Guest eurows Posted June 25, 2008 Posted June 25, 2008 I have a dedicated server on a rack with fasthosts running sql, mysql and access. My main database is access. I have just had a new section built to my site that uses sql. The problem is that ever now and then (sometimes twice a day sometimes twice a week) the site demands a username and password from new visitors. When I look at the server the permissions seem to have disappeared and I have to reapply permissions across the server. This is having serious consequences on my site which is regularly used. The problem has only started happening since I had the new site section built and sql installed. The sql is a shared version available though the hosts. I have no idea what is causing the permissions problem and wondered if anyone had any suggestions. Quote
