Guest Barb Posted December 11, 2007 Posted December 11, 2007 I renewed my subscription for windows live onecare all went ok, then for some unknown reason all of a sudden when I go into Onecares it does not respond, ?? status shows green good but theres no tune up or any other normal info on screen and I cannot access onecare or its help centre. Im still waiting for tech support to contact me. Ive restarted, checked for viruses all kinds, does any one have an answer please Quote
Guest StephenB Posted December 11, 2007 Posted December 11, 2007 Barb <rowfam1> wrote: <span style="color:blue"> >I renewed my subscription for windows live onecare all went ok, then for some >unknown reason all of a sudden when I go into Onecares it does not respond, >?? status shows green good but theres no tune up or any other normal info on >screen and I cannot access onecare or its help centre. Im still waiting for >tech support to contact me. Ive restarted, checked for viruses all kinds, >does any one have an answer please </span> You probably upgraded to v 2.0 this past week. There have been some problems for a small percentage of people - little consolation if you are one of the few people. You may want to consider uninstalling and reinstalling OneCare. Activate with the same LiveID that you originally subscribed with. -steve -- Stephen Boots MVP Windows Live Windows Live OneCare Forum Moderator sboots@mvps.org Quote
Guest Fallstar Posted July 14, 2008 Posted July 14, 2008 "Barb" wrote: <span style="color:blue"> > I renewed my subscription for windows live onecare all went ok, then for some > unknown reason all of a sudden when I go into Onecares it does not respond, > ?? status shows green good but theres no tune up or any other normal info on > screen and I cannot access onecare or its help centre. Im still waiting for > tech support to contact me. Ive restarted, checked for viruses all kinds, > does any one have an answer please </span> So OneCare is running, according to the green icon in your system tray? I had a similar issue, but I have two computers listed with my install, all I had to do was to click on my computer's name on the left side, to select it, and all the info and links showed up. Quote
