Is Defender the problem?
Guest febsr
My Pavilion Vista laptop has been running slower and slower. Especially
while on the web. Pages take forever to come up. Even program files or
the All Programs menu. I have tried disabling Windows Defender thinking
it might be scanning everything. Is this a possibility? Thanks.
febsr
Guest Charlie Tame
febsr wrote:<span style="color:blue">
I have had problems with defender so it might be. Did you disable it?
What anti spyware software do you use? Web speed could be due to a
number of things but spyware is one.
Guest Mr. Arnold
"febsr" <guest@unknown-email.com> wrote in message
news:90d4bda28c3b5745757dc52277041fa2@nntp-gateway.com...<span style="color:blue">
></span>
It sounds like you have some kind of malware running on the computer that's
slowing it down.
Guest febsr
I use AVG and Adaware regularly. And I run disk cleanup almost daily. I
have noticed a small difference since disabling Defender, but not much.
I've tried to eliminate the most obvious causes, but still this Vista
unit runs much slower than any previous OS I've used. Way too many
services are running but eliminating any which seemed unnecessary caused
problems and I had to restore them. Any suggestions?
febsr
Guest Mr. Arnold
news:c1d676789fc84252eb07ca9318920e47@nntp-gateway.com...<span style="color:blue">
></span>
http://www.google.com/search?hl=en&q=how+t...sta&btnG=Search
Each one of the solutions you mentioned above can miss an exploit.
<http://www.windowsecurity.com/articles/Hidden_Backdoors_Trojan_Horses_and_Rootkit_Tools_in_a_Windows_Environment.html>
use Currports as Active Ports doesn't run on Vista.
http://technet.microsoft.com/en-us/sysinternals/default.aspx
Guest febsr
What do you suggest I use to scan? I haven't found any program that
finds and removes rootkits.
febsr
Guest Mr. Arnold
news:8b6ffd275e4b1421d40d0c2f426c759e@nntp-gateway.com...<span style="color:blue">
></span>
I am not saying you have to do anything, but you at least have to go look
for yourself with the proper tools and how to detect something on your own
without having some program do it for you, which the "hidden backdoor link
shows you how".
<http://technet.microsoft.com/en-us/sysinternals/25e27bed-b251-4af4-b30a-c2a2a93a80d9.aspx>
I will say that you need to learn how to reply post. I will suggest that to
you.
Guest NoBloatwarePlease
Not only did I notice the same slowdown, but the program seems to disrespect
any installed suite that already does the same thing. I have a perfectly
good virus/spam protector that doesn't need any freakin' help, thank you very
much. Windows Offender keeps popping up and (worse) quietly disrupting the
performance of my own virus/spam/spyware program. Either they made this
product for (a) lightweights, (style_emoticons/ to limit MS liability or
Guest febsr
Sorry for any confusion. I was asking for suggestions. I am just a
grandmother who is trying to keep my computers running smoothly. I do
need to rely on programs because my technical background is limited. I
don't know how to reply to a post as I don't post very much. If there
are some guidelines I'd be glad to read them. Thank you for your help.
febsr
Guest Beoweolf
When you run Vista - you really need to be sure you have the hardware to
match the horsepower it takes to make it work. Vista is very sensitive to
misconfiguration, driver problems, correct hardware configuration - much
more so than XP, XP-Pro or any of the 2K family.
Just how often do you clear your IE history and logs?
> febsr </span>
Guest febsr
I regularly clean them out about once a week. Disabling windows defender
helped some, but programs have begun hanging. I have 2gb ram which
seemed fine at first. Nothing obvious has changed except for the slowed
down performance.
febsr
Guest Anna
my nephew builds computers and he said it takes a lot of memory just to run
vista,mine is slow on startup and certain pages i open also .
> febsr
Guest Mr. Arnold
news:ba521d715830faf70d0f7c57e2bde1d6@nntp-gateway.com...<span style="color:blue">
> down performance.
></span>
Fsbsr, do you see how I am replying to you and everyone else in this thread
are replying to you? You don't keep posting to your original post with your
reply posts. You select the poster you are replying to and you reply to
them, like I am replying to you.
Guest Mick Murphy
Spybot Search & Destroy will.
Download and install it, then scan in Safe Mode.
All info below.
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.5.2 is a very good, FREE Anti-Spyware Program.
Download, install, update, and immunize your System with it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
Important re: Safe Mode
If you happen to find a problem that you can’t uninstall / delete, reboot
the computer, and go into Safe Mode.
To get into Safe mode, tap F8 right at Power On / Startup, and use UP arrow
key to get to Safe Mode, then hit ENTER.
RESCAN your computer with your Anti-virus and Spybot S & D while in Safe Mode.
Mick Murphy - Qld - Australia
> febsr
Guest Charles W Davis
> febsr</span>
Enable Windows Defender. Have you installed all Microsoft udates? It seems
that malware is rampant. An updated Defender will help.
Have you downloaded and installed AVG Free 8.0? It now incluces an
anti-spyware facility. Go to the direct download page here:
http://tinyurl.com/6g6497
"Anna" <Anna@discussions.microsoft.com> wrote in message
news:B50390C1-1EBD-4093-8E78-7BC9EC9C7F50@microsoft.com...<span style="color:blue">
> run
> "febsr" wrote:
><span style="color:green">
>> febsr
>></span></span>
Minimum 2GB
Guest febsr
Yes, I have updated AVG to 8.0 although I don't like it as much as 7.5.
Disabling Windows defender did help speed it up somewhat. And I have
done all windows updates except for SP1 for Vista as I have heard there
are still some problems which I am hoping to temporarily avoid.
febsr
febsr
