Guest mjm1234 Posted June 7, 2008 Posted June 7, 2008 have a new laptop trying to set it up with our wireless interenet on our desktop. it is asking for a passkey. i have a network key but that doesn't seem to be working. where can i find my wireless network settings on my desktop to put into my laptop. Quote
Guest Mick Murphy Posted June 7, 2008 Posted June 7, 2008 You will find the settings in the Router. Network name and Security Key. -- Mick Murphy - Qld - Australia "mjm1234" wrote: <span style="color:blue"> > have a new laptop trying to set it up with our wireless interenet on our > desktop. it is asking for a passkey. i have a network key but that doesn't > seem to be working. where can i find my wireless network settings on my > desktop to put into my laptop.</span> Quote
Guest mjm1234 Posted June 7, 2008 Posted June 7, 2008 how do i get in the router? "Mick Murphy" wrote: <span style="color:blue"> > You will find the settings in the Router. Network name and Security Key. > -- > Mick Murphy - Qld - Australia > > > "mjm1234" wrote: > <span style="color:green"> > > have a new laptop trying to set it up with our wireless interenet on our > > desktop. it is asking for a passkey. i have a network key but that doesn't > > seem to be working. where can i find my wireless network settings on my > > desktop to put into my laptop.</span></span> Quote
Guest Mick Murphy Posted June 7, 2008 Posted June 7, 2008 If you don't know how to get into the Router, it is time for you to get a Computer Technician to set things up properly for you. I am not knocking you; it is too hard to explain to you here, in a way that you would understand. -- Mick Murphy - Qld - Australia "mjm1234" wrote: <span style="color:blue"> > how do i get in the router? > > "Mick Murphy" wrote: > <span style="color:green"> > > You will find the settings in the Router. Network name and Security Key. > > -- > > Mick Murphy - Qld - Australia > > > > > > "mjm1234" wrote: > > <span style="color:darkred"> > > > have a new laptop trying to set it up with our wireless interenet on our > > > desktop. it is asking for a passkey. i have a network key but that doesn't > > > seem to be working. where can i find my wireless network settings on my > > > desktop to put into my laptop.</span></span></span> Quote
Guest Malke Posted June 7, 2008 Posted June 7, 2008 mjm1234 wrote: <span style="color:blue"> > have a new laptop trying to set it up with our wireless interenet on our > desktop. it is asking for a passkey. i have a network key but that > doesn't > seem to be working. where can i find my wireless network settings on my > desktop to put into my laptop.</span> You can use the free WirelessNetView utility from Nirsoft: http://www.nirsoft.net/utils/wireless_network_view.html Or you can look on your router because in some routers the passphrase (encryption key you need to enter on your laptop to join the wireless network) is in clear text. To get into the router's configuration utility, open a browser such as Internet Explorer or Firefox and in the addressbar type it's IP address. This example is for a Linksys router; if you don't have a Linksys refer to your router manual or your router mftr.'s website for its defaults. http://192.168.1.1 [enter] (this is the router's default IP address, which varies from router to router so check your manual) This will bring you to router's login screen. The default username is left blank and the Linksys default password is "admin" without the quotes. Enter that information. You are now in the router's configuration utility. Your configuration utility may differ slightly from mine. Now click on the Wireless link at the top of the page to see the SSID (network name) and from there, click on Wireless Security to see the encryption level and passphrase used. Malke -- MS-MVP Elephant Boy Computers www.elephantboycomputers.com Don't Panic! Quote
