Guest madman Posted June 17, 2008 Posted June 17, 2008 Greetings, your advice is needed. I see through searches that Hardware Profiles are no longer supported when shifting to Vista. This has me in fear of a MASSIVE security issue unless I am missing something. My environment: I maintain a very secure Windows network(active directory), where Wi-Fi is not allowed. I also utilize roaming profiles for my users, who are also not allowed admin rights to anything. When using a laptop, logging onto my LAN disable the Wi-Fi via the hardware profile to prevent possible bridging between a secure LAN and the outside world. Inversely, booting off my LAN enabled the Wi-Fi and disabled the Ethernet. How do I maintain this level of security with Vista Business or greater (And before you ask, NO I do not trust my users style_emoticons/ )? Does Vista have something more capable that I have not found yet? Thanks, MM -- madman Quote
Guest Steve Riley [MSFT] Posted June 17, 2008 Posted June 17, 2008 > This has me in fear of a MASSIVE security issue There's no security risk here. Since your users don't have admin rights, they won't be able to configure any routing protocols, and any malware that would by chance install as standard user won't be able to act as a router. <span style="color:blue"> > I maintain a very secure Windows network, where Wi-Fi is not allowed</span> This implies that you think wireless is insecure. When configured properly (that is, using WPA or WPA-2), wireless can be quite robust. Why not allow it, and use group policy to configure it? -- Steve Riley steve.riley@microsoft.com http://blogs.technet.com/steriley http://www.protectyourwindowsnetwork.com "madman" <guest@unknown-email.com> wrote in message news:d0be13647d9795aecef5c1ae4eff0dbe@nntp-gateway.com...<span style="color:blue"> > > Greetings, your advice is needed. > > I see through searches that Hardware Profiles are no longer supported > when shifting to Vista. This has me in fear of a MASSIVE security issue > unless I am missing something. > > My environment: > I maintain a very secure Windows network(active directory), where Wi-Fi > is not allowed. I also utilize roaming profiles for my users, who are > also not allowed admin rights to anything. > When using a laptop, logging onto my LAN disable the Wi-Fi via the > hardware profile to prevent possible bridging between a secure LAN and > the outside world. Inversely, booting off my LAN enabled the Wi-Fi and > disabled the Ethernet. > > How do I maintain this level of security with Vista Business or greater > (And before you ask, NO I do not trust my users style_emoticons/ )? > > Does Vista have something more capable that I have not found yet? > > Thanks, > MM > > > -- > madman </span> Quote
