Guest Van Posted February 10, 2008 Share Posted February 10, 2008 I was told that I couyld not update my operating system. The error code was 80073712. The actual update was KB942615. I have not had problems before with updates. Any advice from the gurus? Quote Link to comment Share on other sites More sharing options...
Guest MowGreen [MVP] Posted February 11, 2008 Share Posted February 11, 2008 80073712 - ERROR_SXS_COMPONENT_STORE_CORRUPT. Windows Update file corruption. Delete the file ' pending.xml ' at C:\WINDOWS\WinSxS If the issue still exists after doing the above: Reinstall the Windows Update Agent Windows, x86-based systems http://download.windowsupdate.com/WindowsU...Agent30-x86.exe Windows, x64-based systems http://download.windowsupdate.com/WindowsU...Agent30-x64.exe MowGreen [MVP 2003-2008] =============== -343- FDNY Never Forgotten =============== Van wrote: <span style="color:blue"> > I was told that I couyld not update my operating system. The error code was > 80073712. The actual update was KB942615. I have not had problems before with > updates. Any advice from the gurus?</span> Quote Link to comment Share on other sites More sharing options...
Guest masterminx Posted February 12, 2008 Share Posted February 12, 2008 What if I don't have a pending.xml file in that directory? I can't reinstall the updater because it returns that same error when I try. I am using Vista Home Premium, by the way. "MowGreen [MVP]" wrote: <span style="color:blue"> > 80073712 - ERROR_SXS_COMPONENT_STORE_CORRUPT. > Windows Update file corruption. > > Delete the file ' pending.xml ' at C:WINDOWSWinSxS > > If the issue still exists after doing the above: > > Reinstall the Windows Update Agent > > Windows, x86-based systems > http://download.windowsupdate.com/WindowsU...Agent30-x86.exe > > Windows, x64-based systems > http://download.windowsupdate.com/WindowsU...Agent30-x64.exe > > > MowGreen [MVP 2003-2008] > =============== > -343- FDNY > Never Forgotten > =============== > > > > Van wrote: > <span style="color:green"> > > I was told that I couyld not update my operating system. The error code was > > 80073712. The actual update was KB942615. I have not had problems before with > > updates. Any advice from the gurus?</span> > </span> Quote Link to comment Share on other sites More sharing options...
Guest MowGreen [MVP] Posted February 13, 2008 Share Posted February 13, 2008 Run the Windows Update Agent by right clicking it and choose ' Run as admimistrator '. If that still fails to resolve the issue, see if you can manually download this update, save it, close all programs and browsers, and then attempt to install it by running as Admin: http://www.microsoft.com/downloads/results...&DisplayLang=en Click the correct Version of Vista listed on that page to access the update. MowGreen [MVP 2003-2008] =============== -343- FDNY Never Forgotten =============== masterminx wrote: <span style="color:blue"> > What if I don't have a pending.xml file in that directory? I can't reinstall > the updater because it returns that same error when I try. I am using Vista > Home Premium, by the way. > > "MowGreen [MVP]" wrote: > > <span style="color:green"> >>80073712 - ERROR_SXS_COMPONENT_STORE_CORRUPT. >>Windows Update file corruption. >> >>Delete the file ' pending.xml ' at C:WINDOWSWinSxS >> >>If the issue still exists after doing the above: >> >>Reinstall the Windows Update Agent >> >>Windows, x86-based systems >>http://download.windowsupdate.com/WindowsU...Agent30-x86.exe >> >>Windows, x64-based systems >>http://download.windowsupdate.com/WindowsU...Agent30-x64.exe >> >> >>MowGreen [MVP 2003-2008] >>=============== >> -343- FDNY >>Never Forgotten >>=============== >> >> >> >>Van wrote: >> >><span style="color:darkred"> >>>I was told that I couyld not update my operating system. The error code was >>>80073712. The actual update was KB942615. I have not had problems before with >>>updates. Any advice from the gurus?</span> >></span></span> Quote Link to comment Share on other sites More sharing options...
Guest masterminx Posted February 13, 2008 Share Posted February 13, 2008 Ok...none of that worked. I'm starting to think that I will never get my updates. I think I might actually hate this OS, now. style_emoticons/ "MowGreen [MVP]" wrote: <span style="color:blue"> > Run the Windows Update Agent by right clicking it and choose ' Run as > admimistrator '. > If that still fails to resolve the issue, see if you can manually > download this update, save it, close all programs and browsers, and then > attempt to install it by running as Admin: > http://www.microsoft.com/downloads/results...&DisplayLang=en > > Click the correct Version of Vista listed on that page to access the > update. > > MowGreen [MVP 2003-2008] > =============== > -343- FDNY > Never Forgotten > =============== > > > masterminx wrote: > <span style="color:green"> > > What if I don't have a pending.xml file in that directory? I can't reinstall > > the updater because it returns that same error when I try. I am using Vista > > Home Premium, by the way. > > > > "MowGreen [MVP]" wrote: > > > > <span style="color:darkred"> > >>80073712 - ERROR_SXS_COMPONENT_STORE_CORRUPT. > >>Windows Update file corruption. > >> > >>Delete the file ' pending.xml ' at C:WINDOWSWinSxS > >> > >>If the issue still exists after doing the above: > >> > >>Reinstall the Windows Update Agent > >> > >>Windows, x86-based systems > >>http://download.windowsupdate.com/WindowsU...Agent30-x86.exe > >> > >>Windows, x64-based systems > >>http://download.windowsupdate.com/WindowsU...Agent30-x64.exe > >> > >> > >>MowGreen [MVP 2003-2008] > >>=============== > >> -343- FDNY > >>Never Forgotten > >>=============== > >> > >> > >> > >>Van wrote: > >> > >> > >>>I was told that I couyld not update my operating system. The error code was > >>>80073712. The actual update was KB942615. I have not had problems before with > >>>updates. Any advice from the gurus? > >></span></span> > </span> Quote Link to comment Share on other sites More sharing options...
Guest KC Posted March 26, 2008 Share Posted March 26, 2008 my problem started with not getting updates 8/07, in searching for updates gives the error code 80073712 "MowGreen [MVP]" wrote: <span style="color:blue"> > 80073712 - ERROR_SXS_COMPONENT_STORE_CORRUPT. > Windows Update file corruption. > > Delete the file ' pending.xml ' at C:WINDOWSWinSxS > > If the issue still exists after doing the above: > > Reinstall the Windows Update Agent > > Windows, x86-based systems > http://download.windowsupdate.com/WindowsU...Agent30-x86.exe > > Windows, x64-based systems > http://download.windowsupdate.com/WindowsU...Agent30-x64.exe > > > MowGreen [MVP 2003-2008] > =============== > -343- FDNY > Never Forgotten > =============== > > > > Van wrote: > <span style="color:green"> > > I was told that I couyld not update my operating system. The error code was > > 80073712. The actual update was KB942615. I have not had problems before with > > updates. Any advice from the gurus?</span> > </span> Quote Link to comment Share on other sites More sharing options...
