Guest Michael Posted March 26, 2008 Share Posted March 26, 2008 I have an unknown running process on my computer called "Andrea RT Filters Service". It runs as a Windows servce on start up. I googled it and come up with "Andrea Electronics Corporation". When I contacted them to see if I could get some information about the application. they replied that the do not own or distrubute any application by this name. I have stopped the service and disabled it and there seems to be no side effects. Can someone please tell me what this process is? Quote Link to comment Share on other sites More sharing options...
Guest Malke Posted March 26, 2008 Share Posted March 26, 2008 Michael wrote: <span style="color:blue"> > I have an unknown running process on my computer called "Andrea RT Filters > Service". It runs as a Windows servce on start up. I googled it and come > up > with "Andrea Electronics Corporation". When I contacted them to see if I > could get some information about the application. they replied that the do > not own or distrubute any application by this name. I have stopped the > service and disabled it and there seems to be no side effects. Can > someone please tell me what this process is?</span> I have seen something similar on a client's machine and it was related to some third-party speech recognition software preinstalled by the computer mftr. Can't remember offhand exactly what it was, but since he never used the speech recognition program we turned it off. If you have an OEM machine and this scenario might be applicable to you, manage your Startup matrix and turn off the program that requires the service. Then Start Orb>Search Box>type: services.msc (run the result that will appear) and change the service from "Automatic" to "Manual" if not already that way. Start Orb>Start Search box>msconfig [enter] If you are prompted for an administrator password or for a confirmation, type the password, or click Continue. Then see what is on the Startup tab. You don't need to restart immediately, but the next time you do you'll get a dialog saying you've used the Utility. Usually in Vista this will be blocked by Windows Defender and you'll need to allow it so you can then tick the box that says in effect, "don't bother me about this again". Important - Do not use the System Configuration Utility to stop processes. Instead, use Start>Run>services.msc [enter] and do not stop any services unless you really, really know what you're doing. The free Autoruns program is very useful for managing your Startup - http://www.microsoft.com/technet/sysinternals/default.mspx - Autoruns Malke -- MS-MVP Elephant Boy Computers www.elephantboycomputers.com Don't Panic! Quote Link to comment Share on other sites More sharing options...
Guest RalfG Posted March 26, 2008 Share Posted March 26, 2008 According to http://www.runscanner.net/files/exe/aeadis...adisrv.exe.aspx and http://www.castlecops.com/o23list-3158.html this company http://www.andreaelectronics.com/ does provide multimedia hardware and drivers that run under windows. The service you mentioned isn't specifically mentioned at the sites above but it could well be required as part of your audio system drivers. "Michael" <Michael@discussions.microsoft.com> wrote in message news:113A94DF-3290-42BC-A8BB-C0937C9F62ED@microsoft.com...<span style="color:blue"> >I have an unknown running process on my computer called "Andrea RT Filters > Service". It runs as a Windows servce on start up. I googled it and come > up > with "Andrea Electronics Corporation". When I contacted them to see if I > could get some information about the application. they replied that the do > not own or distrubute any application by this name. I have stopped the > service and disabled it and there seems to be no side effects. Can > someone > please tell me what this process is? </span> Quote Link to comment Share on other sites More sharing options...
Guest Ray Posted March 26, 2008 Share Posted March 26, 2008 =?Utf-8?B?TWljaGFlbA==?= <Michael@discussions.microsoft.com> wrote: <span style="color:blue"> > I have an unknown running process on my computer called "Andrea RT > Filters Service". It runs as a Windows servce on start up. I > googled it and come up with "Andrea Electronics Corporation". > When I contacted them to see if I could get some information about > the application. they replied that the do not own or distrubute > any application by this name. I have stopped the service and > disabled it and there seems to be no side effects. Can someone > please tell me what this process is?</span> The same or similar process, aertsrv.exe, was installed on my system when I updated my Realtek audio drivers. I disabled it and as far as I can tell all the audio functions still work. -- Ray (remove the Xs to reply) Quote Link to comment Share on other sites More sharing options...
Guest Michael Posted March 27, 2008 Share Posted March 27, 2008 I bought my computer from Dell and on thier drivers disk I installed the Realtek Audio drivers. But why would they say they don't own or distribute this application? Anyway, you guys did help me figure it out. I have diabled the service with not side effects. Thank you. "Ray" wrote: <span style="color:blue"> > =?Utf-8?B?TWljaGFlbA==?= <Michael@discussions.microsoft.com> wrote: > <span style="color:green"> > > I have an unknown running process on my computer called "Andrea RT > > Filters Service". It runs as a Windows servce on start up. I > > googled it and come up with "Andrea Electronics Corporation". > > When I contacted them to see if I could get some information about > > the application. they replied that the do not own or distrubute > > any application by this name. I have stopped the service and > > disabled it and there seems to be no side effects. Can someone > > please tell me what this process is?</span> > > The same or similar process, aertsrv.exe, was installed on my system > when I updated my Realtek audio drivers. I disabled it and as far as I > can tell all the audio functions still work. > > -- > Ray > (remove the Xs to reply) > </span> Quote Link to comment Share on other sites More sharing options...
Guest Ray Posted March 27, 2008 Share Posted March 27, 2008 =?Utf-8?B?TWljaGFlbA==?= <Michael@discussions.microsoft.com> wrote: <span style="color:blue"> > I bought my computer from Dell and on thier drivers disk I > installed the Realtek Audio drivers. But why would they say they > don't own or distribute this application? Anyway, you guys did > help me figure it out. I have diabled the service with not side > effects. Thank you.</span> Probably your inquiry was routed to someone who isn't up to date on their products. My system is also a Dell; I had downloaded the update from Dell. -- Ray (remove the Xs to reply) Quote Link to comment Share on other sites More sharing options...
Guest Michael Posted March 27, 2008 Share Posted March 27, 2008 Well maybe they are in the wrong business. Thank you for all your help!! "Ray" wrote: <span style="color:blue"> > =?Utf-8?B?TWljaGFlbA==?= <Michael@discussions.microsoft.com> wrote: > <span style="color:green"> > > I bought my computer from Dell and on thier drivers disk I > > installed the Realtek Audio drivers. But why would they say they > > don't own or distribute this application? Anyway, you guys did > > help me figure it out. I have diabled the service with not side > > effects. Thank you.</span> > > Probably your inquiry was routed to someone who isn't up to date on > their products. My system is also a Dell; I had downloaded the update > from Dell. > > -- > Ray > (remove the Xs to reply) > </span> Quote Link to comment Share on other sites More sharing options...
