Need Help removing " W32/autorun-FF "
Guest VistaKing
::I have a program that scans your computer for viruses and other stuff(
its not an antivirus) and it uses SOPHOS antivirus to find viruses. It
found one virus on my computer called \" W32/autorun-FF \" and I
downloaded the 30-day trial of Sophos antivirus but it is not finding
the W32/autorun-FF Virus . Is there a way I could remove it manually ?
:style_emoticons/S. when I go to the registry and click on \"Hkey_Current_User\" on
the right side I see \" OS shutdown REG_DWORD 0X00000000(0). Is that
suppose to be there? ::
VistaKing
  • Replies 5
Guest Mark H
http://www.sophos.com/support/disinfection/worms.html
"VistaKing" <guest@unknown-email.com> wrote in message
news:3c4d8133c72d7dd4f8921a42d2fbd232@nntp-gateway.com...<span style="color:blue">
> found one virus on my computer called " W32/autorun-FF " and I
> :style_emoticons/S. when I go to the registry and click on "Hkey_Current_User" on
> the right side I see " OS shutdown REG_DWORD 0X00000000(0). Is that
> VistaKing</span>
Guest VistaKing
Mark,
I installed the Sophos Anti-virus 30-day trial updated the definitions
and it didn't find that worm that I have. So I installed Registry
Mechanic and I think it cleared it out . The program I used to scan my
computer didn't show it again after I used the registry Mechanic
software .
Mark H;748360 Wrote: <span style="color:blue">
> 'Sophos - Removing worms'
> (http://www.sophos.com/support/disinfection/worms.html)
> "VistaKing" <guest@xxxxxx-email.com> wrote in message
> news:3c4d8133c72d7dd4f8921a42d2fbd232@xxxxxx-gateway.com...> > > <span style="color:green"><span style="color:darkred">
> > > ::I have a program that scans your computer for viruses and other</span>
> > stuff(<span style="color:darkred">
> > > its not an antivirus) and it uses SOPHOS antivirus to find viruses.</span>
> > It<span style="color:darkred">
> > > the W32/autorun-FF Virus . Is there a way I could remove it manually</span>
> > ?<span style="color:darkred">
> > > VistaKing > ></span></span></span>
VistaKing
Guest Mark H
You asked how to manually delete it.
I posted a link to those instructions from the SOPHOS site.
I'm glad you were able to remove it!
news:10e3a8efe6317b4d5bd64e21219867d9@nntp-gateway.com...<span style="color:blue">
> Mark,
> software .
> Mark H;748360 Wrote:<span style="color:green">
> > news:3c4d8133c72d7dd4f8921a42d2fbd232@xxxxxx-gateway.com...> > ><span style="color:darkred">
> > > stuff(
> > > It
> > > > downloaded the 30-day trial of Sophos antivirus but it is not</span></span></span>
finding<span style="color:blue"><span style="color:green"><span style="color:darkred">
> > > > :style_emoticons/S. when I go to the registry and click on "Hkey_Current_User"</span></span></span>
on<span style="color:blue"><span style="color:green"><span style="color:darkred">
> VistaKing</span>
Guest Mick Murphy
Below is proper Security, and how to use it!
Registry Mechanic deos more harm than good, as does ANY Registry cleaners
Mick Murphy - Qld - Australia
> Mark,
> software .
> Mark H;748360 Wrote: <span style="color:green">
> > news:3c4d8133c72d7dd4f8921a42d2fbd232@xxxxxx-gateway.com...> > > <span style="color:darkred">
> > > stuff(
> > > It
> VistaKing
Guest Mick Murphy
Security Programs that I have installed, and how to use them to remove
problems.
Vista’s Firewall works very well.
http://www.avast.com/eng/download-avast-home.html
Avast Anti-Virus is Vista compatible (32bit and 64bit Versions), FREE,
auto-updating, and a low resources user of your computer.
And, only have 1(one) Anti-Virus installed / running on your computer at any
one time..
Conflicts may occur if you have more than 1(one).
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.5.2 is a very good, FREE Anti-Spyware Program.
Download, install, update, and immunize your System with it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
http://www.javacoolsoftware.com/spywareblaster.html
SpywareBlaster 4.1 is a non-intrusive, FREE Anti-Spyware Program that runs
in the background (no scanning by you!).
Update it once a fortnight, and let it do its work in the background!
Important re: Safe Mode
If you happen to find a problem that you can’t uninstall / delete, reboot
the computer, and go into Safe Mode.
To get into Safe mode, tap F8 right at Power On / Startup, and use UP arrow
key to get to Safe Mode, then hit ENTER.
RESCAN your computer with Avast and Spybot S & D while in Safe Mode.
> Mark,
> software .
> > > stuff(
> > > It
> VistaKing
