BitLocker: How to change drive letter S:
Guest Robinio
I installed BitLocker using MS "BitLocker Preparation Tool". Now S: is my
system partition and I cannot change this drive letter. Since we use software
that wants some data being located on S: I need to change this letter. I
found no 'regular' way to do this.
Would it help if I disable BitLocker, use letter S: for example CD-ROM or
something and then (when S: would not be available any more) re-install
BitLocker? Then I could change CD-ROM letter back to whatever and use S: for
this software.
Best regards,
Robinio
  • Replies 2
Guest robinio
Botted with Vista CD and repaired boot configuration. This obviously removed
'system' from this partition so I could remove it with device manager. Now
everithing is as it was before BitLocker.
"Robinio" <Robinio@discussions.microsoft.com> wrote in message
news:9CD0670B-3C91-4904-9827-9D34C633D9B9@microsoft.com...<span style="color:blue">
> software
> for
> this software.
> Best regards,
> Robinio </span>
  • 2 weeks later...
Guest WJK-Design
Next time if you just want to change the drive letter of the boot partition
you can do it through the registry:
http://support.microsoft.com/kb/223188/en-us
Just rename \DosDevices\S: to \DosDevices\M: for example. If you reboot
your system the drive letter will be changed to M: instead of S:.
Cheers,
WJK
