Virus problem
I did something stupid. I wasn't paying attention and got the wimad virus.
I had the useless bitdefender AV software and it did NOTHTING!! I contacted
them and they told me to delete all this crap which I did and it still
couldn't find/remove the virus. If anything it only made things worse!!
There solution to that was to stop answering my emails. So I went out and
bought Kaspersky AV software. The problem now is I can't uninstall
bitdefender, windows keeps saying the windows installer won't activate or
some such nonsense. I've tried it in safe mode but get the same message. So
I tried to force the Kaspersky software in and it won't install due to the
same reasons. If I could get bitdefender out and Kaspersky in I feel I could
solve my problems but I have no idea how to get the windows installer
working. Also I now cannot get online because internet explorer won't open.
Someone please help me.
  • Replies 7
Guest S. Pidgorny
G'day:
Spectre wrote:<span style="color:blue">
> Someone please help me.</span>
Either use Kaspersky technical support (presumably included with the
purchase)? or rebuild the system, install AV and scan backup media
before tranfering documents back to your system.
Svyatoslav Pidgorny, MS MVP - Security, MCSE
-= F1 is the key =-
http://sl.mvps.org http://msmvps.com/blogs/sp
Tried there support they said in order for there AV software to work it has
to go online and update itself when you install it. The reason I bought it
was because the box said it could fix an infected computer. They just
offered me my money back. I guess buying a external hard drive and
transfering all the important stuff onto it is one option... an expensive
option!
> G'day:
> Spectre wrote:<span style="color:green">
> -= F1 is the key =-
Guest Max Wachtel
On Mon, 22 Sep 2008 03:09:00 -0400, Spectre
<Spectre@discussions.microsoft.com> wrote:
Reply Inline
> virus.</span>
No AV solution can protect you from yourself......
> contacted
> couldn't find/remove the virus. If anything it only made things worse!!</span>
well if you deleted everything there wouldn't be anything to find......
> There solution to that was to stop answering my emails.</span>
What program do you use to check your e-mail?
> So I went out and
> message. So
> the
> could
> open.</span>
How are you posting? Do you have another browser to use?
Use another computer to download the MULTI_AV scanning tool. You can find
a link to it on my site(see below). Run the tool and get all definition
files for all 4 tools(do not scan the system yet). Then copy the whole
folder to a USB stick, put it in your computer, and scan/fix all problems
found.
Post back with results
Virus Removal http://max.shplink.com/removal.html
Keep Clean http://max.shplink.com/keepingclean.html
Change nomail.afraid.org to gmail.com to reply by email.
nomail.afraid.org is setup for use in USENET by everyone
Guest PA Bear [MS MVP]
You'll have to resolve your infection(s) before you'll be able to uninstall
BitDefender [1] and install Kaspersky.
Run a /thorough/ check for hijackware, including posting your hijackthis log
to an appropriate forum.
Checking for/Help with Hijackware
http://aumha.org/a/parasite.htm
http://aumha.org/a/quickfix.htm
http://aumha.net/viewtopic.php?t=5878
http://wiki.castlecops.com/Malware_Removal...n:_Introduction
http://mvps.org/winhelp2002/unwanted.htm
http://inetexplorer.mvps.org/data/prevention.htm
http://inetexplorer.mvps.org/tshoot.html
http://www.mvps.org/sramesh2k/Malware_Defence.htm
http://defendingyourmachine2.blogspot.com/
http://www.elephantboycomputers.com/page2....emoving_Malware
When all else fails, HijackThis v2.0.2
(http://aumha.org/downloads/hijackthis.exe) is the preferred tool to use (in
conjuction with some other utilities). HijackThis will NOT fix anything on
its own, but it will help you to both identify and remove any
hijackware/spyware with assistance from an expert. Post your log to
http://spywarehammer.com/simplemachinesfor....php?board=10.0,
http://forums.spybot.info/forumdisplay.php?f=22,
http://aumha.net/viewforum.php?f=30, or another appropriate forum for review
by an expert in such matters, not here.
If the procedures look too complex - and there is no shame in admitting this
isn't your cup of tea - take the machine to a local, reputable and
independent (i.e., not BigBoxStoreUSA or Geek Squad) computer repair shop.
[1] http://kb.bitdefender.com/KB333-en--How-to...itDefender.html
~Robear Dyer (PA Bear)
MS MVP-IE, Mail, Security, Windows Desktop Experience - since 2002
AumHa VSOP & Admin http://aumha.net
DTS-L http://dts-l.net/
> virus.
> contacted
> So I tried to force the Kaspersky software in and it won't install due to
> the same reasons. If I could get bitdefender out and Kaspersky in I feel
> I
> could solve my problems but I have no idea how to get the windows
> installer
> open.
> Someone please help me. </span>
They told me to delete certain files and folders. Which like I said only
made things worse. I was then supposed to re-scan everything and viola! But
it didn't work there lousy software didn't find any viruses. I get my email
from the web I didn't dare open outlook express. I borrowed a family members
computer and I can link the two but still don't really know how to fix the
problems. I only use explorer I don't care for that freeware/shareware
whatever stuff. I'm at work now so I'll try that scanning tool when I get
home. Thanks
> Reply Inline
> > virus.</span>
> > contacted
> > So I went out and
> > message. So
> > the
> > could
> > open.</span>
> found.
  • 2 weeks later...
CAUTION! Re: Virus problem
"nirajjadhav" <nirajjadhav.3gphwm@news.home.local> wrote in message
news:nirajjadhav.3gphwm@news.home.local...<span style="color:blue">
> Tried removing an annoying popup from my system for ages. Finally
> 'Search And Destroy - Top Anti-Spyware Software 2008'
> (hxxp://www.search-and-destroy.com) removed the popup for good. A
> free
> scan afterwards found and removed hundreds of Trojans and spyware.</span>
This is ROGUE antimalware... DO NOT download!
SearchAndDestroy (search-and-destroy.com):
This program reports false or exaggerated system security threats on the
computer.
http://www.symantec.com/security_response/...2039-99&tabid=2
-jen
Caution! Re: Virus problem
"nirajjadhav" <nirajjadhav.3gphwn@news.home.local> wrote in message
news:nirajjadhav.3gphwn@news.home.local...<span style="color:blue">
> free
computer.
-jen
