Guest recommend3 Posted April 7, 2008 Posted April 7, 2008 Iv'e installed avg ,it works but their are two icons,on is a complete test,how to i remove it? Quote
Guest Gordon Posted April 7, 2008 Posted April 7, 2008 "recommend3" <recommend3@gmail.com> wrote in message news:665c92c0-cf60-4275-a441-a90729b4b345@w5g2000prd.googlegroups.com...<span style="color:blue"> > Iv'e installed avg ,it works but their are two icons,on is a complete > test,how to i remove it?</span> When the complete test is finished, the icon will disappear... Quote
Guest .Joe Posted April 7, 2008 Posted April 7, 2008 recommend3;675015 Wrote: <span style="color:blue"> > Iv'e installed avg ,it works but their are two icons,on is a complete > test,how to i remove it?</span> If you're simply asking to remove the icons from your desktop, just drag them to the recycle bin. Then empty the recycle bin, that should take care of it for you. -- .Joe _[image: http://uswave.net/vistax64/joetmvx64.png] (\"http://www.vistax64.com\")_ _ ::Click_here_for_the_Vista_Forums:: (\"http://www.vistax64.com/index.php?referrerid=17621\")_ _Geekbench_Score:_4050 (\"http://browse.geekbench.ca/geekbench2/view/42901\")_ _CPU-Z_Verified (\"http://valid.x86-secret.com/show_oc.php?id=323179\")_ _ _ Quote
Guest robinb Posted April 7, 2008 Posted April 7, 2008 you are suppose to have 2 icons when it does a scan. When it is done the 2nd icon will go away robin "recommend3" <recommend3@gmail.com> wrote in message news:665c92c0-cf60-4275-a441-a90729b4b345@w5g2000prd.googlegroups.com...<span style="color:blue"> > Iv'e installed avg ,it works but their are two icons,on is a complete > test,how to i remove it? </span> Quote
