RE: removal of win/vista antivirus pro
Guest John Doe
One thing I can now add from experience when removing this PITA using MBAM;
use sysinternal's Process Explorer to first SUSPEND the offending processes
(they're easy to spot), then run MBAM. Failure to do so will likely result
in the necessity to do a repair reinstallation of the OS . . .
