Guest spyware.blockers@gmail.com Posted June 6, 2008 Posted June 6, 2008 Hello there , I have a a slight problem in that my Laptop is not even loading and going straight to the blue screen of death . Here's the details : Message from windows saying I'd been infected with spyware. Ran adaware - it found a trojan of some kind butwas unable to delete the file. Would not let me connect to the internet to update adaware files or windows Restarted and it blue screened with the following message. PAGE_FAULT_IN_NONPAGED_AREA STOP: 0X0000008E(0XC0000005,0X00000000,0XF818CC9C,0X00000000) Also tried starting in safe mode but same happened Also tried 'last known working configuration' it lasted a few seconds then crashed. Thanks in anticiaption for you time and help. Julia18 Thank you. ----------------------------------------------------------------------------------------------------------------------------------------------------- all about spyware site : http://syubrawi.com/spyware-blockers http://fantastic-galleries.net/spyware Quote
Guest David H. Lipman Posted June 6, 2008 Posted June 6, 2008 From: <spyware.blockers@gmail.com> | Hello there , | | I have a a slight problem in that my Laptop is not even loading and | going straight to the blue screen of death . | | Here's the details : | | Message from windows saying I'd been infected with spyware. | | Ran adaware - it found a trojan of some kind butwas unable to delete | the file. | | Would not let me connect to the internet to update adaware files or | windows | | Restarted and it blue screened with the following message. | | PAGE_FAULT_IN_NONPAGED_AREA | | STOP: 0X0000008E(0XC0000005,0X00000000,0XF818CC9C,0X00000000) | Also tried starting in safe mode but same happened | | Also tried 'last known working configuration' it lasted a few seconds | then crashed. | | Thanks in anticiaption for you time and help. | | Julia18 | | Thank you. | I don't know... Your system may be hosed. -- Dave http://www.claymania.com/removal-trojan-adware.html Multi-AV - http://www.pctipp.ch/downloads/dl/35905.asp Quote
