POSSIBLE HACK...PLEASE, PLEASE HELP!
Guest Annie
Thank you, Tom, but I still don't know how to disable the port. I'm not that
experienced a computer person. I want it disabled as long as it won't
interfere with my wireless internet connection.
Dan, I ran disk cleanup, defrag, Adaware, Spybot, Avast and HJT. I thought
HJT was supposed to be the one that told me if I had anything bad on my
computer. ??? If these programs don't pick up the RootKit/Virus combo,
you're saying Microsoft will?
The computer is running fine except for the incoming, from my IP, to my 2869
port. No outsiders. What will happen if I 'do' have a RootKit/Virus combo?
What should I look for in terms of odd behavior?
"Tom [Pepper] Willett" wrote:
> http://www.wilderssecurity.com/archive/ind...hp/t-59493.html
> "Annie" <Annie@discussions.microsoft.com> wrote in message
> news:5121917C-5F58-4F61-8300-5853E7AD2F79@microsoft.com...
> : post too long...deleted some.
> : Thought I had the problem fixed. No such luck.
> : ZA is still blocking to port 2869. Constant incoming alerts are driving
> me
> : crazy. Do I need to have this port open? If not, how do I close it? I
> : don't have anything networked such as wireless printers,
> : computer-to-computer, palm, etc. I do, however, have a router. Does this
> : make a difference?
> : Again...would love your advice. Maybe I should start a new thread?
> : "Annie" wrote:
> : > Just called BrightHouse and they had to reset my router. This seemed to
> take
> : > care of my ZA messages. I think my computer is clean according to HJT
> : > people...so...I'm logging off.
> : > Thanks to everyone who helped. You guys are amazing!
> : > "Annie" wrote:
> : > > Thanks, Root Kit.
> : > > A response from the other site regarding my HJ logs said he thinks I'm
> : > > actually pretty clean at the time. No malware.
> : > > So now I'm thinking my issue is with ZA. Maybe I'll hold off on
> : > > reformatting/reinstalling. ?? Will try to figure out what would be
> : > > comparable to ZA in regards to security and try a new program.
> : > > I took off all personal data from my computer and backed everything
> up. I
> : > > do have the recovery disk if needed.
> : > > Thanks again.
Guest Tom [Pepper] Willett
If it's in your modem, contact your ISP to find out how.
news:49799E98-B053-4FDF-8000-62B970D4A2FE@microsoft.com...
: Thank you, Tom, but I still don't know how to disable the port. I'm not
that
: experienced a computer person. I want it disabled as long as it won't
: interfere with my wireless internet connection.
: Dan, I ran disk cleanup, defrag, Adaware, Spybot, Avast and HJT. I
thought
: HJT was supposed to be the one that told me if I had anything bad on my
: computer. ??? If these programs don't pick up the RootKit/Virus combo,
: you're saying Microsoft will?
: The computer is running fine except for the incoming, from my IP, to my
2869
: port. No outsiders. What will happen if I 'do' have a RootKit/Virus
combo?
: What should I look for in terms of odd behavior?
: "Tom [Pepper] Willett" wrote:
: > http://www.wilderssecurity.com/archive/ind...hp/t-59493.html
: > "Annie" <Annie@discussions.microsoft.com> wrote in message
: > news:5121917C-5F58-4F61-8300-5853E7AD2F79@microsoft.com...
: > : post too long...deleted some.
: > : Thought I had the problem fixed. No such luck.
: > : ZA is still blocking to port 2869. Constant incoming alerts are
driving
: > me
: > : crazy. Do I need to have this port open? If not, how do I close it?
I
: > : don't have anything networked such as wireless printers,
: > : computer-to-computer, palm, etc. I do, however, have a router. Does
this
: > : make a difference?
: > : Again...would love your advice. Maybe I should start a new thread?
: > : "Annie" wrote:
: > : > Just called BrightHouse and they had to reset my router. This
seemed to
: > take
: > : > care of my ZA messages. I think my computer is clean according to
HJT
: > : > people...so...I'm logging off.
: > : > Thanks to everyone who helped. You guys are amazing!
: > : > "Annie" wrote:
: > : > > Thanks, Root Kit.
: > : > > A response from the other site regarding my HJ logs said he thinks
I'm
: > : > > actually pretty clean at the time. No malware.
: > : > > So now I'm thinking my issue is with ZA. Maybe I'll hold off on
: > : > > reformatting/reinstalling. ?? Will try to figure out what would
be
: > : > > comparable to ZA in regards to security and try a new program.
: > : > > I took off all personal data from my computer and backed
everything
: > up. I
: > : > > do have the recovery disk if needed.
: > : > > Thanks again.
Guest PA Bear [MS MVP]
Stick with http://aumha.net/viewtopic.php?f=30&t=34821, Annie.
Annie wrote:<span style="color:blue">
> me
> make a difference?
><span style="color:green">
>> take care of my ZA messages. I think my computer is clean according to
>> HJT
>> Thanks to everyone who helped. You guys are amazing!</span></span>
<snip>
Guest Shenan Stanley
<snipped>
> driving me crazy. Do I need to have this port open? If not, how
> do I close it? I don't have anything networked such as wireless
> printers, computer-to-computer, palm, etc. I do, however, have a
> router. Does this make a difference?
> Again...would love your advice. Maybe I should start a new thread?</span>
Personally - I think if you are going to continue trying to fix this
yourself - you are going to be better off backing up your important data
(documents, pictures, emails, contacts, etc) and wiping the computer and
installing from scratch.
I don't recommend that lightly - but...
http://groups.google.com/group/microsoft.p...92fc976519c105d
and
http://groups.google.com/group/microsoft.p...5fe465138260bcb
Essentially you have gotten to a point where you are unsure what you have
and whether or not what you might have is good or bad. It is at that point
that the wisest thing to do is (IMHO) start afresh.
- Hook up some external hard disk drive or burn DVDs/CDs of your important
sstuff (keep that machine off the network.) Copy everything you need.
Pictures, documents, spreadsheets, images, emails, contacts, text files,
serial keys, installation files, etc. If you can - get an imaging
application (Norton Ghost, Acronis TrueImage, BootItNG, etc) and make a
complete image of your hard disk drive onto an external device and you can
go back later for anything you did not back up.
- Install Belarc Advisor on the machine (from an external drive or
something) and run it - print the results. That should have your Windows
Product Key, other software with Product keys that register on the machine,
a list of stuff you have installed and a list of the hardware installed on
your machine.
- Break out all of your installation media and keys/etc (Windows XP
installation CD, any office suites/products you have - etc...) Any program
you need to have installed on the computer, find its installation media
(even if it is an installation executable file and a text file with the
serial number in it) and get it onto media seperated from the machine so you
can install using it later.
- Now that you have everything backed up and everything ready to install...
Clean install Windows XP:
http://www.michaelstevenstech.com/cleanxpinstall.html
- Update the hardware drievrs...
- Get Windows XP SP3 from another computer onto CD or thumb drive or
somehting to the newly formatted drive... Install it.
- Install your other software (AV and such).
- THEN connect to the Internet and get updates from
http://windowsupdate.microsoft.com/ ...
Shenan Stanley
MS-MVP
How To Ask Questions The Smart Way
http://www.catb.org/~esr/faqs/smart-questions.html
Guest Root Kit
On Thu, 24 Jul 2008 09:22:02 -0700, Annie
>Just called BrightHouse and they had to reset my router. </span>
So afterwards, did you make the basic router securing as suggested?
Guest Root Kit
On Thu, 24 Jul 2008 10:32:01 -0700, Annie
>ZA is still blocking to port 2869.</span>
If it's blocked there's not that much to worry about.
> Constant incoming alerts are driving me crazy.</span>
Yes, but you asked for that yourself by installing ZA.
>computer-to-computer, palm, etc. </span>
Any peer-to-peer app's?
Skype?
Anyway, download and run CurrPorts from NirSoft to try and identify if
some app is using the port mentioned.
http://www.nirsoft.net/utils/cports.html
Guest Root Kit
On Thu, 24 Jul 2008 13:03:01 -0700, Annie
>Thank you, Tom, but I still don't know how to disable the port.</span>
I think Tom is suggesting that UPnP is enabled in your router. And he
may very well be right. Did you make the basic router securing as
suggested?
Guest Root Kit
On Thu, 24 Jul 2008 23:06:31 GMT, Root Kit <b__nice@hotmail.com>
>Yes, but you asked for that yourself by installing ZA.</span>
Windows firewall would just have silently blocked it.
Guest Root Kit
On Thu, 24 Jul 2008 10:32:00 -0700, Dan
>Annie, the key word you used is that you Think your Machine is Clean (TMC)
>and unless you run anti-virus programs like Windows Live One Care, Spybot
>Search and Destroy, Kaspersky, and AVG 7.5, and others then how will not be
>sure. </span>
The app's mentioned cannot in any way guarantee that a machine is
clean. Only a thorough comparison of relevant system files to a known
safe baseline can give a trustworthy hint about a systems state. This
is not a task for Joe Average.
>Please make sure only one antivirus program is installed at a time and
>beware of false positives because anti-virus programs like Avast have gotten
>much worse over time. For example, Avast Antivirus thought that Yahoo web
>portal had malware when it did not.</span>
Anti-malware products often cause more problems than they solve.
Guest Annie
I disabled UPnP in the router settings. Also disabled UPnP and SSDP
Discovery Service on my computer. No more messages since I did this.
Everything seems to be running smoothly right now.
In doing this, I found a file I don't recognize. B's Recorder GOLD Library
General Service. bgsvcgen.exe Is this something that should be uninstalled?
(it's not in my add and remove folder) I have no idea what it's doing on my
machine.
The HJT guy said he didn't find any malware so I'm guessing it's OK to leave
on.
Guest Root Kit
On Fri, 25 Jul 2008 12:41:01 -0700, Annie
>machine. </span>
http://www.neuber.com/taskmanager/process/bgsvcgen.exe.html
The "HJT guy" said:
<QP>
Port 2869 traffic is UPnP traffic, generated between your router and your
workstation. It is harmless, and certainly not coming from outside of your
computer system.
You can disable UPnP on the router, the client, or both, to stop the
traffic.
</QP>
Source: http://aumha.net/viewtopic.php?p=196621#p196621
~PA Bear
> Library
> uninstalled? (it's not in my add and remove folder) I have no idea what
> it's doing on my machine.
> leave
> on.</span>
<snip>
Guest Annie
That's not my issue anymore. I already posted I disabled UPnP on router and
computer...everything is fine. I said 'thank you', too. I really, really
appreciate everyone's help here. BTW, I won't name name's but one of those
'guys' at aum....was very rude. Read many posts and he's obviously upsetting
a lot of people. Why do they allow that? Unexperienced people with computer
problems are there for help. Not to be yelled at. One little mistake in a
post and man, he's all over me! Not just myself. I, for one, won't be going
back there. I'm sticking to Microsoft for help. If I'm bugging you guys,
Sorry. I don't mean to be. Sheeesh.
From my previous post: "In doing this, I found a file I don't recognize.
B's Recorder GOLD Library<span style="color:blue">
>machine. " This is my issue. I'm just now reading the info from the link RootKit gave me. </span>
> The "HJT guy" said:
> <QP>
> computer system.
> traffic.
> </QP>
> ~PA Bear
> Annie wrote:<span style="color:green">
> > Library
> > leave
> > on.</span>
> <snip>
Google is your friend.
: From my previous post: "In doing this, I found a file I don't
recognize.
: B's Recorder GOLD Library
: >General Service. bgsvcgen.exe Is this something that should be
uninstalled?
: > (it's not in my add and remove folder) I have no idea what it's doing on
my
: >machine. " This is my issue. I'm just now reading the info from the
: "PA Bear [MS MVP]" wrote:
: > The "HJT guy" said:
: > <QP>
: > Port 2869 traffic is UPnP traffic, generated between your router and
your
: > workstation. It is harmless, and certainly not coming from outside of
your
: > computer system.
: > You can disable UPnP on the router, the client, or both, to stop the
: > traffic.
: > </QP>
: > Source: http://aumha.net/viewtopic.php?p=196621#p196621
: > ~PA Bear
: > Annie wrote:
: > > I disabled UPnP in the router settings. Also disabled UPnP and SSDP
: > > Discovery Service on my computer. No more messages since I did this.
: > > Everything seems to be running smoothly right now.
: > > In doing this, I found a file I don't recognize. B's Recorder GOLD
: > > Library
: > > General Service. bgsvcgen.exe Is this something that should be
: > > uninstalled? (it's not in my add and remove folder) I have no idea
what
: > > it's doing on my machine.
: > > The HJT guy said he didn't find any malware so I'm guessing it's OK to
: > > leave
: > > on.
: > <snip>
Ya just gotta love...
<QP>
Pfft. I'm almost 13, and I know how to manipulate the registry easily.
</QP>
Source:
http://64.233.169.104/search?q=cache:d3bow...clnk&cd=1&gl=us
<VBEG>
Tom [Pepper] Willett wrote:<span style="color:blue">
><span style="color:green"><span style="color:darkred">
>>> recognize.
>>> it's doing on my machine. " This is my issue. I'm just now reading the
>>> info from the link RootKit gave me.</span></span></span>
<snip>
Yep. I Googled for it when she first brought it up. It's everywhere ;-)
"PA Bear [MS MVP]" <PABearMVP@gmail.com> wrote in message
news:uMHGpBq7IHA.616@TK2MSFTNGP02.phx.gbl...
: Ya just gotta love...
: <QP>
: Pfft. I'm almost 13, and I know how to manipulate the registry easily.
: </QP>
: Source:
: <VBEG>
: Tom [Pepper] Willett wrote:
: > Google is your friend.
: >>> From my previous post: "In doing this, I found a file I don't
: >>> recognize.
: >>> B's Recorder GOLD Library
: >>> General Service. bgsvcgen.exe Is this something that should be
: >>> uninstalled? (it's not in my add and remove folder) I have no idea
what
: >>> it's doing on my machine. " This is my issue. I'm just now reading
the
: >>> info from the link RootKit gave me.
: <snip>
You are obviously referring to Mr Castner, Annie. Ref:
I, too, noticed that he upset/annoyed a lot of posters and at times I wondered if, in fact, there
was more than one individual providing 'solutions' under the guise of being
http://aumha.net/memberlist.php?mode=viewprofile&u=12522
Please don't fret though ........ 'he' was rude to me too! <wink>
I tried to find the answer to this question: If Mr Castner 'joined' AumHa 9/18/06, how come he was
giving answers to folk back in 2004? See here:
http://aumha.net/search.php?st=0&sk=t&sd=d...2522&start=8190
As the most profligate poster at AumHa, Robear Dyer (see
http://aumha.net/memberlist.php?mode=&sk=d&sd=d ) is here in this thread, perhaps he will explain
this apparent anomally to all of us.
Perhaps ...... maybe ........ all is not quite as it appears to be at first sight ............ 'over
there'!
Dave
news:AED76AE7-564B-42C8-8B0C-A082F056A316@microsoft.com...<span style="color:blue">
></span>
<snip>
Guest Annie
You hit the nail on the head, Dave! Don't think he should be allowed to
treat people like that.
Anyway. I did get my port problem fixed. Thanks, everyone. I've disabled
the B's Recorder.....file. I'll leave it at that for the time being. Yes, it
was everywhere on Google, guys. style_emoticons/ Just hadn't gotten that far in my
research yet. 13? Pretty good for 13!
I'm now working with Avast to clear up an updating problem. It's been one
thing after another since I connected with RoadRunner! Altho I love the
speed, the tech obviously made changes all over my computer without my
knowledge. Shoulda told me.
> there'!
> Dave
> news:AED76AE7-564B-42C8-8B0C-A082F056A316@microsoft.com...<span style="color:green">
> ></span>
> <snip>
Annie, you should know that ~BD~ was banned from AumHa Forums, several other
forums, an ISP, and at least one Usenet server for his bizarre and sometimes
harrassing behavior. By jumping in here, he's taking advantage of you in an
effort to further his agenda, not to assist you.
@Annie only: Bill's AumHa profile was "horked" due to a server problem in
Sept-06. His posts from 18 Sept-06 and earlier were associated with the
"horked" profile. Bill is a well-respected, longtime MS MVP and has been an
AumHa VSOP and Moderator for many years; cf. http://aumha.org/vsop.htm.
Participation in many AumHa Forums requires a certain level of computer
proficiency but we attempt to assist all comers. (I did suggest other
forums to you.) You may find Computer Haven forums (where ~BD~ is also
/personna non grata/, I believe) more to your liking:
http://www.computerhaven.info/
~Robear Dyer (PA Bear)
MS MVP-IE, Mail, Security, Windows Desktop Experience - since 2002
AumHa VSOP & Admin http://aumha.net
DTS-L http://dts-l.net/
> disabled
> it was everywhere on Google, guys. style_emoticons/ Just hadn't gotten that far in my
> knowledge. Shoulda told me.</span>
<snip>
Answer below
news:B10E2E07-DA8A-4CDB-BF9F-E8C0997B15D2@microsoft.com...<span style="color:blue">
I'm really pleased to hear that you've succeeded in fixing things, Annie. style_emoticons/
Robear is correct when he tells you I have been banned by AumHa - for asking difficult questions
............. and banned from Annexcafe.com for the very same reason. The folk at
hxxp://www.computerhaven.info/ have not (to my knowledge) banned me, but I noted that some were the
same as the 'helpers' on Aumha so haven't felt comfortable there.
I have NEVER been banned by 'an ISP, and at least one Usenet server' - that is a lie.
I posted this note in another thread recently:-
Hello PA Bear!
As you have dropped by, I wonder if you can tell me why it is that if I type www.Aumha.com into my
browser address bar I'm whisked off to this URL - http://downloadprograms.biz/?rid=544620
Many here will know that you are one of the resident experts at www.Aumha.net and that
www.Aumha.org is a well established site for helping those wishing to learn about PC's and security.
I find it surprising that the .com domain isn't 'owned' by Mr James E. Eshelman, a man of great
experience, as explained here: www.aumha.org/resume.htm
TIA
I didn't receive a reply! Perhaps someone else reading here will know the answer.
As far as a "horked" profile is concerned, I'd have thought that it would be easy for such clever
folk to correct the false information.
I used to trust people once!
Dave
Guest Root Kit
On Sat, 26 Jul 2008 10:03:25 +0100, "~BD~" <BoaterDave@nospam.invalid>
>http://aumha.net/viewtopic.php?p=196621#p196621</span>
Honestly, based on this thread alone I see no sign of rudeness. He
answers a question (correctly) and reminds about forum rules. That's
not being rude unless one is too sensitive.
