Vista Security:
http://www.amazon.com/gp/product/047010155...rotectyourwi-20
"Gatemix" wrote:
> me i greatfull:) </span>
Link to comment
Guest Gatemix
i need help
yea but the web cam is a part of the computer ,so i dont understand why
windows vista is rejcting it , it vas allredy on the computer when i got it ? <span style="color:blue">
></span>
Link to comment
Did your computer come with Windows Vista? If so the manufacturer should
provide you with proper software that makes the webcam work. You need to call
their tech support. If the web cam consistently causes Messenger to hang then
they need to provide you with a solution. There is nothing we can really do
to help you, unfortunately.
> i need help
> "Jesper" wrote:
> <span style="color:green">
> > </span>
> windows vista is rejcting it , it vas allredy on the computer when i got it ? <span style="color:green">
> ></span></span>
Link to comment
Guest James Matthews
You should be able to do it from the propties
http://www.goldwatches.com/movado--watches.html
http://www.jewelerslounge.com/
"Gatemix" <Arnstein_l_@hotmail.com> wrote in message
news:F8367D1C-BF45-498C-BCE6-87FC5968A1B5@microsoft.com...<span style="color:blue">
> i
> ,an
> shutted
> help
> me i greatfull:)
Link to comment
  • 3 months later...
Guest Elrik_C
I also have problems with DEP that prevents the installation
of system board device drivers, and since MachSpeed, the
manufacturer of the system board has no intention of
providing a DEP compatable set of Vista 64 bit device drivers
and only made Vista 64 bit drivers as an after thought.
So it would be nice if there were a way to completely
disable DEP at least until all the device drivers are installed.
Perhaps a registry tweak or removal of a system file? style_emoticons/
Elrik_C
Posted via http://www.vistaheads.com
Link to comment
Guest Brink
Elrik_C;653936 Wrote: <span style="color:blue">
> Elrik_C
> Posted via 'Microsoft Windows Vista Community Forums - Vistaheads'
> (http://www.vistaheads.com)</span>
Hi Elrik_C,
I do not know if it will help in installing the drivers, but this will
show you how to completely disable DEP.
http://www.vistax64.com/tutorials/120778-d...le-disable.html
Shawn
Brink
There are no dumb questions, just the people that do not ask
them.
' VISTA FORUMS '
(http://www.vistax64.com/index.php?referrerid=2980)
Please post feedback to help others.
Link to comment
