Guest nid Posted May 30, 2008 Posted May 30, 2008 Hi, Just saw your post when I was searching for a resolution to the very same problem. I managed to enable remote access to writing CDs and DVDs by doing the following: - Open a command prompt and run gpedit - Navigate in the resulting window to Computer Configuration > Administrative Templates > System > Removable Storage Access - In there you will find a setting called "All Removable Storage: Allow direct access in remote sessions". Enable this setting. Hope this helps. Best Regards nid -- nid Quote
