Guest BillyJay Posted June 4, 2008 Posted June 4, 2008 I can't see hidden files due to a worm. I delete this worm but the problem is remaining! What can i do for this? Quote
Guest Carey Frisch [MVP] Posted June 4, 2008 Posted June 4, 2008 Once your PC is infected with a computer virus or worm, your computer becomes compromised and nothing less than a reinstallation of the operating system is going to work. Yes, you can scan and eliminate the initial virus, but you generally cannot undo the damage caused by the virus to the system files. You'll need to reformat your hard drive and then reinstall your Windows operating system. After restoring your system, consider installing a good antivirus program, such as Windows OneCare. You can try it absolutely FREE for 90 days. http://onecare.live.com/standard/en-us/default.htm -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows Vista Enthusiast --------------------------------------------------------------- "BillyJay" <BillyJay@discussions.microsoft.com> wrote in message news:9E992F23-E5EC-44B3-B8E5-659C1DB554ED@microsoft.com... I can't see hidden files due to a worm. I delete this worm but the problem is remaining! What can i do for this? Quote
Guest Malke Posted June 4, 2008 Posted June 4, 2008 BillyJay wrote: <span style="color:blue"> > I can't see hidden files due to a worm. I delete this worm but the problem > is remaining! What can i do for this?</span> Go through these general malware removal steps systematically - http://www.elephantboycomputers.com/page2....emoving_Malware Include scanning with David Lipman's Multi_AV and follow instructions to do all scans in Safe Mode. Please see the special Notes regarding using Multi_AV in Vista. http://www.elephantboycomputers.com/page2.html#Multi-AV - instructions http://tinyurl.com/yoeru3 - download link and more instructions You can also check to see if there are targeted removal steps for your malware here: Bleeping Computer removal how-to's - http://www.bleepingcomputer.com/forums/forum55.html When all else fails, get guided help. Choose one of the specialty forums listed at the first link. Register and read its posting FAQ. DO NOT POST LOGS IN THE MS NEWSGROUPS. Standard disclaimer: I can't see and test your computer myself, so these are just suggestions based on many years of being a professional computer tech; suggestions based on what you've written. You should not take my suggestions as a definitive diagnosis. If you can't do the work yourself (and there is no shame in admitting this isn't your cup of tea), take the machine to a professional computer repair shop (not your local equivalent of BigComputerStore/GeekSquad). Please be aware that not all local shops are skilled at removing malware and even if they are, your computer may be so infested that Windows will need to be clean-installed. If possible, have all your data backed up before you take the machine into a shop. Malke -- MS-MVP Elephant Boy Computers www.elephantboycomputers.com Don't Panic! Quote
Guest Mick Murphy Posted June 5, 2008 Posted June 5, 2008 Security Programs I use; and how to use them to remove problems. Vista’s Firewall works very well. http://www.avast.com/eng/download-avast-home.html Avast Anti-Virus is Vista compatible (32bit and 64bit Versions), FREE, auto-updating, and a low resources user of your computer. And, only have 1(one) Anti-Virus installed / running on your computer at any one time.. Conflicts may occur if you have more than 1(one). http://www.spybot.info/en/index.html Spybot Search & Destroy 1.5.2 is a very good, FREE Anti-Spyware Program. Download, install, update, and immunize your System with it. Then SCAN with it. Update it, and scan your System once a fortnight. http://www.javacoolsoftware.com/spywareblaster.html SpywareBlaster 4.0 is a non-intrusive, FREE Anti-Spyware Program that runs in the background (no scanning by you!). Update it once a fortnight, and let it do its work in the background! Important re: Safe Mode If you happen to find a problem that you can’t uninstall / delete, reboot the computer, and go into Safe Mode. To get into Safe mode, tap F8 right at Power On / Startup, and use UP arrow key to get to Safe Mode, then hit ENTER. RESCAN your computer with Avast and Spybot S & D while in Safe Mode. -- Mick Murphy - Qld - Australia "BillyJay" wrote: <span style="color:blue"> > I can't see hidden files due to a worm. I delete this worm but the problem is > remaining! What can i do for this?</span> Quote
Guest FromTheRafters Posted June 6, 2008 Posted June 6, 2008 You can't see hidden files!? That is perfectly normal. ....but seriously, knowing which worm (and which detector detected it as such) is a very helpful fact to give in a post such as yours. Otherwise, you're stuck with the more general procedures others have outlined. You may end up using Malke's and/or Carey's methods anyway in the end. Some worms make Carey's method your only solution. "BillyJay" <BillyJay@discussions.microsoft.com> wrote in message news:9E992F23-E5EC-44B3-B8E5-659C1DB554ED@microsoft.com...<span style="color:blue"> >I can't see hidden files due to a worm. I delete this worm but the problem >is > remaining! What can i do for this? </span> Quote
