Guest Anthony Wieser Posted April 21, 2008 Posted April 21, 2008 I've had a customer have problems installing our program RIP Vinyl (www.ripvinyl.com) on his Vista Home system, but haven't had this from any of our other users. This customer reports that our installer (a wrapper that runs msiexec) gives the error return 1625 which translates as ERROR_INSTALL_PACKAGE_REJECTED As it's not possible (so far as I know) to set a security policy under Vista Home, that doesn't seem to be the problem. I offered to help him via microsoft messenger, but when he tried to install that, he got the same error message, so it's obviously a problem with his system configuration, and not our installer. In the end he resolved the problem, by switching off user access control on his vista system, at which point it installs correctly. He assures me that the elevation dialog didn't appear during the install when UAC was switched on (whereas it does on my systems which are Vista Business). His user account in not a limited account; it's an administrator account. Has anyone run across this strange behaviour of the elevation dialog not being shown during an install when it should be? Anthony Wieser Wieser Software Ltd Quote
Guest Mick Murphy Posted April 21, 2008 Posted April 21, 2008 RE: Vista Home UAC prevents installation of programs/Elevation dialog The Admin account that you are using is not a "true" Admin Account like in XP. Have a read of the link below. Also, for installation try Right-clicking on the setup.exe of the Program> Run as Admin http://support.microsoft.com/Default.aspx?kbid=942956 -- Mick Murphy - Qld - Australia "Anthony Wieser" wrote: <span style="color:blue"> > I've had a customer have problems installing our program RIP Vinyl > (www.ripvinyl.com) on his Vista Home system, but haven't had this from any > of our other users. > > This customer reports that our installer (a wrapper that runs msiexec) gives > the error return 1625 which translates as ERROR_INSTALL_PACKAGE_REJECTED > > As it's not possible (so far as I know) to set a security policy under Vista > Home, that doesn't seem to be the problem. > > I offered to help him via microsoft messenger, but when he tried to install > that, he got the same error message, so it's obviously a problem with his > system configuration, and not our installer. > > In the end he resolved the problem, by switching off user access control > on his vista system, at which point it installs correctly. He assures me > that the elevation dialog didn't appear during the install when UAC was > switched on (whereas it does on my systems which are Vista Business). His > user account in not a limited account; it's an administrator account. > > Has anyone run across this strange behaviour of the elevation dialog not > being shown during an install when it should be? > > Anthony Wieser > Wieser Software Ltd > > </span> Quote
