Certificates, Autoenrollment, Credential Roaming and User's PersonalStore
Guest BillL
Hi,
I have a user cert set up for autoenrollment. The cert is published
in AD and the "Do not automatically reenroll if a duplicate
certificate exists in Active Directory" checkbox is checked. The CA
is a Windows 2003 Enterprise CA. Credential Roaming is also set up in
the environemnt.
Autoenrollment and credential roaming seem to be working fine but I do
encounter an issue when a workstation is reimaged or the certs are
deleted from the user's personal store on a workstation. After one of
these occurences the user's personal store never gets a copy of the
user's existing certs on that workstation.
The only way to populate the store is to have them issued a new
certificate by deleting the user's certs from the CA and their AD
object. After this the autoenrollment process will populate the
personal store with a brand new user certificate.
I'd rather not generate a new cert each time. Is there a way to get
the existing certs automatically copied to the user's personal store
on a workstation?
Thanks for your help.
Bill
  • Replies 4
Guest Brian Komar \(MVP\)
Re: Certificates, Autoenrollment, Credential Roaming and User's Personal Store
Some answers inline...
"BillL" <wlawn@yahoo.com> wrote in message
news:f23b89e9-1ab6-436e-9654-04a445d35fa0@k37g2000hsf.googlegroups.com...<span style="color:blue">
> Hi,
> the environemnt.</span>
If you are using certificate roaming there really is no need to enable the
certificate exists in Active Directory" .
What type of certs are you issuing? Signing? Encryption?<span style="color:blue">
> user's existing certs on that workstation.</span>
Yes, this is due to the duplicate certificate in AD setting. If you manually
delete the certificate in the user's store, this is the expected and proper
behavior.
You have chosen to explicity delete the certificate from the store.
A re-image should not have this behavior. Much like logging on to a new
computer, the certificates will roam to the new profile on the new computer.
Same as logging onto a new computer. Verify that CRS is correctly
configured.
> personal store with a brand new user certificate.</span>
You do not ahve to delete the certs from the AD. You would have to delete
them from the AD object though due to the certificate template setting.
> on a workstation?</span>
It should work if you re-image the computer. If the user or help desk is
telling the user to delete the certificate from the store, then you have
deleted the certificate and will have to re-enroll.
> Bill </span>
Guest BillL
Re: Certificates, Autoenrollment, Credential Roaming and User'sPersonal Store
On Apr 29, 11:26 am, "Brian Komar \(MVP\)"
<brian.komar.nos...@nospam.identit.ca> wrote:<span style="color:blue">
> "BillL" <wl...@yahoo.com> wrote in message
><span style="color:green">
> > Hi,</span>
> behavior.
> configured.
> > Bill- Hide quoted text -</span>
> - Show quoted text -</span>
Hi Brian,
Thanks for your assistance.
I had checked the "Do not automatically reenroll if a duplicate
certificate exists in AD" check box because users were getting
multiple certs if I didn't have this checked. I was trying to
minimize the number of certs that were generated for each user.
The cert purpose is "Signature and Encryption". The Description of
Application Policies shows Encrypting File System, Secure Email and
Client Authentication. We are currently only using it for client
authentication.
When you say "verify that CRS is correctly configured" are you talking
about the group policy settings for enabling autoenrollment? If so I
do not have "Automatic Certificate Request Settings" configured. I do
have "Autoenrollment Settings" configured for users and computers at
the domain level. These are set to "Enroll Certifcates
automatically". I have both the "Renew expired certifcates, ..." and
"Update certificates that use templates" checked.
By the way your book has been a great help to me as well.
Thanks again.
I am talking about Credential Roaming Service
This is what you need to deploy
http://technet2.microsoft.com/WindowsServe...004baa1033.mspx
Brian
news:aa9cf8e9-f466-4e4f-a9fe-30742f4fab82@m73g2000hsh.googlegroups.com...
> > Hi,</span>
> manually
> proper
> behavior.
> computer.
> configured.
Hi Brian,
authentication.
Thanks again.
Guest BillL
On Apr 30, 2:04 am, "Brian Komar \(MVP\)"
> This is what you need to deployhttp://technet2.microsoft.com/WindowsServer/en/Library/673d5152-1bc8-...
> Brian
> On Apr 29, 11:26 am, "Brian Komar (MVP)"
> <brian.komar.nos...@nospam.identit.ca> wrote:<span style="color:green">
> > Some answers inline...</span>
> > "BillL" <wl...@yahoo.com> wrote in message</span>
> >news:f23b89e9-1ab6-436e-9654-04a445d35fa0@k37g2000hsf.googlegroups.com...</span>
><span style="color:green"><span style="color:darkred">
> > > Hi,</span></span>
> > > the environemnt.</span></span>
> > certificate exists in Active Directory" .</span>
> > What type of certs are you issuing? Signing? Encryption?</span>
> > > user's existing certs on that workstation.</span></span>
> > manually
> > proper
> > behavior.
> > You have chosen to explicity delete the certificate from the store.</span>
> > computer.
> > configured.</span>
> > > personal store with a brand new user certificate.</span></span>
> > them from the AD object though due to the certificate template setting.</span>
> > > on a workstation?</span></span>
> > deleted the certificate and will have to re-enroll.</span>
> > > Bill- Hide quoted text -</span></span>
> Hi Brian,
> authentication.
> Thanks again.- Hide quoted text -
I didn't make the reference of CRS to Credential Roaming Services.
Yes, I have implemented that and it seems to be working in most
cases. When we reimage a workstation, it is reimaged with the same
computer name. Could that affect whether the user certifcates are
copied down to the "new" workstation?
Thanks.
