Administrator Rights problem
hi...i have install windows vista home on toshiba laptop.
in my laptop there is one user only me..administrator
in my system there is only one drive C.
by mistake i set all permission for C drive for administrator means for
me to set deny.
so now i can't access my C drive..it say that access is denied.
i can only use and see desktop now nothing else.
and access denied most of the services..
so plz help me...
dkshah
  • Replies 7
Guest Peter Foldes
Boot in with or as Administrator and without password then change it back
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
"dkshah" <guest@unknown-email.com> wrote in message news:760998599d1f1a8d164003193a1c9157@nntp-gateway.com...<span style="color:blue">
> me to set deny.
> so plz help me...
> dkshah</span>
Guest FromTheRafters
> hi...i have install windows vista home on toshiba laptop.</span>
Did this myself recently.
> in my laptop there is one user only me..administrator</span>
There should be two:
1) Administrator (for administration)
2) Standard User (For day to day use)
> in my system there is only one drive C.</span>
You see only one drive (C: drive), same here.
> me to set deny.
> so now i can't access my C drive..it say that access is denied.</span>
Had you done this in a Standard User account, you would have
the Administrator account to fall back on to "undo" this mistake.
> so plz help me...</span>
Can't you use the same method you used to change the permissions to
"deny" to change them back to "Full Control" or "Allow" or whatever
it was before?
Right click on the drive icon and select "Properties"
Click the "security" tab
Click the "edit" button
Highlight "administrators"
check the "allow" box next to the "full control" item - the deny checks
should go away.
Okay your way out and reboot.
In case you get "denied access" to the right click "properties"
route, you may want to create a standard user account and
use that to access this route.
Does "Control Panel" appear if you press the "Windows" key
and "r" at the same time and type "control" and enter?
If so - create a new user account as "Standard User" and
log into it to navigate to the settings.
> me to set deny.
> so plz help me...
> dkshah </span>
ya i did...
i have only user..name is dkshah(as a administrator)
when i click on properties and select on security tab but there is no
edit options like that and everything is denied for me..
and ya i cant allow me to create new user..
ya i can see that options but when i click on that nothing to happened.
and also i cant restore my system..
dkshah
news:fd7f6174f4839dff854d9686f02944d1@nntp-gateway.com...<span style="color:blue">
> ya i did...
> and also i cant restore my system..</span>
Do you have access to someone who can help you locally?
You may need to activate the hidden administrator account
or add a standard user by way of the command prompt to
fight your way out of this.
Do you have the installation disk?
