HELP ! My PC has been compromised !!
Guest penang@freemail.c3.hu
Last nite my PC behaves normally, but this morning, it took over 1
hour to boot up the XP.
Now, in the tasking tray, I see tons and tons of messages are being
sent out !
I have not configure this PC to send out emails. I use webmails. But
now my PC is sending out tons and tons of emails !!
The symantec norton antivirus is doing the "Symantec Email Scan" on
those emails and the emails are jamming up the system.
What can I do ????
What software should I use to remove this security breach ????
Please help !!!!
Thank you !!
Guest David H. Lipman
| sent out !
| What can I do ????
| Please help !!!!
| Thank you !!
Download and execute HiJack This! (HJT)
http://www.trendsecure.com/portal/en-US/th.../HJTInstall.exe
Create a HJT log file and post it in one of the below locations...
{ Please - Do NOT post the HJT Log here ! }
Forums where you can get expert advice for HiJack This! (HJT) logs.
NOTE: Registration is REQUIRED in any of the below before posting a log
Suggested primary:
http://www.thespykiller.co.uk/index.php?board=3.0
Suggested secondary:
http://www.bleepingcomputer.com/forums/forum22.html
http://castlecops.com/forum67.html
Suggested tertiary:
http://www.dslreports.com/forum/cleanup
http://www.cybertechhelp.com/forums/forumdisplay.php?f=25
http://www.atribune.org/forums/index.php?showforum=9
http://www.geekstogo.com/forum/Malware_Rem...o_Here-f37.html
http://gladiator-antivirus.com/forum/index.php?showforum=170
http://forum.networktechs.com/forumdisplay.php?f=130
http://forums.maddoktor2.com/index.php?showforum=17
http://www.spywarewarrior.com/viewforum.php?f=5
http://forums.spywareinfo.com/index.php?showforum=18
http://forums.techguy.org/f54-s.html
http://forums.tomcoyote.org/index.php?showforum=27
http://forums.subratam.org/index.php?showforum=7
http://www.5starsupport.com/ipboard/index.php?showforum=18
http://www.malwarebytes.org/forums/index.php?showforum=7
http://makephpbb.com/phpbb/viewforum.php?f=2
http://forums.techguy.org/54-security/
http://forums.security-central.us/forumdisplay.php?f=13
Dave
http://www.claymania.com/removal-trojan-adware.html
Multi-AV - http://www.pctipp.ch/downloads/dl/35905.asp
Guest PA Bear [MS MVP]
Unexplained computer behavior may be caused by deceptive software
http://support.microsoft.com/kb/827315
Run a /thorough/ check for hijackware, including posting your hijackthis log
to an appropriate forum.
Checking for/Help with Hijackware
http://aumha.org/a/parasite.htm
http://aumha.org/a/quickfix.htm
http://aumha.net/viewtopic.php?t=5878
http://wiki.castlecops.com/Malware_Removal...n:_Introduction
http://mvps.org/winhelp2002/unwanted.htm
http://inetexplorer.mvps.org/data/prevention.htm
http://inetexplorer.mvps.org/tshoot.html
http://www.mvps.org/sramesh2k/Malware_Defence.htm
http://defendingyourmachine2.blogspot.com/
http://www.elephantboycomputers.com/page2....emoving_Malware
When all else fails, HijackThis v2.0.2
(http://aumha.org/downloads/hijackthis.zip) is the preferred tool to use.
It will help you to both identify and remove any hijackware/spyware with
assistance from an expert. Post your log to
http://forums.spybot.info/forumdisplay.php?f=22,
http://castlecops.com/forum67.html,
http://forums.subratam.org/index.php?showforum=7,
http://aumha.net/viewforum.php?f=30, or other appropriate forums for review
by an expert in such matters, not here.
If the procedures look too complex - and there is no shame in admitting this
isn't your cup of tea - take the machine to a local, reputable and
independent (i.e., not BigBoxStoreUSA) computer repair shop.
penang@freemail.c3.hu wrote:<span style="color:blue">
> sent out !
> What can I do ????
> Please help !!!!
> Thank you !! </span>
Guest Patrick Keenan
<penang@freemail.c3.hu> wrote in message
news:284d05e7-7d2a-425d-87fe-4279d9af68c8@e6g2000prf.googlegroups.com...<span style="color:blue">
> sent out !
> What can I do ????
> Please help !!!!
> Thank you !!</span>
The very first thing you should do is to disconnect the PC from any network
connection or telephone line, so that it cannot send anything. Then, you
can start scanning and manually searching for files that shouldn't be
running or in existence. Process Explorer and Hijack This are good
starting points.
Look for .exe and .dll files that have apparently random names. If you
delete them and new ones come back, there is another file that is creating
them you've missed.
Often these files are hidden away, so doing searches for hidden and system
files can often identify malware. Go to a command prompt, and from the
root directory use the dir command with the /a:h and /a:s switches to show
system and hidden files, and the /S switch to search all subdirectories.
At the end of the command, use the redirect to file to get a file you can
actually read: dir /ah /S >>list.txt
Clear all the temp folders and content.ie5 folders. This is a prime
location and entry point for malware. Look in the System32 folder for
files that shouldn't be there.
You can attach that drive to another well-protected system and scan it as a
hosted drive. Trying to gain control of an actively infected drive can be
difficult, but hosting it makes the process a lot easier since the
infections can't launch at boot.
Because you don't boot from it, there is very limited opportunity for
infection to spread to the host system. You might try using the Trend
Micro Housecall online scanner; since its files are online they are much
harder to compromise.
HTH
-pk
Guest Straight Talk
>sent out !
>What can I do ????
>Please help !!!!
>Thank you !!</span>
You should of course revert to the latest known clean state - which
ultimately means flatten and rebuild.
Guest Lanwench [MVP - Exchange]
Straight Talk <b__nice@hotmail.com> wrote:<span style="color:blue">
><span style="color:green">
>> sent out !
>> What can I do ????
>> Please help !!!!
>> Thank you !!</span>
> ultimately means flatten and rebuild.</span>
Well, that's a bit dire - it may not be at all necessary. It might be, but
it isn't the first thing I'd try.
Guest giedrius.majauskas@gmail.com
<span style="color:blue"><span style="color:green">
> >Thank you !!</span>
1. Get some nice free spyware remover, or at least scanner to get the
names of parasites. SuperAntiSpyware or Malwarebytes anti-malware to
name a few that have free versions, spyware terminator, etc.
2. If you opt for software that offers free scans only (Spyware
Doctor, CounterSpy, SpySpweeper, etc), google for spyware names it
finds, there might be free solutions/information about these
parasites. Especially if you want to get out from this freely. You can
pay for them, if you wish.
3. Post hijackthis logs in forums and wait for help.
For the future, I strongly suggest updating browser if you still use
IE older than 6. IE 7 is much better if your PC can handle it.
Lanwench [MVP - Exchange] wrote:<span style="color:blue">
>><span style="color:darkred">
>>>sent out !
>>>What can I do ????
>>>Please help !!!!
>>>Thank you !!</span>
Well, you've certainly picked up some malware. I wonder how Symantec
missed it.
Tom <t.wyckoff@verizon.net> wrote:<span style="color:blue">
> Lanwench [MVP - Exchange] wrote:<span style="color:green">
>>>> sent out !
>>>> But now my PC is sending out tons and tons of emails !!
>>>> What can I do ????
>>>> Please help !!!!
>>>> Thank you !!
>> be, but it isn't the first thing I'd try.
>></span>
> missed it.</span>
<looks around frantically, in sudden terror>
I have? Oh my god! And I don't even have Symantec software on here!
Wait. Symantec is malware, and you must not have meant to reply to me .
Guest Ricky
"Lanwench [MVP - Exchange]"
<lanwench@heybuddy.donotsendme.unsolicitedmailatyahoo.com> wrote in message
news:uckc29kgIHA.748@TK2MSFTNGP04.phx.gbl...<span style="color:blue">
> Tom <t.wyckoff@verizon.net> wrote:<span style="color:green">
>> Lanwench [MVP - Exchange] wrote:<span style="color:darkred">
>>>>> sent out !
>>>>> What can I do ????
>>>>> Please help !!!!
>>>>> Thank you !!
>>></span>
>> missed it.</span>
></span>
You must be the only one that doesn't have Symantec. ;-)
Computers make very fast, very accurate mistakes.
Ricky <rsjoiner@NO_SPAMbellsouth.net> wrote:<span style="color:blue">
> message news:uckc29kgIHA.748@TK2MSFTNGP04.phx.gbl...<span style="color:green">
>> Tom <t.wyckoff@verizon.net> wrote:<span style="color:darkred">
>>>>>> 1 hour to boot up the XP.
>>>>>> being sent out !
>>>>>> on those emails and the emails are jamming up the system.
>>>>>> What can I do ????
>>>>>> Please help !!!!
>>>>>> Thank you !!
>>>>> which ultimately means flatten and rebuild.
>>>> might be, but it isn't the first thing I'd try.
>>> Symantec missed it.</span>
>> me .
>></span>
> You must be the only one that doesn't have Symantec. ;-)</span>
Oh, not by a long shot!
From: "Lanwench [MVP - Exchange]" <lanwench@heybuddy.donotsendme.unsolicitedmailatyahoo.com>
>> You must be the only one that doesn't have Symantec. ;-)</span></span>
I wish people would not confuse Norton AV with Symantec AV.
The difference between the corporate offering (Symantec AV) vs. the retail offering (Norton
AV) is night and day.
It is the retail version that pisses people off.
Dave
David H. Lipman <DLipman~nospam~@Verizon.Net> wrote:<span style="color:blue">
><span style="color:green"><span style="color:darkred">
>></span>
> retail offering (Norton AV) is night and day.
> It is the retail version that pisses people off.</span>
Well, I'm pretty pissed off at Symantec's abyssmal tech support for their
enterprise products, so I don't think I fall into the category of person to
which you refer. The only Symantec stuff I use at any client site is
BackupExec, and that's because I used to adore Veritas and Symantec hasn't
managed to entirely kill off that good product yet.
Guest Straight Talk
On Sun, 9 Mar 2008 11:09:17 -0400, "Lanwench [MVP - Exchange]"
>Straight Talk <b__nice@hotmail.com> wrote:<span style="color:green">
>>> sent out !
>>> What can I do ????
>>> Please help !!!!
>>> Thank you !!</span>
>Well, that's a bit dire - it may not be at all necessary. </span>
Problem is, you wouldn't be able to tell whether it is or not unless
you have a baseline.
>It might be, but it isn't the first thing I'd try. </span>
Trial and error against malware is a common but very stupid approach.
Guest Straight Talk
On Sun, 9 Mar 2008 09:01:08 -0700 (PDT), giedrius.majauskas@gmail.com
>> >Thank you !!</span>
>names of parasites. </span>
How about getting a clue instead.
>name a few that have free versions, spyware terminator, etc.</span>
What makes you believe these will work? - Advertising?
>pay for them, if you wish.</span>
Yeah, fill up your machine with anti-crap.....
>IE older than 6. IE 7 is much better if your PC can handle it.</span>
Better stay away from IE completely (with IE7 on Vista in protected
mode as a possible exception).
Guest bojimbo26one@aol.com
On Sun, 9 Mar 2008 21:39:46 -0500, "Ricky"
>>>>>> sent out !
>>>>>> What can I do ????
>>>>>> Please help !!!!
>>>>>> Thank you !!
>>> missed it.</span>
>></span>
Had it on my first comp back in `99 for a month .
That, I agree with you.
Dave
Guest Frank Saunders MS-MVP IE,OE/WM
"Ricky" <rsjoiner@NO_SPAMbellsouth.net> wrote in message
news:Wb1Bj.5481$r76.533@bignews8.bellsouth.net...<span style="color:blue">
>></span>
Wouldn't have it anywhere near one of my machines or a customer's.
www.fjsmjs.com
Do not reply with email
"David H. Lipman" <DLipman~nospam~@Verizon.Net> wrote in message
news:WK1Bj.2731$HA3.948@trnddc02...<span style="color:blue">
> offering (Norton
If they foist that crap on the poor, ignorant public they don't deserve
respect for anything.
www.fjsmjs.com
<snipped for length><span style="color:blue"><span style="color:green"><span style="color:darkred">
>> Well, that's a bit dire - it may not be at all necessary.</span>
>> It might be, but it isn't the first thing I'd try.</span>
> Trial and error against malware is a common but very stupid approach.</span>
Nonsense. It depends entirely on the severity of the infestation. I won't
spend hours and hours on a troubled workstation, but if I can pretty easily
remove a not-very-invasive piece of malware or two, I simply do so. I don't
tell a client, "Sorry; I saw a popup - it's format time!" What is a "stupid
approach" (I merely quote you; I tend not to use such derogatory language)
is any hard and fast rule applied blindly regardless of situation.
Guest Straight Talk
On Mon, 10 Mar 2008 11:35:37 -0400, "Lanwench [MVP - Exchange]"
>Straight Talk <b__nice@hotmail.com> wrote:</span>
>Nonsense. </span>
Not really.
>It depends entirely on the severity of the infestation. </span>
Precisely. A severity you cannot determine without having a baseline.
>I won't spend hours and hours on a troubled workstation, but if I can pretty easily
>remove a not-very-invasive piece of malware or two, I simply do so. </span>
And how exactly do you verify that the machine is now back in a
reliable state?
>>> approach.</span>
>> Nonsense.</span>
> Not really.
>> It depends entirely on the severity of the infestation.</span>
>> can pretty easily remove a not-very-invasive piece of malware or
>> two, I simply do so.</span>
> reliable state?</span>
Because it works and has no further symptoms when I run thorough scans.
That's generally good enough for a home user. Sorry, I'm bored now - done
with this thread. Have fun storming the castle.
Guest Straight Talk
On Tue, 11 Mar 2008 12:13:12 -0400, "Lanwench [MVP - Exchange]"
>>>> approach.
>>> Nonsense.</span>
>> Not really.
>Because it works and has no further symptoms when I run thorough scans. </span>
This coming from someone bragging to be an MVP. Very sad.
>That's generally good enough for a home user. </span>
That's very good news for malware writers.
>with this thread. Have fun storming the castle.</span>
Oh, yes. Go back to sleep, MVP bragger.
Guest FromTheRafters
"Straight Talk" <b__nice@hotmail.com> wrote in message
news:9u5ct3pf7c04vnkkj3ut9k0f5ft72kfqj0@4ax.com...<span style="color:blue">
>>Nonsense.</span>
> Not really.
>>pretty easily
>>remove a not-very-invasive piece of malware or two, I simply do so.</span>
If you know what changes a malware made, you
can often reverse those changes and get the system
back to as reliable as it was before the malware hit.
Yes...it is that 'if' that is the bugger. Many malwares
allow communication outside the system so you no
longer know exactly what changes were made and
it is time to flatten and rebuild if you desire any sense
of confidence in its integrity.
Guest Straight Talk
On Tue, 11 Mar 2008 17:35:35 -0400, "FromTheRafters"
>news:9u5ct3pf7c04vnkkj3ut9k0f5ft72kfqj0@4ax.com...<span style="color:green">
>>>Nonsense.</span>
>> Not really.
>>>pretty easily
>back to as reliable as it was before the malware hit.</span>
That's true. Which, as I said, requires a baseline and a thorough
understanding. Most users don't have that.
>of confidence in its integrity. </span>
Yup.
