Running MSI from a NT service problem
Guest petr.kizima@gmail.com
Hello everybody,
I am developing an updater application which is polling a server
asking for updates. The application is executing as a NT service under
Local System account. Once there is an update, the service application
is downloading it, and runs.
Here problems start to appear. The update is an MSI application which
fails with the weird error:
DIFXAPP: INFO: creating HKEY_USERS\S-1-5-18\Software\Microsoft\Windows
\CurrentVersion\DIFxApp\Components\{35D06518-F300-4A4A-
B802-1AC70C92E08F} (User's SID: 'S-1-5-18') ...
DIFXAPP: ERROR 0x57 encountered while creating subkey for component
'{35D06518-F300-4A4A-B802-1AC70C92E08F}'
DIFXAPP: RETURN: ProcessDriverPackages() 87 (0x57)
So, the question is: am I able to launch MSI from a NT service? I read
that the MSI has to have a property ALLUSERS set to 1, i.e. ALLUSERS=1
(read
http://groups.google.com/group/microsoft.p...b607cd073a31f5b
) but it does not help. If I launch MSI under user there are not
problems.
Thank you for any hints and ideas, Petr.
  • Replies 4
Guest Phil Wilson
I believe that you must set ALLUSERS to 1 (such as in the property table or
on the commmand line) to install from local system account. When you say "it
does not help" what exactly did you do?
Phil Wilson
Definitive Guide to Windows Installer
http://www.apress.com/book/view/1590592972
<petr.kizima@gmail.com> wrote in message
news:2143a4cf-6101-4169-87f6-fc88b31968ff@d77g2000hsb.googlegroups.com...<span style="color:blue">
> Hello everybody,
> DIFXAPP: INFO: creating HKEY_USERSS-1-5-18SoftwareMicrosoftWindows
> CurrentVersionDIFxAppComponents{35D06518-F300-4A4A-
> (read
> problems.
> Thank you for any hints and ideas, Petr. </span>
On Sep 17, 9:19 pm, "Phil Wilson"
<phil.wil...@wonderware.something.com> wrote:<span style="color:blue">
> Phil Wilson
> Definitive Guide to Windows Installerhttp://www.apress.com/book/view/1590592972
> <petr.kiz...@gmail.com> wrote in message
><span style="color:green">
> > Hello everybody,</span>
> > asking for updates. The application is executing as aNTserviceunder
> > Local System account. Once there is an update, theserviceapplication
> > is downloading it, and runs.</span>
> > Here problems start to appear. The update is anMSIapplication which
> > fails with the weird error:</span>
> > DIFXAPP: RETURN: ProcessDriverPackages() 87 (0x57)</span>
> > So, the question is: am I able to launchMSIfrom aNTservice? I read
> > that theMSIhas to have a property ALLUSERS set to 1, i.e. ALLUSERS=1
> > (read
> >http://groups.google.com/group/microsoft.p...rmsdk.msi/brows...
> > ) but it does not help. If I launchMSIunder user there are not
> > problems.</span>
> > Thank you for any hints and ideas, Petr.</span></span>
Hello Phil,
Thank you for reply. The property is set, and I got the problem with
MSI anyway (see logs in prev. message).
Guest Stefan Kuhr
Hi Petr,
petr.kizima@gmail.com wrote:<span style="color:blue">
> <snip>
Does your installation install a driver under the hood? If so, check if
the installation works if you run the msi from SYSTEM with desktop
interaction enabled. For testing purposes run on W2K, XP or W2K3 Server
cmdasuser localsystem
to get a command prompt running as system, then do an msiexec /i msifile
and see if the installation works. If it does, then you probably install
an unsigned driver or a driver with a coinstaller which is something you
can only do from an interactive logon session.
You can get cmdasuser from the IIRC last issue of MSJ, which can be
found on http://www.msj.com. The article link seems to be broken, but
the code is here:
http://download.microsoft.com/download/0/6...b4/MSJFeb00.exe
HTH,
Stefan
Hello Stefan, Thanks for your reply.
> interaction enabled.</span>
Yes, the MSI is installing the driver. I tried with cmdasuser and I
got the failure anyway. Here goes a logs when I run it via cmdasuser
in Windows 2000 SP4:
So, I decided to look further into this issue. I decompiled the
difxapp, and found the following code which fails:
..text:04049D5 push 80000001h ; hKey
..text:004049DA call ds:__imp__RegCreateKeyExW@36 ;
RegCreateKeyExW(x,x,x,x,x,x,x,x,x)
..text:004049E0 mov [ebp-0CCh], eax
..text:004049E6 test eax, eax
..text:004049E8 jz short loc_404A40
..text:004049EA push dword ptr [ebp-0D4h]
..text:004049F0 push eax
..text:004049F1 push offset aDifxappError_5 ;
"DIFXAPP: ERROR 0x%X encountered while c"...
..text:004049F6 push ebx
..text:004049F7 call ?
LogCustomActionInfo@@YAXKPBGZZ ; LogCustomActionInfo(ulong,ushortconst
Which proves that the failure is caused by a failure of
RegCreateKeyExW function. So I put a simple code into my NT service
and it reproduces the problem. I hope it would help people from
Microsoft to isolate and fix this problem:
std::wstring szKey = TEXT("S-1-5-18\\Software\\Microsoft\\Windows\
\CurrentVersion");
HKEY componentRegKey = 0;
LONG uiStat = RegCreateKeyEx(HKEY_USERS, szKey.c_str(), 0, NULL,
REG_OPTION_NON_VOLATILE, KEY_READ | KEY_WRITE, NULL, &componentRegKey,
NULL);
When running in NT service in Windows 2k the code above always fails.
Could please someone shed light why, or I should decompile and dig
further into RegCreateKeyEx?
Thanks. Petr.
Stefan Kuhr wrote:<span style="color:blue">
> Hi Petr,
> petr.kizima@gmail.com wrote:<span style="color:green">
> > <snip>
> ></span>
> the code is here:
> HTH,
> Stefan</span>
