"Interactive Services" - Problems
Guest JessiRight77
Hello. I have recently installed Vista Business on a Dell
Optiplex. Whenever I access a particular application, a message box
tells me that "A program can't display a message on your desktop."
The details on the message box say that there is a partial
incompatibility with Vista. I can close the message box, but it
continues to pop up every few minutes.
The application program seems to work fine, however. The message box
is just incredibly annoying!!!
My Windows services are set for "Interactive Services" to use the
"Manual" Startup Type, but the status is currently started.
MY QUESTION: Is this simply a notification box only? Will stopping
or disabling this service cause any security problems.... or will it
simply halt the notifications?
I'm confused.
Thanks,
Jessi
  • 1 month later...
Guest saffa
"JessiRight77" wrote:
> I'm confused.
> Thanks,
> Jessi
I cannot find the answer anywhere either?
  • 5 weeks later...
Guest morechid
Solution :
Solution :
<span style="color:blue"><span style="color:green">
>> Open:Control PanelSystem and MaintenanceAdministrative</span></span>
Tools\Services
>> In "Administrative Tools" Double click "Services".</span></span>
>> In SERVICES search for "Interactive Service Detection"</span></span>
>> Found it? Now Right click on "Interactive Service Detection" and</span></span>
select Properties.
>> A window will appears with in its own properties</span></span>
>> In that window go to "Startup type" and Disable it and Services</span></span>
status should be "stopped".
Now you wont get that message anymore.....
All the Best !!!
morechid
  • 1 month later...
Guest hillmet@yahoo.com.au
On Apr 15, 1:19 pm, morechid <morechid.37x...@no-mx.forums.net> wrote:<span style="color:blue">
> Solution :
> Solution :
><span style="color:green"><span style="color:darkred">
> ToolsServices
> select Properties.
> All the Best !!!
> morechid</span>
Thank you!
  • 1 month later...
Guest melbourneaussie
Thank you moredich for your help.
It is works.
Thanks again
melbourneaussie
