Guest timtim Posted May 22, 2008 Posted May 22, 2008 I am using XP PRO Meadia Center Edition. I recently added a harddrive. Now i am getting this,Chassis intrusion detected. This typically does NOT indicate a hardware failure. 1. Contact your Help Desk if you did not personally open your chassis. 2. Enter System Setup & Set Chassis Intrusion to 'Clear' I have went to setup and it askes me for a (setup password) but my password dosn't work. Yes i am the administrator and in fact the only user of this computor how do i get in to reset the password or reset to clear or reset to no password required? -- timtim Quote
Guest Paul Adare Posted May 22, 2008 Posted May 22, 2008 On Thu, 22 May 2008 11:09:00 -0700, timtim wrote: <span style="color:blue"> > I am using XP PRO Meadia Center Edition. I recently added a harddrive. Now i > am getting this,Chassis intrusion detected. This typically does NOT indicate > a hardware failure. > 1. Contact your Help Desk if you did not personally open your chassis. > 2. Enter System Setup & Set Chassis Intrusion to 'Clear' > I have went to setup and it askes me for a (setup password) but my password > dosn't work. > Yes i am the administrator and in fact the only user of this computor > how do i get in to reset the password or reset to clear or reset to no > password required?</span> This is not an operating system message, it is coming from the BIOS on your computer. Contact the computer manufacturer's support for help on this. -- Paul Adare http://www.identit.ca You depend too much on computers for information. Quote
