PKI (CA Hierarchy) and Hyper-V pros and cons
Guest hypnotix911
Enterprise three-tier CA hierarchy on virtual machines?
Or any part of hierarchy (offline or online CAs )? Is it bad idea?
Any thoughts?
Tnx a lot.
Guest Dobromir Todorov
I don't think it is a bad idea - actually, considering the amount of
computational resources required on a CA, it is probably a good idea to have
all of them on small virtual machines.
The only thing that comes to mind is the fact that the CA private key and
other sensitive information better be stored on HSMs (should they be
supported on VM - which I doubt), or SmartCards (these are supported, if
connected to a USB slot). If the private key or other sensitive info is
stored locally on the VM, considering the fact that the VM is just a file,
then stealing the file is equivalent to breaking phusical security on real
servers.
HTH,
Dobromir
Learn more about Security and Identity Management:
Visit http://www.iamechanics.com
"hypnotix911" <hypnotix911@yahoo.com> wrote in message
news:OC9JVIqkIHA.4076@TK2MSFTNGP05.phx.gbl...<span style="color:blue">
> Any thoughts?
> Tnx a lot.
Guest Brian Komar \(MVP\)
Only if you use a network attached HSM to protect the CA private keys
Brian
> Any thoughts?
> Tnx a lot.
Guest hypnotix911
Thank you both,
but what about using bitlocker on VM files?
(we don't have a budget for HSM)
> Any thoughts?
> Tnx a lot.
That does not protect the private keys.
Any body who is local Admin can:
1) Export the CA's private key and certificate
2) Import it into any computer they want
3) Issue a certificate that your org trusts and cannot revoke from the CA
console
What type of business are you in. Are you sure that you are making the right
decision.
But, to summarize, BitLocker does not replace a HSM
Brian
news:O7XW9MAlIHA.5820@TK2MSFTNGP04.phx.gbl...<span style="color:blue">
> Thank you both,
> news:OC9JVIqkIHA.4076@TK2MSFTNGP05.phx.gbl...<span style="color:green">
>> Any thoughts?
>> Tnx a lot.
>></span>
