Problems with the "Require trusted path for credential entry" setting
Hi
After reading
http://technet.microsoft.com/da-dk/magazin...019(en-us).aspx, i want
to try the recommandation to use "Require trusted path for credential
entry" when evaluate to administrator. After activating this settings, i
selected windows update and chose "run as administrator", then a dialog
came and I pressed ctrl+alt+del to access the "secure desktop". The screen
change to the startup screen, with the text "please wait". Then no more
happened. I left it on for a 5 - 10 min, but nothing happens. Then the
only options was to power off the computer, return to safe mode and
deactivate the settings.
Anyone knows why this happens???
rrm
  • Replies 3
Guest FromTheRafters
"rrm" <runemadsen16@hotmail.com> wrote in message
news:op.uho4kuz0b2lo77@rrm.pbk.dk...<span style="color:blue">
> Hi
> After reading
> selected windows update and chose "run as administrator",</span>
Did you reboot? I'm not sure it is needed, but
sometimes a reboot is needed for some settings
to actually take.
> then a dialog came</span>
Could you be more vague? style_emoticons/)
> deactivate the settings. </span>
Re: Problems with the "Require trusted path for credential entry"setting
Den 19.09.2008 kl. 00:26 skrev FromTheRafters <erratic@ne.rr.com>:
> news:op.uho4kuz0b2lo77@rrm.pbk.dk...<span style="color:green">
>> Hi
>> After reading
> to actually take.</span>
I did not rebot after changing the setting.... But i suppose the old
evaluation still is shown!?!?
<span style="color:blue"><span style="color:green">
> Could you be more vague? style_emoticons/)</span>
Well the dialog has two options: "Would you like you complete the action"
and "Would you do not complete the action". After clicking on the first, a
dialog is shown to press ctrl+alt+del and after i have pressed this, then
my problem occur.
>> deactivate the settings.</span>
></span>
news:op.uhpvxjjkb2lo77@rrm.pbk.dk...<span style="color:blue">
>> news:op.uho4kuz0b2lo77@rrm.pbk.dk...<span style="color:darkred">
>>> Hi
>>> After reading
> evaluation still is shown!?!?</span>
It wasn't clear to me from your first post, but it
appears that the setting was applied properly.
<span style="color:blue"><span style="color:green"><span style="color:darkred">
> my problem occur.</span>
Thanks for the additional details. It appears that you
did everything correctly, but something is amiss with
either the secure desktop switching or something else
related to "consent.exe" hanging.
Maybe someone else here has seen this or something
similar and can help you. A quick Google search did
not turn up anything for me specifically related to this.
>>> deactivate the settings.</span></span></span>
Sorry I couldn't help, but I'll keep looking for answers.
