Guest Philip Michener Posted June 11, 2008 Posted June 11, 2008 I was recently infected with the Vundo Trojan and have had problems ridding myself of it. Windows Malicious Software Removal finds the trojan, but gives the message that it was only partially removed. Then tell me to run a full scan with antivirus software to complete the removal. I have tried McAfee, XSoft, Lavasoft, and Spydoctor, but they all fail to find the remaining files. Meanwhile, system gets reinfected, and popups start all over again. Anyone have suggestions as to how I can finally kill this bastard! Quote
Guest Malke Posted June 11, 2008 Posted June 11, 2008 Philip Michener <Byesville, Ohio> wrote: <span style="color:blue"> > I was recently infected with the Vundo Trojan and have had problems > ridding myself of it. > > Windows Malicious Software Removal finds the trojan, but gives the > message that it was only partially removed. Then tell me to run a > full scan with antivirus software to complete the removal. > > I have tried McAfee, XSoft, Lavasoft, and Spydoctor, but they all fail > to find the remaining files. > > Meanwhile, system gets reinfected, and popups start all over again. > > Anyone have suggestions as to how I can finally kill this bastard!</span> Vundo infections can be, as you have discovered, extremely difficult to remove. Please have your data backed up in case you need to reinstall Windows. You may not need to but it is always wise to be prepared. Since you've tried other methods, your next step is to get guided help at one of the specialty forums listed below (in no particular order). Choose one, register, read its posting FAQ, and then post according to its guidelines. PLEASE DO NOT POST LOGS HERE IN THE MS NEWSGROUPS. http://aumha.net/ - Click on the HijackThis forum. Read the announcement and the stickies first . http://www.atribune.org/forums/index.php?showforum=9 http://aumha.net/viewforum.php?f=30 http://www.bleepingcomputer.com/forums/forum22.html http://castlecops.com/forum67.html http://www.dslreports.com/forum/cleanup http://www.cybertechhelp.com/forums/forumdisplay.php?f=25 http://www.geekstogo.com/forum/Malware_Rem...o_Here-f37.html http://gladiator-antivirus.com/forum/index.php?showforum=170 http://spywarewarrior.com/viewforum.php?f=5 http://forums.techguy.org/54-security/ http://forums.tomcoyote.org/ Malke -- MS-MVP Elephant Boy Computers www.elephantboycomputers.com Don't Panic! Quote
Guest ~BD~ Posted June 11, 2008 Posted June 11, 2008 In the thread 'Spyware' on 7 June Malke said "Include scanning with David Lipman's Multi_AV" David Lipman never recommends the AumHa forums in his 'advice', yet on this occasion Malke does so. It's just an interesting (to me) observation. Mr Lipman will not explain why he does not recommend AumHa. Any thoughts about this from anyone? BD "Malke" <malke@invalid.invalid> wrote in message news:eCAZuz8yIHA.4816@TK2MSFTNGP03.phx.gbl...<span style="color:blue"> > Philip Michener <Byesville, Ohio> wrote: ><span style="color:green"> >> I was recently infected with the Vundo Trojan and have had problems >> ridding myself of it. >> >> Windows Malicious Software Removal finds the trojan, but gives the >> message that it was only partially removed. Then tell me to run a >> full scan with antivirus software to complete the removal. >> >> I have tried McAfee, XSoft, Lavasoft, and Spydoctor, but they all fail >> to find the remaining files. >> >> Meanwhile, system gets reinfected, and popups start all over again. >> >> Anyone have suggestions as to how I can finally kill this bastard!</span> > > Vundo infections can be, as you have discovered, extremely difficult to > remove. Please have your data backed up in case you need to reinstall > Windows. You may not need to but it is always wise to be prepared. > > Since you've tried other methods, your next step is to get guided help at > one of the specialty forums listed below (in no particular order). Choose > one, register, read its posting FAQ, and then post according to its > guidelines. PLEASE DO NOT POST LOGS HERE IN THE MS NEWSGROUPS. > > http://aumha.net/ - Click on the HijackThis forum. Read the announcement > and > the stickies first . > http://www.atribune.org/forums/index.php?showforum=9 > http://aumha.net/viewforum.php?f=30 > http://www.bleepingcomputer.com/forums/forum22.html > http://castlecops.com/forum67.html > http://www.dslreports.com/forum/cleanup > http://www.cybertechhelp.com/forums/forumdisplay.php?f=25 > http://www.geekstogo.com/forum/Malware_Rem...o_Here-f37.html > http://gladiator-antivirus.com/forum/index.php?showforum=170 > http://spywarewarrior.com/viewforum.php?f=5 > http://forums.techguy.org/54-security/ > http://forums.tomcoyote.org/ > > Malke > -- > MS-MVP > Elephant Boy Computers > www.elephantboycomputers.com > Don't Panic! > </span> Quote
Guest David H. Lipman Posted June 11, 2008 Posted June 11, 2008 From: "Philip Michener" <Byesville, Ohio> | I was recently infected with the Vundo Trojan and have had problems | ridding myself of it. | | Windows Malicious Software Removal finds the trojan, but gives the | message that it was only partially removed. Then tell me to run a | full scan with antivirus software to complete the removal. | | I have tried McAfee, XSoft, Lavasoft, and Spydoctor, but they all fail | to find the remaining files. | | Meanwhile, system gets reinfected, and popups start all over again. | | Anyone have suggestions as to how I can finally kill this bastard! Perform the following... If that does not work post in an Expert Forum as Malke suggested. 4 phase answer... Perform Part 1, Part 2 and Part 3 and alternately part 4 It is suggested that you execute each tool in Normal Mode then in Safe Mode. If you are using any version of Sun Java that is prior to JRE Version 6.0, then you are strongly urged to remove any/all versions. There are numerous vulnerabilities in them and they are actively being exploited. It is highly suggested that you update to the latest version which is Sun Java JRE/JSE Version 6.0 update 6 (jre 6u6) Simple check, look under... C:\Program Files\Java The only folder under that folder should be the latest version. Such as... C:\Program Files\Java\jre1.6.0_06 http://java.sun.com/javase/downloads/index.jsp http://www.java.com/en/download/manual.jsp FYI: http://sunsolve.sun.com/search/document.do...y=1-26-102557-1 http://sunsolve.sun.com/search/document.do...y=1-26-102622-1 http://sunsolve.sun.com/search/document.do...y=1-26-102648-1 http://sunsolve.sun.com/search/document.do...y=1-26-102729-1 http://sunsolve.sun.com/search/document.do...y=1-26-102732-1 http://sunsolve.sun.com/search/document.do...y=1-26-102760-1 Part 1 ------------ Download Adware-Virtumundo Removal Tool -- http://secured2k.home.comcast.net/tools/VirtumundoBeGone.exe Part 2 ------------ Download Atribune's VUNDOFIX.EXE http://www.atribune.org/ccount/click.php?id=4 Save VUNDOFIX.EXE to "C:\" ( C:\VUNDOFIX.EXE ) and execute it from there. Part 3 ------------ Malwarebytes Anti-Malware http://www.malwarebytes.org/mbam/program/mbam-setup.exe Part 4 ------------ Norman Vundo removal tool. http://download.norman.no/public/Norman_Vundo_Cleaner.exe http://www.norman.com/Virus/Virus_removal_tools/52658/en Please report back your results -- Dave http://www.claymania.com/removal-trojan-adware.html Multi-AV - http://www.pctipp.ch/downloads/dl/35905.asp Quote
Guest FromTheRafters Posted June 11, 2008 Posted June 11, 2008 Sure. He is under no obligation to explain, so why should he? "~BD~" <~BD~@nospam.invalid> wrote in message news:e2W4tW$yIHA.3968@TK2MSFTNGP04.phx.gbl...<span style="color:blue"> > In the thread 'Spyware' on 7 June Malke said "Include scanning with David > Lipman's Multi_AV" > > David Lipman never recommends the AumHa forums in his 'advice', yet on > this occasion Malke does so. > > It's just an interesting (to me) observation. Mr Lipman will not explain > why he does not recommend AumHa. > > Any thoughts about this from anyone? > > BD > > "Malke" <malke@invalid.invalid> wrote in message > news:eCAZuz8yIHA.4816@TK2MSFTNGP03.phx.gbl...<span style="color:green"> >> Philip Michener <Byesville, Ohio> wrote: >><span style="color:darkred"> >>> I was recently infected with the Vundo Trojan and have had problems >>> ridding myself of it. >>> >>> Windows Malicious Software Removal finds the trojan, but gives the >>> message that it was only partially removed. Then tell me to run a >>> full scan with antivirus software to complete the removal. >>> >>> I have tried McAfee, XSoft, Lavasoft, and Spydoctor, but they all fail >>> to find the remaining files. >>> >>> Meanwhile, system gets reinfected, and popups start all over again. >>> >>> Anyone have suggestions as to how I can finally kill this bastard!</span> >> >> Vundo infections can be, as you have discovered, extremely difficult to >> remove. Please have your data backed up in case you need to reinstall >> Windows. You may not need to but it is always wise to be prepared. >> >> Since you've tried other methods, your next step is to get guided help at >> one of the specialty forums listed below (in no particular order). Choose >> one, register, read its posting FAQ, and then post according to its >> guidelines. PLEASE DO NOT POST LOGS HERE IN THE MS NEWSGROUPS. >> >> http://aumha.net/ - Click on the HijackThis forum. Read the announcement >> and >> the stickies first . >> http://www.atribune.org/forums/index.php?showforum=9 >> http://aumha.net/viewforum.php?f=30 >> http://www.bleepingcomputer.com/forums/forum22.html >> http://castlecops.com/forum67.html >> http://www.dslreports.com/forum/cleanup >> http://www.cybertechhelp.com/forums/forumdisplay.php?f=25 >> http://www.geekstogo.com/forum/Malware_Rem...o_Here-f37.html >> http://gladiator-antivirus.com/forum/index.php?showforum=170 >> http://spywarewarrior.com/viewforum.php?f=5 >> http://forums.techguy.org/54-security/ >> http://forums.tomcoyote.org/ >> >> Malke >> -- >> MS-MVP >> Elephant Boy Computers >> www.elephantboycomputers.com >> Don't Panic! >></span> > > </span> Quote
Guest David H. Lipman Posted June 11, 2008 Posted June 11, 2008 From: "FromTheRafters" <Erratic@ne.rr.com> | Sure. He is under no obligation to explain, so why should he? | -- Dave http://www.claymania.com/removal-trojan-adware.html Multi-AV - http://www.pctipp.ch/downloads/dl/35905.asp Quote
Guest ~BD~ Posted June 13, 2008 Posted June 13, 2008 Thank you. I've assumed that was a rhetorical question. Both Mr Lipman and Malke post regular replies in this group. That is a fact. No-one is under any obligation to explain anything nor, indeed, to tell the truth. In my opinion, witholding an explanation merely mudies the water, so to speak. BD "FromTheRafters" <Erratic@ne.rr.com> wrote in message news:eNY8xCBzIHA.552@TK2MSFTNGP06.phx.gbl...<span style="color:blue"> > Sure. He is under no obligation to explain, so why should he? > > "~BD~" <~BD~@nospam.invalid> wrote in message > news:e2W4tW$yIHA.3968@TK2MSFTNGP04.phx.gbl...<span style="color:green"> >> In the thread 'Spyware' on 7 June Malke said "Include scanning with David >> Lipman's Multi_AV" >> >> David Lipman never recommends the AumHa forums in his 'advice', yet on >> this occasion Malke does so. >> >> It's just an interesting (to me) observation. Mr Lipman will not explain >> why he does not recommend AumHa. >> >> Any thoughts about this from anyone? >> >> BD >> >> "Malke" <malke@invalid.invalid> wrote in message >> news:eCAZuz8yIHA.4816@TK2MSFTNGP03.phx.gbl...<span style="color:darkred"> >>> Philip Michener <Byesville, Ohio> wrote: >>> >>>> I was recently infected with the Vundo Trojan and have had problems >>>> ridding myself of it. >>>> >>>> Windows Malicious Software Removal finds the trojan, but gives the >>>> message that it was only partially removed. Then tell me to run a >>>> full scan with antivirus software to complete the removal. >>>> >>>> I have tried McAfee, XSoft, Lavasoft, and Spydoctor, but they all fail >>>> to find the remaining files. >>>> >>>> Meanwhile, system gets reinfected, and popups start all over again. >>>> >>>> Anyone have suggestions as to how I can finally kill this bastard! >>> >>> Vundo infections can be, as you have discovered, extremely difficult to >>> remove. Please have your data backed up in case you need to reinstall >>> Windows. You may not need to but it is always wise to be prepared. >>> >>> Since you've tried other methods, your next step is to get guided help >>> at >>> one of the specialty forums listed below (in no particular order). >>> Choose >>> one, register, read its posting FAQ, and then post according to its >>> guidelines. PLEASE DO NOT POST LOGS HERE IN THE MS NEWSGROUPS. >>> >>> http://aumha.net/ - Click on the HijackThis forum. Read the announcement >>> and >>> the stickies first . >>> http://www.atribune.org/forums/index.php?showforum=9 >>> http://aumha.net/viewforum.php?f=30 >>> http://www.bleepingcomputer.com/forums/forum22.html >>> http://castlecops.com/forum67.html >>> http://www.dslreports.com/forum/cleanup >>> http://www.cybertechhelp.com/forums/forumdisplay.php?f=25 >>> http://www.geekstogo.com/forum/Malware_Rem...o_Here-f37.html >>> http://gladiator-antivirus.com/forum/index.php?showforum=170 >>> http://spywarewarrior.com/viewforum.php?f=5 >>> http://forums.techguy.org/54-security/ >>> http://forums.tomcoyote.org/ >>> >>> Malke >>> -- >>> MS-MVP >>> Elephant Boy Computers >>> www.elephantboycomputers.com >>> Don't Panic! >>></span> >> >></span> > > </span> Quote
Guest Leythos Posted June 13, 2008 Posted June 13, 2008 In article <#7J1pWVzIHA.2208@TK2MSFTNGP04.phx.gbl>, ~BD~@nospam.invalid says...<span style="color:blue"> > In my opinion, witholding an explanation merely mudies the water, so > to speak.</span> Withholding an explanation could also mean that there is nothing to add to the request or that there is nothing the person is willing to state about it for several reasons. -- - Igitur qui desiderat pacem, praeparet bellum. - Calling an illegal alien an "undocumented worker" is like calling a drug dealer an "unlicensed pharmacist" spam999free@rrohio.com (remove 999 for proper email address) Quote
Guest ~BD~ Posted June 13, 2008 Posted June 13, 2008 "Leythos" <void@nowhere.lan> wrote in message news:1213370206_60769@news.usenet.com...<span style="color:blue"> > In article <#7J1pWVzIHA.2208@TK2MSFTNGP04.phx.gbl>, ~BD~@nospam.invalid > says...<span style="color:green"> >> In my opinion, witholding an explanation merely mudies the water, so >> to speak.</span> > > Withholding an explanation could also mean that there is nothing to add > to the request or that there is nothing the person is willing to state > about it for several reasons. > > -- > - Igitur qui desiderat pacem, praeparet bellum. > - Calling an illegal alien an "undocumented worker" is like calling a > drug dealer an "unlicensed pharmacist" > spam999free@rrohio.com (remove 999 for proper email address) ></span> I'm sure you are right! Maybe you will comment on whether or not you feel AumHa is a 'safe' place to visit when one is seeking help and advice on computer related matters? Quote
Guest FromTheRafters Posted June 13, 2008 Posted June 13, 2008 It was, but your answer seems to be that he should explain because it bothers you that he doesn't explain. Maybe his integrity precludes him from commenting. Maybe his superiors have asked him not to comment. Maybe it seems redundant to him - yet another helpdesk among so many others (which really muddies the waters for those seeking help) If it turned out that he thinks that they are a bunch of clowns, how would that help you? That having been said, I think they and he are very helpful netizens. "~BD~" <~BD~@nospam.invalid> wrote in message news:%237J1pWVzIHA.2208@TK2MSFTNGP04.phx.gbl...<span style="color:blue"> > Thank you. I've assumed that was a rhetorical question. > > Both Mr Lipman and Malke post regular replies in this group. That is a > fact. No-one is under any obligation to explain anything nor, indeed, to > tell the truth. In my opinion, witholding an explanation merely mudies the > water, so to speak. > > BD > > "FromTheRafters" <Erratic@ne.rr.com> wrote in message > news:eNY8xCBzIHA.552@TK2MSFTNGP06.phx.gbl...<span style="color:green"> >> Sure. He is under no obligation to explain, so why should he? >> >> "~BD~" <~BD~@nospam.invalid> wrote in message >> news:e2W4tW$yIHA.3968@TK2MSFTNGP04.phx.gbl...<span style="color:darkred"> >>> In the thread 'Spyware' on 7 June Malke said "Include scanning with >>> David Lipman's Multi_AV" >>> >>> David Lipman never recommends the AumHa forums in his 'advice', yet on >>> this occasion Malke does so. >>> >>> It's just an interesting (to me) observation. Mr Lipman will not explain >>> why he does not recommend AumHa. >>> >>> Any thoughts about this from anyone? >>> >>> BD >>> >>> "Malke" <malke@invalid.invalid> wrote in message >>> news:eCAZuz8yIHA.4816@TK2MSFTNGP03.phx.gbl... >>>> Philip Michener <Byesville, Ohio> wrote: >>>> >>>>> I was recently infected with the Vundo Trojan and have had problems >>>>> ridding myself of it. >>>>> >>>>> Windows Malicious Software Removal finds the trojan, but gives the >>>>> message that it was only partially removed. Then tell me to run a >>>>> full scan with antivirus software to complete the removal. >>>>> >>>>> I have tried McAfee, XSoft, Lavasoft, and Spydoctor, but they all fail >>>>> to find the remaining files. >>>>> >>>>> Meanwhile, system gets reinfected, and popups start all over again. >>>>> >>>>> Anyone have suggestions as to how I can finally kill this bastard! >>>> >>>> Vundo infections can be, as you have discovered, extremely difficult to >>>> remove. Please have your data backed up in case you need to reinstall >>>> Windows. You may not need to but it is always wise to be prepared. >>>> >>>> Since you've tried other methods, your next step is to get guided help >>>> at >>>> one of the specialty forums listed below (in no particular order). >>>> Choose >>>> one, register, read its posting FAQ, and then post according to its >>>> guidelines. PLEASE DO NOT POST LOGS HERE IN THE MS NEWSGROUPS. >>>> >>>> http://aumha.net/ - Click on the HijackThis forum. Read the >>>> announcement and >>>> the stickies first . >>>> http://www.atribune.org/forums/index.php?showforum=9 >>>> http://aumha.net/viewforum.php?f=30 >>>> http://www.bleepingcomputer.com/forums/forum22.html >>>> http://castlecops.com/forum67.html >>>> http://www.dslreports.com/forum/cleanup >>>> http://www.cybertechhelp.com/forums/forumdisplay.php?f=25 >>>> http://www.geekstogo.com/forum/Malware_Rem...o_Here-f37.html >>>> http://gladiator-antivirus.com/forum/index.php?showforum=170 >>>> http://spywarewarrior.com/viewforum.php?f=5 >>>> http://forums.techguy.org/54-security/ >>>> http://forums.tomcoyote.org/ >>>> >>>> Malke >>>> -- >>>> MS-MVP >>>> Elephant Boy Computers >>>> www.elephantboycomputers.com >>>> Don't Panic! >>>> >>> >>></span> >> >></span> > > </span> Quote
Guest Leythos Posted June 13, 2008 Posted June 13, 2008 In article <#dlROxVzIHA.1772@TK2MSFTNGP03.phx.gbl>, ~BD~@nospam.invalid says...<span style="color:blue"> > > "Leythos" <void@nowhere.lan> wrote in message > news:1213370206_60769@news.usenet.com...<span style="color:green"> > > In article <#7J1pWVzIHA.2208@TK2MSFTNGP04.phx.gbl>, ~BD~@nospam.invalid > > says...<span style="color:darkred"> > >> In my opinion, witholding an explanation merely mudies the water, so > >> to speak.</span> > > > > Withholding an explanation could also mean that there is nothing to add > > to the request or that there is nothing the person is willing to state > > about it for several reasons.</span> > > I'm sure you are right! > > Maybe you will comment on whether or not you feel AumHa is a 'safe' place > to visit when one is seeking help and advice on computer related matters? </span> I make no suggestion that any site is safe, and only state that sites are unsafe if I've personally confirmed them to be unsafe or practice bad ethics - like pc butts 1 . com (see sig). I have never been to the site you ask about, so I can't comment. -- Leythos - spam999free@rrohio.com (remove 999 to email me) Public Service Warning: Learn about PCButts before you trust: http://forums.speedguide.net/archive/index.php/t-223485.html http://www.google.com/search?hl=en&q=pcbutts1+thief Quote
Guest ~BD~ Posted June 14, 2008 Posted June 14, 2008 In line responses: <span style="color:blue"><span style="color:green"> >> Maybe you will comment on whether or not you feel AumHa is a 'safe' >> place >> to visit when one is seeking help and advice on computer related matters?</span> > > I make no suggestion that any site is safe, and only state that sites > are unsafe if I've personally confirmed them to be unsafe or practice > bad ethics - like pc butts 1 . com (see sig).</span> A very sensible stance to take! FYI, your link to the speedguide forum article did not work for me (either from here of from the Techaarena thread here: http://forums.techarena.in/showthread.php?t=978738 <span style="color:blue"> > > I have never been to the site you ask about, so I can't comment. ></span> It often appears - in Malke an PABear responses in particular. I'm surprised that you haven't been sufficiently curious to take a look! style_emoticons/ <span style="color:blue"> > > -- > Leythos - spam999free@rrohio.com (remove 999 to email me) > Public Service Warning: Learn about PCButts before you trust: > http://forums.speedguide.net/archive/index.php/t-223485.html > http://www.google.com/search?hl=en&q=pcbutts1+thief > </span> Quote
Guest ~BD~ Posted June 14, 2008 Posted June 14, 2008 Thank you for your further response. style_emoticons/ No more to add right now. BD "FromTheRafters" <Erratic@ne.rr.com> wrote in message news:e7paIgWzIHA.4848@TK2MSFTNGP05.phx.gbl...<span style="color:blue"> > It was, but your answer seems to be that he should explain > because it bothers you that he doesn't explain. > > Maybe his integrity precludes him from commenting. > > Maybe his superiors have asked him not to comment. > > Maybe it seems redundant to him - yet another helpdesk > among so many others (which really muddies the waters > for those seeking help) > > If it turned out that he thinks that they are a bunch of clowns, > how would that help you? > > That having been said, I think they and he are very helpful > netizens.</span> Quote
Guest Leythos Posted June 14, 2008 Posted June 14, 2008 In article <eJsSpGgzIHA.4476@TK2MSFTNGP06.phx.gbl>, ~BD~@nospam.invalid says...<span style="color:blue"> > In line responses: > <span style="color:green"><span style="color:darkred"> > >> Maybe you will comment on whether or not you feel AumHa is a 'safe' > >> place > >> to visit when one is seeking help and advice on computer related matters?</span> > > > > I make no suggestion that any site is safe, and only state that sites > > are unsafe if I've personally confirmed them to be unsafe or practice > > bad ethics - like pc butts 1 . com (see sig).</span> > > A very sensible stance to take! FYI, your link to the speedguide forum > article did not work for me (either from here of from the Techaarena thread > here: http://forums.techarena.in/showthread.php?t=978738</span> It was bound to expire, happens, and I just don't check that often. I updated it with another site that still has that post archived. <span style="color:blue"><span style="color:green"> > > I have never been to the site you ask about, so I can't comment. > ></span> > > It often appears - in Malke an PABear responses in particular. I'm surprised > that you haven't been sufficiently curious to take a look! style_emoticons/</span> With so many sites, with so many ways to fight malware, there just isn't enough need for me to review every site. My belief is that once a system is compromised, that the only 100% certain way to remove that compromised, since it could spread in other directions, could install as-yet unknown malware, is to wipe the system and reinstall from scratch in a clean environment. -- Leythos - spam999free@rrohio.com (remove 999 to email me) Public Service Warning: Learn about PCButts before you trust: http://www.velocityreviews.com/forums/t513...f-removeit.html http://www.google.com/search?hl=en&q=pcbutts1+thief Quote
Guest Dell Techie Posted June 16, 2008 Posted June 16, 2008 1. Run Deckard's System Scanner (DSS) http://securitynewsfromthenet.blogspot.com...canner-dss.html 2. Run the vundo and combo fix http://securitynewsfromthenet.blogspot.com...-combo-fix.html 3. Run Malwarebytes Anti-Malware http://securitynewsfromthenet.blogspot.com...alware-105.html 4. Run the anti spyware removal programs spybot http://securitynewsfromthenet.blogspot.com...pyware-and.html 5 Run Superantispyware http://securitynewsfromthenet.blogspot.com...ition-free.html 6. Run a complete scan with free curing utility Dr.Web CureIt! http://securitynewsfromthenet.blogspot.com...web-cureit.html "Philip Michener" wrote: <span style="color:blue"> > I was recently infected with the Vundo Trojan and have had problems > ridding myself of it. > > Windows Malicious Software Removal finds the trojan, but gives the > message that it was only partially removed. Then tell me to run a > full scan with antivirus software to complete the removal. > > I have tried McAfee, XSoft, Lavasoft, and Spydoctor, but they all fail > to find the remaining files. > > Meanwhile, system gets reinfected, and popups start all over again. > > Anyone have suggestions as to how I can finally kill this bastard! > > </span> Quote
Guest dfinc Posted December 17, 2008 Posted December 17, 2008 Use vundo trojan manual removal instructions http://www.darfuns.com/remove-vundo-trojan/index.html -- dfinc ------------------------------------------------------------------------ dfinc's Profile: http://forums.techarena.in/members/dfinc.htm View this thread: http://forums.techarena.in/security-virus/984429.htm http://forums.techarena.in Quote
Guest David H. Lipman Posted December 17, 2008 Posted December 17, 2008 From: "dfinc" <dfinc.3kjrvb@DoNotSpam.com> | Use vundo trojan manual removal instructions No. Even when the the first instances of Vundo were introduced into the wild, removing the Vundo manually wasn't easy and Today's variants are much more difficult. -- Dave http://www.claymania.com/removal-trojan-adware.html Multi-AV - http://www.pctipp.ch/downloads/dl/35905.asp Quote
